Maybe this summer we can meet up in the central Cascades for some exploring, etc... I'd like to do it as an over-nighter since we both will have a couple hour drive each way. There's nothing like getting way out there away from those normal campgrounds and setting up camp where only a Jeep can take you.
It would be great if we could get a few more Washington/Northern Oregon Jeepers to join us. Maybe shoot for July or August? The snow should be gone by then in the upper elevations.
-Pete
And yes, 3.07's with 33" tires is so slow it's not even funny. But the worst part is 1st gear is so high that I feel like I have to drop into low range to start out on some steep city streets. I really have to slip the clutch a lot to get it moving. That never smells goods
-Pete
Give up your Jeep for a woman???? You are a sick man! Get some help NOW!
Seriously, Kev, congratulations on your engagement! When's the big day gonna be?
Hope you figure out a way to have the new family AND keep the new Jeep. Get an older but safe and dependable vehicle for the family needs??? No one says the family car has to be new, right? As long as it is safe and dependable.
Too bad they don't still make the XJ! That would be the best of both worlds: a family wagon that would still wheel like a demon. Maybe you could get one of them with low miles?
Tom
Have you hugged your Jeep today?
If you are geared too high with your gear and tire combination, your crawl speed will be too fast for going down steep trails, causing you to use your brakes too much. Man, I have been in spots where I wished I had even lower crawl speed, and I have 3.73 gearing with 31" tires. In those situations, 3.07 gearing and 33" tires would have been AWFUL!
You can always go with a Tera Low conversion for the T-case to get a higer ratio low range, but that's fairly expensive, I guess. That would allow you to select a street-friendly gearing for your highway driving and still have good 4WD low range gearing.
Tom
http://www.itsajeep.org/PhotoPost/showphoto.php?photo=806&pas- sword=&sort=1&cat=500&page=1
Gotta do a dad proud
congrats KEVIN!
Keep Jeepin
Happy New Year
BAma
-Mike
There is a huge difference in the ride when I go over 30 lbs in those BFG's: it gets MUCH rougher.
You want the pressure that gives you the best "footprint." This means getting ALL of the tread down on the road across the width of the tire. Over inflation wears out the center tread, and under inflation wears out the edges. You have the factory tires on your Jeep right? If so, I would go with the recommended pressure.
For a given tire, a LOT depends on the weight that the tire will support on a particular vehicle. You divide the weight of the vehicle by four to get the weight each tire will see, and then ratio the pressure based on the percentage of the maxium load that the tire will actually see. For example, if the maximum load for a particular tire is 1500 lbs, and the maximum pressure is 50 psi, then you would use 25 psi if the tire sees only 750 lbs (half the maximum pressure for half the maximum load). It's not quite that simple, but that gets you in the ball park.
If you want to check your footprint, take some chalk and make a line across the width of the tread. Then drive the Jeep a little ways and see if the chalk wears off evenly across the tread. I've never gone to this much trouble, myself. I just go by the way the Jeep handles and rides. I pay attention to how the tread is wearing after some time has gone by.
Tom
I was really amazed at the difference in the ride and handling when I was over 30 psi. It was AWFUL! I kind of arrived at my 28 psi by trial and error. I like the feel at 28 psi, but I have never tried lower, as you suggest. Might just have to give it a try.
There's not a heat build-up issue at highway speeds with that lower psi range?
Tom
James
I don't know what it's gonna take to get people to start buying new vehicles again.
I was back at the dealer yesterday, and it was deader than four o'clock the whole time I was there. They let me use their clean up shop to wax the Impala, after they did the clean-up they owed me. I was there from about 10:15 AM til 3:00 PM, and I don't think they had more than one or two customers that whole time.
When people can get up to $8K or even more off sticker price and have the advantage of today's low interest rates, why in the world wouldn't they go ahead and buy?
Tom
Also, you can get a factory original service manual at http://techauthority.daimlerchrysler.com
They are only $6.00.
Welcome, James. Guess this was your first post, right? Glad ya joined us!
Tom
I hope that everyone's holiday went well.
Tom, congrats on your super deal!
I have successfully installed my full-size CB into my center console, with only a small modification (or removal) of the white plastic liner. It is lockable, out of sight, and I can still easily hear the truckers telling me where the smokeys are sitting.
Question:
My '01 Wrangler Sport has a tag on the coolant bottle that says it takes a special coolant. Before I ask the parts guys downstairs and I get a wrong answer, does anyone know why it takes a special pink coolant and is there a non-mopar brand available?
-Bill
PS pray for snow in New England and for the Patriots to stomp the Buffalo Bills today.
I got some of those Commit lozenges, and I hope the work! I got the high-powered ones, the 4 mg size. I told some of my buds in Gill's that I wish they had an IV version of them, and I would have one in each arm, plus the lozenge in my mouth. And, if they had a suppository version, I would have one of them too!
One of my buds in Gill's is going to quit at the same time, so we will have each other for moral support.
Wish me luck!
Tom
Glad ya got that CB mounted.
Tom
Bill - did you mount the CB under the radio in the dash? Do you have a 5 speed or an auto - wondered about interference with a 5 speed.
James
I'd think the the dome light fuse would be the least of your worries. How bad is this totalled Jeep of yours?
Also, someone could have disabled the contact switches in the doors to keep the light from being on while the doors were off. That would be silly, since pulling number 4 fuse would have accomplished the same thing, but some people do things the hard way.
Tom
James
I don't have the subwoofer in the center console, so there is lots of space in there once the white plastic liner was removed for my big (know it works) CB. The liner not only holds your small items, but protects the e-brake mechanicals. I riveted the CB's mount to the inside of the plastic console and ran the mic wire through the e-brake's brush covered access slot. I do have to make a box of some kind to regain some storage next to the CB inside the console.
I plan to borrow a co-worker's digital camera next week so I may have some pics of my Wrangler (& CB install) shortly.
-Bill
PS The Patriots won! 31-0 over the Buffalo Bills!!!
According to the factory service manual, any ethylene glycol based antifreze that has organic rust inhibitors is OK.
The factory stuff is supposedly good for five years or 100,000 miles. NO WAY! At least I ain't gonna leave any coolant in any of my vechicles that long!
I'll just use good old regular antifreeze that meets the requirements above and change it every couple years. I have already changed Thelma Jane's coolant once. Just went with Prestone.
Tom
Heck, you might even decide that you can live without the soft top, once you have owned the Jeep a while.
It has worked out well for me having just the hard top, but Thelma Jane is not my daily driver. I can leave her top and doors off for long periods and drive my S-10 when it is raining. I have a garage that I park Thelma in, so no problem leaving the top and doors off just about all summer.
Let us know how all this turns out! Sounds like you are close to a deal!
Tom
You could easily be happy with just a hard top and a bikini or safari top - I know others who go that route. That's what I would probably do if I had a garage. Since I don't, the hard top has never been off mine.
Bill - thanks for the details on how you mounted the CB. I just mis-read your original post, and was thinking you put it in the dash, not the center console. Guess it's another "senior moment." I would like to see the pictures when you post them.
I have posted a few times over in Impala, and although people have responded, they have been very slow about it. When I go back just a page or two to read old posts, I find that the posts are dated in November or even back as far as October.
Now that Impala is a real nice car, but it certainly is not as much fun as a Jeep! I guess that's why there is so little posting going on over there.
Tom
Gotta love those FUN cars!
To describe a Wrangler as merely 'nice' would be an insult.
Wranglers are exciting the whole time you own them! Believe me, I have owned virtually every other type of vehicle, and their excitement factors were very short-lived. Thelma Jane, however, continues to be a source of joy and excitement to me after three years.
Tom
Jeeps. . .they go where Impalas fear to tread.
You can do a search for 303.
That was in 1985 and about 100 pounds ago. At least I blame giving up cigarettes on the weight gain and I am sticking to that story.
Could not afford to smoke at the prices they get today. Was a really heavy smoker in my time, always 2-3 packs a day and while in Spain was up to 5 packs a day. I was a chain smoker to say the least.
Who is the other person that is kicking the habit? Best of luck to both of you.
Don't hang out in the bars like you normally do and it will be a whole lot easier:)
I still consider smoking a good cigar every now and then.
Still a happy camper,
I also go to the LS board and it is kinda slow there like your Impala board.
Pepe' has the split radiator problem (dang plastic radiators). Out of warranty and dealer wants about $500 for a factory (plastic) replacement. My local jeep specialist is going to do an aluminum radiator replacement for about $350 so I think that is the way to go. Pepe' has been drivable as it is only a slow leak but I am getting fluid all over the underside (and it smells).
Have a great new years everybody.
How come we never see you in Gill's any more and hardly ever hear from you here either? Still workin' crazy long hours? Tell Jean hi from me and Ross Allen.
Tom
Well, I got my mirrors mounted today. Man, what a job! I didn't realize that the windshield would have to be lowered and the dash unbolted. But now that they're on, they look great.
I wish ya luck man. We all can be your moral support. I need to loose 15 pounds, so i guess we can help each other.
I know what you mean by slow boards, ive posted on the Nissan board a few time. WOW they must be asleep over there.
Well, some of you know that I work for my in-laws in thier BBQ restaurant. Well, they are retiring, my wife & I are taking over. So, I will be self-employed.
Hope everyone has a safe & happy new year.
Keep Jeepin
Bama
Hope you will be posting some pics of that baby?
You are gonna LOVE that Jeep! You probably ain't gonna be able to sleep tonight, huh?
Be sure and post tomorrow night and tell us all of your first impressions.
Tom
bama - Should I say congrats or condolences? Sounds like a great opportunity, but now it is all yours, sink or swim. I think I prefer being a small cog in a huge organization. Of course, I could easily find myself out of a job at any moment. But since it won't happen next week (we are shut down between Christmas and New Years for the first time ever) I'm heading for the Sierras and the Gold Country. Don't know if I'll have access to a computer, so everyone have a happy and safe Jeepin' New Year if I don't.
CONGRATS on being a restaurant owner! I'm gonna HAVE to get down there for a meal "on the house."
Tom
I love BBQ; may have to resolve to hit your place Bama. I manage to drive through Birmingham every couple of years, so maybe you better put my name on some chopped shoulder meat :-)
Looks like Wrangler welding is going to be farmed out to suppliers:
Pact allows DCX to move work from Toledo plant (Detroit Free Press)
Maybe that'll Rescue some more sales that otherwise would have gone to the Hummer. (Get the joke, Embeeduece?)
Stop by here on your way to b'ham and get me. We'll BOTH hit Bama up for a free meal!
Tom
Since I usually start from Chattanooga you'll have to meet me at the base of Lookout Mountain. I used to take my CJ-5 to an abandoned strip mine north of there - maybe we could still find it!
(I'll buy the ice tea at Bama's)
