Mitsubishi Galant Maintenance and Repair
I don't want to be duked when I go to the repair shop. Yesterday I noticed a pan like object that was hanging from underneath my car. I was like in the middle. I was able you quickly wiggle it off. My car is driving fine I have pictures of the part that came off can anyone help me identify the part. sorry there is no place for me to post the pics.
:confuse:
:confuse:
I have a 2000 Galant which I have an intermittent problem. It does not want to idle as I release the gas it will drop RPM and stall. I can keep it at idle with the gas pedal but if I move my foot it dies. The check engine light has now come on also.
Strangely it will work perfectly one day and the next Ahhhh!
Any suggestions??
If your car is driving fine, I'm going to put forth a wild guess that the part was a heat shield and won't adversely affect vehicle operation. But I, and others, can't really be more helpful without a pic or detailed description of where the part came from, how it was attached (bolted at corners, etc.), if it appears to hold in fluids of any kind (probably not since the car is still drivable).
I haven't heard of many issues with Galant transmissions and I never had a problem during the 10.5 years & 152K miles I had my '99 Galant. Come to think of it I can't recall reading any posts about AT issues.
Some questions:
How many miles are on the car?
Has the trans fluid been services as outlined in the manual?
I'm not an expert so I'd hesitate to speculate on the problem. If the fluid hasn't been changed it could have seized or burned. But it could just be wear & tear. Should it be shot, Galant's of that generation ('99-03) were good sellers for Mitsu so you should be able to find a rebuilt trans for a reasonable price.
Similar thing happened to me at around 110K on my Galant (a 2001 with 160K and still going strong :-) ). At around 60 mph I heard a "whoosh" from under the hood and the car slowed down; the "check engine" light came on. I took it to the dealer and after they read the code they told me that the car "slipped" out of gear. Less than 8K prior to that I had done a flush at an indy shop that used what I believe was a generic with additives to bring it up to Mitsu specs.
The dealer mechanic suggested a flush with the hope that no permanent damage was done and see what happens. I was lucky and never had an issue ever since.
Bottom line, as confirmed later, the Galant transmissions are picky, so NEVER use anything but the OEM Mitsubishi AT fluid.
Bad gas is easy to diagnose: Run a couple of tanks of Premium from a Top Tier brand (http://www.toptiergas.com/retailers.html) to see if the idle smoothes out.
Other thoughts: Dirty air/fuel filters or spark plugs past their prime.
Does it every actually stall?
You might also try taking to a shop that'll read the engine codes for cheap or free; it's possible the engine's computer is logging a fault condition.
