Visitor Agreement.
Can't really comment on whether or not it will fit in an unlimited, but I know my golf clubs fit in the back of my jeep with the back seat tumbled forward. I had to put it in there in an angle, but I could have easily layed it side ways with the clubs resting on the tub of the jeep. Hope that helps some.
des'
-Paul
His Jeep is on its way to Huntsville, but it won't be there in time for this weekend's wheelin', unfortunately.
Tom
Have you hugged your Jeep today?
-Paul
-Paul
-twylie
-Paul
-Paul
Note to self: try not to give Mac any material for jabs :-0
-twylie
Thanks in advance for any help! Still lovin' my Jeep!
Check for coolant flow through the heater core by holding the feed and return hoses, which should both be hot. If they're not, you could either have a blocked core or an airlock.
If they're both hot then the blend door is either stuck, broken, or you have a problem with the switch, motor, or the associated wiring.
Seriously, hope you do as you say you will, and become active in the group. It's good to hear from you.
Tom
P.S. Let us know what the problem turns out to be with your heater. What would we do without the Old Macster around here???
I just want to be able to give people the right info when I am trying to help someone buy a used Jeep.
Tom
I really love my Kermit, but sometimes I just wish I had that 4.0 and D44.
-Paul
The problem appeared to be one of thermal stress. The fix is a new 'header' style manifold, similar to the original, but with bellows on the #1 and #6 tubes to allow for expansion, which seems to have been generally successful.
The 2.5 rarely had problems with the manifold itself, but early ones suffered a lot with broken studs, which would shear off in the head. This was generally covered under warranty.
Terry
'00 models don't seem to have any particular problems you need to especially worry about. Just keep it properly maintained and serviced.
Actually, the only real issues I've had since I took possession of it are:
1 - Manifold fix
2 - Catalytic converter became a maraca and rattled every time I drove it.
3 - Leaky radiator - another known issue
4 - Wacky fuel gauge - not enough to worry about
-Paul
As measured by the roadside radars, my odometer reads about 6% slow (28 actual at 30 indicated) so that part is not a concern.
-Paul
des'
I didn't measure mine, but to get the bar diameter, you could always do Circumfrence/3.14 = d for a close approximation.
These are the grips I have and they work very well: http://www.raingler.com/shop/productDetails.asp?productID=5
HTH
-twylie
-Paul
If you installed it, did it mount outside of the tire carrier so that you have the sheet metal, then the carrier, then the mount?
Since I'll be wheeling at TB, I have to worry about that. Not so much of a problem in the deserts of soCal eh?
-Paul
jeff
not looking forward to the 2 1/2 hour drive to my parents today. not that i worry about my vehicle or driving, its those other nuts on the road during the first snow,, and everyone in a hurry to get to their grandmothers' houses.
The heater in the Unlimited does quite well when the temps are in the 20's. Yes, Paul, that's what it's been the last couple of mornings. And even in the mountains the overhead clearance isn't as important as the side-to-side brush clearance, even in the mountains.
des'
I have no doubts about the width for Jeeps.
In other words, I'm worried about the antenna/mount being so stiff that the sheet metal is the easiest part to flex/bend.
With the rain we've had here, I'm really wishing I had the Jeep today, instead of our sedan. Some of these puddles are getting really deep and the Jeep would be more fun to drive through them with! hehe
-Paul
TJ's with no lift can handle 31 x 10.50 tires on the factory wheels. Your backspacing should be five to five and a half inches on those factory wheels.
If you are unfamiliar with the term "backspacing," just type that word into the search window. You should find one of my posts with a diagram that explains backspacing.
Some folks find it necessary to install a washer or two on their steering stops with the 31 x 10.50 tires to keep the tires from rubbing on the control arms, but most people don't. It's no big deal, if you do have to install the washers.
Tom
Terry
My end pieces are still the plastic, so if they do go, I'd end up getting the endpieces from Quadratec. Those pieces are pretty much the same from any online vendor (JCW, 4wd.com, etc).
-Paul
jeff
Tom
Get the job done, and then come home safe and sound!
Tom
I'll be staying in a motel about 20 miles from Turkey Bay with some of my Jeep Buds from Alabama. I have folks driving over 8 hours to wheel with me!
Now, does that make a certain individual who could be here in about five hours feel bad because he has not made it down here yet? Said person could be wheelin' this weekend with me, if he would just hop in his new, red Unlimited and drive it down here. Who is this masked man that I am speaking of??? Why, it's the Loan Arranger!
Tom
