Glen
Kevin
As far as the cooling performance of the system, it seems to be working great. The new rad does let everything run a little cooler than the old OEM one, but not so cool to make me think the thermostat's stuck open (which is a new one). I think it's either a broken "flapper" inside the blend valve or perhaps some trapped air still in the heater core or lines which no one has been able to burp out. I guess I'm looking for some "eureka" event from Mac or someone based on my synopsis. Sorry it's taking me so long! On the other hand, Tom asked me to report back, and this a great group of Jeepers, so....?
Any ideas? (I really prefer to resolve this on "my own" with your help!) I know the dealers' kids gotta eat too, but there's this whole concept of the Wrangler being a simple vehicle and all..... Thanks!
If both heater hoses are getting hot then the heater core must be hot, therefore the problem is that air isn't being sent through the heater core. The most likely cause is that the blend door isn't functioning, but I guess there might be a dead possum in there. I think a blend door malfunction would head my list though.
Good luck!
If your radiator hoses and hoses going to the heater core aren't getting hot, you can either test or replace the tstat to see if the problem moves in the system. Here are the troubleshooting items I found for no or poor heater performance.
INADEQUATE HEATER
PERFORMANCE . THERMOSTAT
FAILED IN OPEN POSITION
1 . Has a diagnostic trouble
code (DTC) number 17 been
set?
2. Coolant level low.
3. Obstructions in heater hose
fittings at engine .
4. Heater hose kinked.
5. Some models with certain
engines are equipped with a
water control valve located on
one of the heater hoses . This
valve maybe defective.
6. Water pump is not pumping
water to heater core. When
the engine is fully warmed up,
both heater hoses should be
hot to the touch. If only one of
the hoses is hot, the water
pump may not be operating
correctly. The accessory drive
belt may also be slipping
causing poor water pump
operation .
resolution:
1 . Refer to On-Board Diagnostics in the
manual text and replace thermostat if
necessary.
2. Refer to Testing Cooling System for
Leaks in the manual text. Repair as
necessary.
3. Remove heater hoses at both ends and
check for obstructions. Repair as
necessary.
4. Locate kinked area and repair as
necessary.
5. Refer to Group 24, Heating and Air
Conditioning for diagnosis . Repair as
necessary.
6. Refer to Water Pumps in this group.
Repair as necessary. If a slipping belt is
detected, refer to Engine Accessory Drive
Belts in this group. Repair as necessary.
Sorry to hear about your problems and I'm sure you'll track it down soon (through process of elimination if nothing else :-) )
-twylie
Blake
Yup, I hugged my Jeep today (it saved my [non-permissible content removed]!)
Marcus
New aftermarket bumper, hmmm...(slyly rubbing chin).
Marcus
You might also want to check out the tailgate more thoroughly. It's quite common for it to be badly damaged after the spare takes a hit, it just doesn't show until you take the wheel off.
Glad you are okay, but like mac said, get yourself checked to make sure all is good. Those neck injuries have a way of coming back to really hurt if you're not careful.
-Paul
You're right, I suppose it could be kinda caved in behind the spare...I'll have to pull it this weekend and take a look. I've already got an appointment to go to a claim center on Monday to get it evaluated. Even if my tailgate's toast, I still made out way better than that Cavalier did! ;-)
Marcus
When they got the weight off the front end to do the alignment, the guy grabbed the left front tire and shook it. There was a BIG TIME wobble, which means the hub bearing is shot. The bearing is integral to the hub assembly, so no such thing as just changing out a bearing: the whole unit must be replaced.
Guess how much that part lists for? I checked with the DC dealer that I do business with, and the parts guy said the list price was $305!!!! The Autozone price was $329. I always get a discount at the dealership, and the parts guy told me I could get the part for $225. I told him to go for it, but he has to get it in from a warehouse in St. Louis. Might have it as early as Tuesday.
I'm not going to whine about the part failure, after all the miles Thelma Jane has seen on the trails. She Jane is only four years old and has only been off roaded during the last three years. I go virtually every Saturday, so Thelma Jane has as many trail miles on her as most ten or fifteen year old Jeeps!
I stay out of mud and water whenever I can, but it cannot be totally avoided at Turkey Bay. I'm sure water and mud have a lot to do with that bearing failure.
It was so nice of that parts guy to discount the part that much for me. It's not like I buy thousands of dollars worth of parts or anything.
You see so many negative posts about car dealerships, but I have been well treated at two or three different places. It's just a matter of establishing a good relationship. If you go in with a chip on your shoulder, you are probably not going to be given the best of treatment.
Tom
Have you hugged your Jeep lately?
One of the reasons I called my '98 Sport my Noble Black Steed is that something along those lines happened when he was about 6 months old. My other half was calmly driving, minding our own business in the carpool lane. A compact pickup tried to change into our lane right in front of us - I'm sure he didn't look. The Jeep climbed the curve on the wall (I thought we would roll but we didn't - my other half did a great job of keeping the wheels straight) and we scraped both the wall as well as the pickup. We drove away while the other guy had to wait for a tow truck (of course, the other guy's insurance ended up having to pay over $4,000 repairs - all of it just body work). Wranglers are very tough vehicles.
Mac, or anyone else who has some knowledge on the subject, are they most likely getting as high quality as original equipment? Who is the supplier for the OEM hub?
I checked Autozone, remember, and they wanted $329.99. I will have to review those posts again to see where people are getting those low priced hubs.
Also, a Jeep Bud talked to a guy who deals in auto parts, and that guy said he could get my a hub for about $130. According to THAT guy, the hub for a 98 Grand Cherokee is the same part as for the 01 Wrangler. The price is MUCH lower for the Grand. Guess that happens a lot? Just gotta know which parts are interchangeable and ask for the cheaper one???
Does anyone know if Timken HA597449 (01 Wrangler) is exactly the same part as Timken 513084 (98 Grand).
Tom
Have you hugged your Jeep today?
Are either of those as good as the OEM part? Does Timken or BCA supply DC with the OEM parts?
I R CORNFUSED!
Tom
Now I R REALLY CORNFUSED!
Tom
P.S. The above doesn't make sense without putting it with the previous posts, so let me explain.
Part numbers HA597449 and 513084 are both made by Timken and are both listed for the 2001 Wrangler front wheel bearing. So, Timken makes two part numbers for the same application and uses part numbers HA597449 and 513084.
Personally, I'd opt for the cheapest and check it more often than you have been doing. That will give you a benchmark to decide what to do when your other one goes (and trying to keep out of mud and water will help too!).
Feel free to expound more on that part number/price issue. You think the VERY SAME part can be had for about a third of the list price of OEM?
Tom
On the bright side, the front bearings usually last a lifetime unless you contaminate them.
3.5 RE Suspension Lift
1 inch BL
Shrockworks Rocksliders
33x10.5x15 BFG ATs
That puppy sure looks GOOD! And, she looks like she is READY FOR TURKEY BAY!
So, when you gonna bring her down here????
Tom
jts
While it wasn't much of a test, GiGi handled the snow covered streets of my subdivision this afternoon. There's about an inch or 2 of snow here and it is SO beautiful! The road didn't seem icy at all, just a little snow covered, so there was good traction. She didn't even wiggle her tail at the spot that is often icy. It'll be interesting to see what conditions are like tomorrow morning, though.
I notice Warn has to housing types. One has everything in a nicely shaped housing. The other has a separate box-like thing. What's the difference between the two?
Also, what kind of line and what kind of fairlead would ya recommend?
-Paul
I have canceled my order at the Jeep dealer and ordered one at NAPA. I can get it for $139.95 instead of $225!!!
The NAPA part has a lifetime warranty, so how can I go wrong?
Thanks, Mac, for you input!
Tom
How many winches do you want to buy in the next 15 years or so?
I bought the 9.5 Ti not because I needed 9500 lbs capacity, but because it is so well sealed against moisture and so well constructed that it should last a lifetime. It was reliability that I was after.
I figured I might as well spend the bucks for a good one and then be done with it.
Tom
I think the 9.5 has better water protection, but how 'bad' in comparison are the other models?
-Paul
I went by what was being said in Jeep message boards and by what little understanding I had about the differences.
I'm sure an 8000 would be a good winch too, and it would probably last a long time also.
You could go to Warn's website and read about the different models.
I just liked the looks of the 9.5 Ti, it was the "latest and greatest" model at the time of my purchase, and it was getting rave reviews.
I did like that thermal indicator feature that warns you when to stop pulling before you burn up the motor. Not having any prior experience with winches, I just thought it sounded like a good feature to have. I mean, come on, shouldn't a Warn winch "warn" you????
Tom
So in respect for my other half, I want to add it, but keep the expense such that it won't blow her away when I get a winch. Tough for me to justify the higher price winch right now. I guess I need to get edjamakated before I decide anything!
-Paul
Tom
-Paul
You can find it, just think of where Jeep parts would be.
-Paul
I check it almost before I check retailers.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1- &item=7938758818&category=33716
here is your brake light assembly, if you want to save a few bucks on shipping I'll be most sellers would take the lens out and throw away the rest if thats what you want.
there are several others, none have bids on them, you must be the only person wanting one, seems like anytime I want something, so does everyone else.
jeff
Do covers protect them or do they trap moisture inside?
Jeff
If its ok to leave my winch outside unprotected, can can I leave my blender & toaster outside too, I'm running out of counter space?
I think the concern is more about submersion of the winch than exposure to weather.
Tom
Have yuo hugged your Jeep today?
-twylie
-twylie
twylie, you always seem to come through, just like Mac and Tom. I know we tell Mac this a lot, but let me tell you that I appreciate all you do to help this group from advice, to parts, to whatever. Your insight has helped me on countless times and I just wanted to express my gratitude for it.
-Paul
Sorry, but I don't have the info you need, but I didn't want you to think we ignore people around here.
Someone will be around to help you before too long, I guess. Maybe none of us know the answer, so you might just have to "test drive" to find out.
You'd better be prepared to have FUN like you have never had with any other vehicle, if you get a Wrangler!
Tom
