Bought our car with 32000 miles, first had spark plug/coil problems(we relaced), then the acelerating problems (that no one can diagnose), then violent vibrating-struts are being replaced (in a 39,000 car!) as we speak. I only googled to see if there are recalls. Now I am scared-what is next?
All the best,
Sarah
GM Customer Service
Thank you all for posting what you have tried and what has worked. It is a great help.
Did you have any luck resolving the wind noise concern on your Aveo? Also, I saw on another post of yours that you may have some recall questions - we're happy to check into recall information for you. Please email us the last 8 of your VIN at socialmedia@gm.com
All the best,
Sarah
GM Customer Service
I was able to drive the car back home at a slow speed.
I got the car to my dealership and they have had the car ever since. The first week they ordered a speed sensor and a manual/park switch. After installing these parts which the mechanic thought would be covered under the powertrain warranty they took it for a test drive but it still would not go into overdrive.
Thats when they decided i did not need the manual/park switch so they removed it. Thats when they told me it wasnt covered under the powertrain warranty. I then needed a radiator as transmission fluid had somehow got in it and ruined it. (the dealer was paying for the radiator) And they had to order a gear which was going to be covered by the warranty. They had no loaner cars and i had been on foot for a week so they rented me a car from Enterprise. That was over a month ago. I have called the Dealership several times. They tell me the part is a genuine GM part but is out sourced. I could have gotten it here faster by a rowboat. GM Customer Service used to call me a couple of times a week but not in the last 2 weeks. The Dealership has treated me really nice but i would really like to have my car back. Havent seen any other posts about the Aveo needing a gear or overdrive going out with the speed sensor. Just sounds like something hokey is up with my car.
We appreciate your continued patience on this and are sorry to hear that you have been without your Aveo for so long. If you had wanted to send us your case number (71-**********) to socialmedia@gm.com, we can check into it to make sure that we're doing all we can on our end in the meantime.
Kindest regards,
Sarah
GM Customer Service
All the best,
Sarah
GM Customer Service
Sarah, GM Customer Service
