BMW Service Questions
I have 2008 335xi with 27k miles on it. Cars warrenty and maintenance will expire in net year. I am debating if its worth for me to buy extended warrenty and maintenance plan.
Car aleady had its fuel pump and injectors replaced so I am not sure whats the long term reliability of its car. Dont know if I do regular maintenance will the car will be trouble free .
German cars are quite expensive to fix after warrenty
As far as electrical issues go, the X3 required a passenger SRS sensor(replaced under the new car warranty) and one brake light bulb.
I replaced the battery on the 3er at 10 years/101000 miles as a precaution and 5000 miles later it needed a brake light switch(a whopping $30!).
At 114000 miles I had to spend almost $13 to replace the miniature bulbs in the headlamp and fog lamp switches. I think I also replaced a couple of tail lamp bulbs.
Bottom line: The electrical "issues" on both cars have cost me a combined total of nearly $200.
Since I had my tires rotated and balanced about 6 weeks ago, my DSC has been acting up. First, it was coming on once a day. When it kicked on I would hear a noise (click?) in the engine, car would kind of pull, but then drove fine but light stayed on until I turned car off then on again. Then after a suggestion, I checked my tire pressure & they (Tires Plus) overinflated my tires to 40. I deflated them down to about 30 where they should be about at, then the DSC was coming on about once week, or at about 100 miles. Then for the last 3 days it is coming on again more frequently. Half of the time the light just comes on w/ no noise/slight pull (ie indication it is coming on).
As a side note, I had some engine work (spark plugs, coils, tune-up) done on the car about 1 mo ago and they did full diagnostics and module did not show any error codes.
Any suggestions as I'm not looking to put much more into the car as will be getting rid of same w/in the year.
thanks!
Though it's not officially in the program, BMW has allowed low-mileage drivers to have their oil changed at the 1 year mark, even if they haven't reached the oil change interval... Rather than re-setting the system, they just get an additional oil change, and then have it changed again when the indicator calls for it...
That scenario fits perfectly with what you report.. At one year of service and 11K miles, the car's oil was changed.... then again, at the regular service interval of 15K..
It's all good!
regards,
kyfdx
E30 engine series 1.8L, 4-spd automatic trans, DOCD car that keeps overheating. I have a brand new radiator (install by a certified mechanic shop, but couldn't afford to have them work on it after that), I also needed, so I bought and install, a brand new fan clutch. Now here's my question, I have bought 2 thermostats, one from O'Reilly's Auto Parts and one from a specialized European Automotive shop. Both places gave me a thermostat that opens up at 192 F, with the specialized shop insisting they were giving me the right thermostat, an OEM part. I told them that my car requires one opens up at 176 F, but they still insisted that I was getting the correct one. Could installing that thermostat cause my car to still overheat, fairly quickly? Also we checked the waterpump and and it appears to be good, but were not sure. Oh, also the hose going from the tank is cool, but the return hose going back to the radiator was steaming hot after I test drove it and the temperture read hot in the red zone. Thank you, Shelly B.
Given the age of the car, and being a 318, you'd best check for a bad head gasket, too.
But sure, let's hope that's not it. Seems like an air block would cause his temp gauge to move around alot.
A simple pressure test should solve this problem. Pressurize the system, then while holding the pressure, remove the spark plugs one at a time. If you see coolant on the tip of any of them, there you go.
And if we add in the inherent weakness of the cooling systems of most 3-series in the 1990s, one has to at least be suspicious of overheating stresses, as you pointed out.
