2012 Subaru Impreza
1192022242532
  • hcalcathcalcat Member Posts: 30
    What are your settings for bass, mid-range and treble? Are you keeping srs on? I have a tin ear so I could use some help from an audiophile.
    On another note, I filled up for the first time today and averaged 26.9 mpg in 60/40 city/hwy driving. City driving was mostly short trips. Went 339 miles, took 12.6 gal, and one bar left on the fuel gauge.
    I reset my A odometer while I was filling up and after I started my car, my fuel gauge only registered half full. I had to hold the reset button down for about 3 seconds and watched the gauge move slowly to full. Guess you shouldn't reset until you've filled up.
  • wimchattawimchatta Member Posts: 28
    this is a cool find, bob!
    Wonder if I should try a backup camera, or still stick with the plan to install an ultrasonic backup sensor array.
    The car should be in this weekend, looking forward to it!
  • kanjiikanjii Member Posts: 99
    Sounds like Star Trek =)
  • bobdole888bobdole888 Member Posts: 38
    I heard confirmation from the other impreza forum that the non-nav head unit in the limited model is ready to go for rear view camera.
    There's a adaptor harness available that hooks up to the HU and provides a composit video input. After market camera can be used to hook up to the composit video inuput.
    HU will automatically switch to camera view in reverse.
    Though the wire from back of the car to the HU is not in the car and needs to be installed by an installer.
  • iliketoshiftiliketoshift Member Posts: 24
    Ok, but where would the non-nav HU output the video to? My guess is that they may have left that menu item in the firmware but there's no output device. In fact if the non-nav HU had the video chip depopped, there's no avenue to upgrade this. Someone can tear open the two head units and see where their common hardware is.
  • dfong87dfong87 Member Posts: 171
    if that's true, that would be really cool. i imagine someone creative or adventurous will try this out. :)
    any takers? seems like a lot of folks on NASIOC might be willing to explore this :)
    hcalcat: can't say i have definitive recommendations. i always have told my friends to trust their ears. if it sounds good to you, then that's what you want it to be! (usually in reference to buying stereo equipment). everyone's hearing is different.
    that being said, i only did a quick and dirty adjustment and i think, a couple minutes of listening (seriously, i haven't done much on this), i set the bass at +2, treble and +4 or +5, and kept the midrange flat. if i have the chance, i may play some more, but overall, the sound is much better than it was. i still think it was inferior to what i had in my Honda Civic (again, nothing super fancy: a 14 year old minidisc deck by Sony ($400 on the time but that's because it was MD) with 3way Pioneer Premiere speakers in front and Eclipse in the rear -- probably $300 worth of speakers).
    i digress: for me, at least for now, good enough. before Bob's suggestion, i really was looking into what others were doing about replacing the head unit. now, i think i can probably live with the head unit and if i wanted to do anything, i might look into upgrading the speakers in the doors. but given i'm already being driven nuts by an intermittent rattle/creak in my steering column, i'm reluctant to introduce any more possible extraneous noises to my car. that would be not worth the upgrade in sound quality. :p
    edited April 2012
    "Ok, but where would the non-nav HU output the video to? "
    As I pointed out in my earlier post, the camera video gets displayed on the 4.3" LCD screen on the non-nav HU. I have been able to get into the secret menu and show the camera view which is black screen without the actual video. However, you can see in that view that the distance markers are present on the screen as well as the warning message "please check surrounding before backing up".
    so, filled my first tank up: average speed was around 22mph which i can best say was half highway and half city...maybe more than half city (suburban SF Bay Area in CA).
    computer read 30.0mpg
    hand calcs gives a 29.1mpg (300 miles and 10.29 gal at click).
    overall, not too bad though and if it goes up by 1-2 mpg after a few thousand miles, i'll be satisfied. this is about the same mileage as i was seeing in comparable driving with my 2000 Honda Civic Coupe. although perhaps slightly lower because i've been keeping my highway speed at 65mph or less for this break in period (i didn't drive much faster, but i would say i typically drive 70 or below normally).
    i still see the mileage as horrible during my morning commute to the train station or during the first 3 miles of driving. i know that's true for most cars, except that i'm guessing (i didn't have an onboard computer) that's worse in the Impreza with the 5.3 qts of oil to warm up. my wife's prius gets 25 mpg or less during the first 1-2 miles, and then it seems up to full operating temp (oil wise) and it's mileage is up to its usual 50 mpg range.
    i think long term, i'll have a better idea about the inaccuracy of the onboard computer. it seems people have reported a 1-2 mpg overprediction. funny how psychologically, 30 mpg sounds so much better than 29 though!
    i have not, however, compared my odometer to a GPS yet. the speedometer seems about right whenever i go buy one of those radar check points (at least up to 35 mph), for what it's worth...
    Thanks, dfong. I'll start with your settings and then monkey around with it as you suggest.
    I also have an intermittent rattle that I only hear when I hit a bumpy section of road. Not sure what part of the dash it is coming from.
  • skid0skid0 Member Posts: 16
    The fuel gauge doesn't require you to hold the button. All fuel gauges are damped, so you don't see the needle bobbing around when you corner/accel/brake. It will rise all on it's own. :)
  • oakleafoakleaf Member Posts: 1
    Got my 2012 Impreza Premium last week and had no problem setting up bluetooth for phone and audio (iPhone 4s). A week later, phone is fine. Audio streams fine, but the hands free buttons to advance the song tracks (on steering wheel and console) no longer work. If I hard wire connect the phone via the USB port, the buttons to advance tracks works fine, but not when streaming via bluetooth. I have deleted the audio device twice and paired it again. Same problem. Any ideas?
    i played a little more today and i think +2 bass, +4 treble is about as good as i can get it.
    one thing i haven't explored is turning back on the loudness. theoretically, that is meant to bolster the low end at low volume levels, but i'm guessing that won't be good since when it was on (in conjunction with the EQ setting) it was just plain boomy.
    overall, i think it's acceptable now. not great, but much better than it was with EQ and loudness enabled.
    as for rattles: with the warmer weather, my steering column rattle has temporarily gone into hiding. i thought i heard something new in the passenger seat at one point today, but that was only shortlived.
    i'm trying to stop focusing on looking for extraneous sounds, but somehow my ears are drawn to it. :p
    For those of you really bothered by the audio control lockout while driving, there is a workaround.
    However, it requires opening up the panel above the stereo and cutting a wire.
    There's write up on this at the other Subaru forum.
    If I do proceed with the rear view camera install, that's something I'll do at the same time.
  • xwesxxwesx Member Posts: 18,192
    Interior rattles and "Subaru" are synonymous. I think they're getting better, mind you, but if you have only heard a couple intermittent ones thus far, you're doing well!
  • birdadlybirdadly Member Posts: 10
    I'm new to remote starters, but REALLY wanted it my next car, which is now a Limited Impreza. Cutting to the chase, I was surprised to learn just how this one works...
    I use the remote start and it automatically locks the doors when started. I unlock the door and the engine stops. I then have to use the key to restart the car. The dealership said too many people were burning out starters by turning the key too far when the car was already running.
    Does this sound about right? I think I might be more reluctant to use it now which is unfortunate.
    Here in Fairbanks, "auto starts" are extremely common. I think once people get used to having them, they generally don't accidentally attempt to start their already-running car, but yes, it certainly happens frequently during the transition!
    I don't see the problem with the way yours functions. If the point of starting the car early is to heat or cool the car before you occupy it, having it shut off when the car is unlocked seems a minor thing in the grand scheme. Unless, of course, you unlock it without the intent to get in and drive away.
    ha ha. thanks for the reality check. i know all cars can potentially have them, but they are something my brain is unfortunately hardwired to notice. hopefully, this car will train me better. :D
    I know what you mean. My 2007 Outback about drove me insane. The dealership fixed many of the rattles under warranty, but others evaded all attempts at remediation. I don't mind rattles on an old car but have no tolerance for them on a new one. *sigh*
  • mrgoodwrench70mrgoodwrench70 Member Posts: 8
    Getting ready to order a sport premium in Pearl white, got it for $21,126 with Homelink Mirror, Cargo tray, and cargo net.... includes PZEV and shipping... out the door with tax and tax =$22,128... I think that' about $300 under invoice.. Pretty happy with internet dealing....:)
  • ericspyderericspyder Member Posts: 33
    Look like your tax only $1000. How many percent of tax in your area?
    Someone in Bay Area, CA got $21,200 for Limited with homelink mirror + tax and doc. fee. But we have 8.25% on sale tax. Thnak you for sharing.
    Tax runs about 3.1 %.... Just got another offer a few hours ago from another dealer in Richmond , VA.... Impreza Sport Premium CVT PZEV, homelink mirror,cargo tray and net for $20,600 + tax and processing and tags = $21,831 out the door.... I love it when dealers compete with each other... :)
    I am finally starting to see the new Impreza with regularity, so the proliferation has begun! I'll have to go check them out soon, then compare to the XV when it comes around this fall.
    sounds like a really good deal, IMHO. i'm jealous of your lower taxes. TTL is about double what you are paying in CA (since Sales tax is over double where i live)
    i still haven't seen one yet in my area, and this is the SF Bay Area in CA! actually, that's not quite right: i saw one sedan, but i haven't seen any hatchbacks (what i own) yet.
    I own a hatch, but you probably won't see me since I am in the east bay...then again, I may head to SF for the J-town Cherry Blossom festival this weekend :P
    Subaru is a popular vehicle choice here (Fairbanks, Alaska) due to the all-wheel-drive. I think I have seen at least a dozen different vehicles (owing to the color, body style, or both) in the past two-to-three weeks, but didn't hardly see them at all prior to that.
    ;) won't be up there, but have fun! i'm sure we'll see more in time. if they are flying off the lots as has been suggested, its just a matter of time that we start seeing more.
  • jd_24jd_24 Member Posts: 92
    I saw 3 different 2012 Imprezas before I got mine 3 weeks ago, but haven't seen one since. I somewhat enjoy being the unique car out there. Lots of Subies in the Minneapolis area.
    I plan to do the same.
    The XV gets a bigger gas tank (15.9 vs. 14.5) and one of the big things I'd like in my next car is more range.
    Bigger tank probably just equals lower fuel economy.
    We'll see. I won't seriously consider it if it is less than 31-2 mpg highway on a manual transmission. I'm willing to give up some economy for AWD, and I much prefer it over the Impreza hatch both for appearance and clearance. That said, I don't need the AWD for my personal transportation, so that's as far as I am willing to go.
    I love the AWD. My buudy has been in all my vehicles and he says the Subie was the most safest and secure of all the vehicles I ever had driving in the rain. That includes the Honda Element with real time AWD and a 4x4 Nissan Xterra ;)
    The 2.7 inches of clearance difference is obvious, but the other appearance changes are such a subtile difference. Why not a little lift kit on the Impreza? Am I missing somthing other than the black trim around the wheel well and front bumper and the fog light changes?
    The 17" wheels appear to have a slightly higher profile to them.
    Subaru is estimating 30mpg highway for the manual on its website for the XV.
    edited April 2012
    I heard the XV was rated similarly. Let's see.
    For me, range is more important than mileage. My van can go 4-500 miles on a tank. Sweet. The Miata's low fuel light goes on as early as 260 miles in...ugh.
    Update.... Finally ordered new 2012 Imrpreza Sport Premium CVT PZeV today... Dealers got in a bidding war.. Got it for $20,600 with homelink mirror, rear cargo tray and net. Out the door with taxes and tags $21,817. I'm pretty happy with my first new car purchase since 1989....:)
    The trimming definitely makes a massive visual difference; it helps create a transition from the sheet metal. The higher clearance, while vastly practical in the area I live, also helps balance the vehicle's look. In person, the hatch looks like a whole lot of sheet metal that stops just shy of the ground; it isn't helped by the boxy, angular [non-permissible content removed], either.
    I love AWD, too. It makes for a whole lot of fun when you drive on snow or ice for six months of the year. However, I don't need it. I can get around just fine with my little one-wheel-drive Escort as a commuter car, and it gets 31% better fuel economy (averaged) than our Forester. If this was my family car, and my wife was going to drive it regularly (or at all), I would rank AWD up higher. As it is, I put it in the "nice to have" category because if I *really* need AWD, I can take the Forester. I'm willing to give AWD a leeway of five miles per gallon, and I tend to average about 2 mpg over EPA combined estimates over the life of a vehicle.
    So, when considering a 40 mpg car versus a 30 mpg car (highway), the latter also being somewhat ugly, it better have a laundry list of attributes that put it ahead of the other options or it isn't going to make the cut. I want to explore it fully before coming to a conclusion, though.
    edited April 2012
    And for good reason! Congrats! :shades:
    I'd be thrilled to get that car, with manual transmission, for that price, and the MSRP on the manual is a grand less.
    I'd rather lower it an inch...excellent handling car. :P
    I was told by a dealer that the last day to order a 2012 impreza model is April 25th or 28th, can't remember the exact date.... :)
    still surprised to hear that (i think others have posted it). even with a 8-12 week delay, that puts delivery in the ballpark of mid june-mid july. unless the 2012 comes out early summer, it seems they would sell the 2012 a bit longer.
    i wonder what is in store for 2013...can't see any major things being changed except for addressing some design issues that might be going on behind the scenes or things that were rushed for the 2012.
    not that it matters to me since i bought a 2012, maybe make the trip computer standard on the NA '13's as well? :)
    I would have probably bought the base model, but it doesn't come with cruise control standard or as an option... now that's what should be standard on a vehicle ......come on Subaru.... for $17,495 give me standard cruise control !!! :)
  • brianna_mplsbrianna_mpls Member Posts: 4
    I ordered a Sport Limited 5-door four weeks ago (moonroof, auto dimming mirror added) and when I followed up with my dealer to see if there was an update they didn't even have a VIN# assigned yet with no ETA. The guys at the dealership have been surprisingly hard to get a hold of with my follow up questions so thought I'd ask here.
    If they don't have a VIN assigned yet does that mean it will be more on the 8-12 week side of things rather than the 4-8 they told me to expect? The car would be shipping to Minneapolis.
    Thanks for any insight. I'm really excited to get the car!.. especially b/c mine is about to die. :(
  • dcm61dcm61 Member Posts: 1,567
    The extra 2.7 mile highway range (33x15.9=524.7 vs. 36x14.5=522) isn't worth the projected 3 mpg penalty.
    Yes, it will most likely have more city/suburban range, but still probably not enough to talk about.
    I ordered a Sport Limited 5-door four weeks ago (moonroof, auto dimming mirror added)...
    I too ordered a Sport Limited w/ Moonroof. I checked after 4 weeks and they had no update. It's now been 6+ weeks and I've heard nothing.
    Ugh, bummer - that is NOT promising.
  • donnieyodonnieyo Member Posts: 2
    I also ordered a Sport Limited with moonroof and Homelink mirror (and Nav), 9 weeks ago today.
    Two days ago I checked with the dealer, and was given my VIN and told May 11 delivery date (to Chicago). That puts delivery at 12 weeks and 2 days.
    I've read here (or elsewhere) that delivery often happens a few/several days before the estimate. Fingers crossed... this has been a test of patience.
    I'll disagree on the styling :) but I'd say neither is great. I also didn't think there was much wrong (styling) with my friends AMC Gremlin, so mayby I'm style impared. :surprise:
    For the AWD and practical usage I'll agree 100%. AWD for me wasn't a big deal and was low on the list too. Ground clearance was a little more interesting. I almost waited for the XV, just because being 6'4" its easier to climb in and out of it. I drive a farm field road 3 to 5 times a year, and have more than 6" of snow on the road maybe 3 times a year. I commute 35miles (one way) to work nearly every day. MPG needs to be higher on the list. The old Outback can do the rest.
    The 30% mpg increase over our 2001 Outback is nice. Its one reason we don't have another Outback. 36mpg Impreza vs 38mpg Focus I prefered the Impreza. 36mpg Impreza vs 48mpg Prius. Harder choice, but my wife hated the Prius and we both liked how the Impreza drove compared to the Prius.
    The Minneapolis/St Paul dealer I bought mine from told me 8 to 12 weeks, with 12 weeks being if it wasn't already in the assembly line.(That was in March) I lucked out and found one that was already being shipped to them that was close enough to what I wanted. If I recall, the VIN would be available once its made and ready for shipping. So I'd say yes to your quesion of the 8 to 12 weeks.
    Do we have specs for the US model yet (XV)? Where'd you get the MPG info from?
