Visitor Agreement.
In my '99 manual its position is indicated in the index.
Steve
Anyway, the kid got oil on top of the skid when he drained the crankcase, and he got even more oil on the top of the skid when he unscrewed the old filter and took it off.
Maybe there is no way to avoid this?
Tom
Have you hugged your Jeep today?
As you now have protection in that area, you could fit a drain valve instead of the the regular drain plug in the oil pan. You want the type you can attach a length of hose to. Fram makes one, and there's a better one available from a company whose name escapes me at the moment.
Found it (the wonders of Google)!
Fumoto Drain Valves
You want the type with a nipple to take a hose. I can't remember the Wrangler's drain plug thread at the moment.
Actually, if you get the drain valve it makes it so easy that you may end up changing the oil yourself!
Many moons ago I did change my own oil. But, they have deals so good now that it just ain't worth the trouble.
At the GM dealership service dept, they will change your oil and filter, do lubrication, and top off fluids for $5.95, if you bring in your own oil and filter.
At the DC dealerhip, where I normally take Thelma Jane, it's $10.95 or something like that for the same service.
The only way I will let either place do that work is if they let me stand right there at the bay where the work is being done and supervise. So far they have let me do that at both places, but if they ever enforce the official policy of no customers in the shop, that's when I go back to changing my own oil and filter at home.
Now that might sound like I don't have confidence in either service department, but that is absolutely NOT the case. I just like to be there when work is done, no matter how much I trust the establishment or the individual technician.
Now I just have to find someone to watch ME while I watch the TECHNICIAN. I stood there yesterday and watched the whole process. I even wiped off the zerks for the seven lube points, in case the kid wasn't in the habit of doing so before lubing. (If you don't clean first, you are just forcing grit into the zerks along with the fresh grease.) Well it occurred to me last night that I didn't see the kid do any greasing! He didn't think of it, and I didn't either at the time! Will be going back today for the lube job.
Tomster
Another (free and easy) option is to cut the top few inches off a 2L soda bottle and use it as a funnel to get the oil through the drain hole on the SkidRow skid.
-twylie
Jeep gauge fix
-twylie
I know of seven places that take grease on Thelma Jane. Where are the other nine? The ones I know of are all on the steering system somewhere: top of steering knuckles, tie rod ends, pitman arm, and drag link.
Didn't think any of the U-joints had fittings. Do they???
Tomster
#15031 by twylie Nov 13, 2004 (9:40 pm)
one tip my dad taught me on changing oil is to place the drain plug on top of the new filter. Helps me to not forget the drain plug before filler 'er back up. My routine in oil changes:
- gather new oil and filter (to make sure I have what I need)
- put drain pan under oil pan
- remove drain plug
- put drain plug in top of new filter
- remove old oil filter, place small drip pan under filter location
- get grease guns and hit all zerks with syn or poly grease depending on application
- log mileage and date on back of oil filter box top
- write up new oil change sticker (many auto parts stores give these out for free now)
- top off washer fluid
- visually check radiator overflow tank and brake fluid, diffs and tranny through check holes
- check air pressure
- replace drain plug
- lube up gasket on new filter
- wipe filter seating surface
- hand tighten new filter
- recheck drain plug
- add new oil
- start engine until oil pressure shows, run 30 sec.
- shut off engine and fill containers with old oil
- put away tools
- check oil level
- grab an adult beverage
Sounds a lot more complex than it seems when doing it, but after a hundred or so oil changes, it's routine.
I will be the first to admit that having a garage has made auto repair/maint. much nicer in extreme temps or inclimate weather.
-Paul
That last step the most important?
-twylie
-twylie
I meant to check my air pressure label this morning. Mine's on the door frame. I think it's 28 or 29, which seemed low to me, but what do I know.
-Mike
Does that gauge fix perhaps affect just the fuel gauge as well?
twylie, you still available for assistance with OME?
-Paul
-twylei
Good advice, that's where most of the answers to commonly asked questions are!
In this particular instance, although nothing has to be disconnected, it's very important to set the transfer case and main transmission correctly.
Good Old Mac can help us, I'm sure, and probably some others in here can also shed some light.
Anyone?
Tom
Sure wish they'd get around to opening some of the trails around me - the rains have stopped, everything is pretty dried out in the lower elevations and I'm ready to go play on a dirt road. Gigi would like a change from all the freeway pavement she's been on recently.
Thx,
Mike
P.S.Edit -- Wow. Mtngal gave me a nice segue to 4x4ing. Didn't even see that until I posted. But, yeah, with the recent rains even the paved canyon roads have been an adventure.
You don't necessarily have to take a course to get started - there are lots of wonderful, easy roads in the national forests to give you a taste of off-roading without running the risk of getting into trouble. There are a number of guidebooks available - email me (my address is public) and I'll send you a list of the ones I've read.
If you want to wander around SoCal backcountry you might check out the Southern California Auto Club county maps. They are excellent and have many of the dirt roads marked on them, along with indicating seasonal and permanent gates. At the moment many roads that are normally open all year are closed because of our tough winter, so it would be a good idea to check with the national forest rangers for the area you're thinking about visiting.
>California would sure be a nice place to live if it weren't for the fires, earthquakes, landslides, high winds and traffic!
Don't forget riots. Riots are fun too.
-Mike
And how could I forget the riots - they sure screw up traffic!
Everyone - be careful out there!
Seriously, welcome to the group, and congrats on getting a Jeep.
I have no experience with anything other than TJ's, since I got into this "Jeep Thing" only four years ago and bought a TJ.
I'm sure someone will be able to help you with your lift selection.
Tom
Now yer talkin'! Get ready for the most fun you will ever have with your clothes on.
Mtngal gave you some excellent advice about getting hooked up with a club. That's the best way to learn off roading. Most clubs welcome newbies, and the members are more than willing to help a newbie learn the ropes.
Man, if you just lived near me.... I love to help folks get started in this wonderful hobby, sport, or whatever offroading is.
Do you have tow hooks front and back? Do you have a CB? These things are really necessary, and a lot of clubs will require that you have them to ride with them. They just plain make good sense, so whether the club requires them or not, you ought to have them.
You can't pull a Jeep out of a hole by attaching a cable or or a strap to the bumper. You just bend the bumper and don't move the Jeep. Tow hooks are essential.
You need a CB to communicate with the other Jeeps in the group. If you have a radio, the trail guide could tell you, "watch me, but don't follow me," or "come on and follow me, this is one you can do." That is better than guessing whether or not the trail guide wants you to try an obstacle. Besides, the chatter on the radio is part of the fun.
Tom
Mine is a soft top, which is way fun. I've been on this site for about as long as Tom, but with far fewer postings. But then, who doesn't! I bought used, but in 2000 it onlyhad about 12,000 miles. Now it's up to about 80k. Still a baby, in mtngal terms!
Many helpful pointers from this site over the years. Thanks especially to Mac with regard to my heater core/radiator issue. But others have also been very eager to help. Quite a strong extended family.
Enough history. Like I said; I've got a soft top, and half doors. This means a lot of zippers. Most are fine, but especially the driver's window is very "sticky" and much less effective than it used to be. Is there a good lubricant to restore it's smooth operation (zippers are like magic to me; how in the world do they work?!)? Or should I cave and look into a set of sliders? I'd prefer to keep everything original and ind a solution with some cheap lube solution, but am willing to face reality.
Thanks again. I know there will be help here!
Red
Offer still stands... if you send me an invitation to view your pics at photobucket, then maybe I can get them to load here in Jeep Wrangler.
Email is public in my profile.
Tom
".........(zippers are like magic to me; how in the world do they work?!)?..........."
Yup, they use magic, probably licensed from Disney!
I think the problem is with the cookies and I do not want to disable the cookies block on my computer. Tell me how to send you an invitation (you have my permission right now) to view the photos on photobucket and it's a done deal.
Thanks...you ought to see how much "stuff" this thing can hold...wife and I re-packed all our gear into duffle type carriers and you can pile a ton of stuff in the back (took the seat our and wrapped it in bubble wrap and won't see it again until I sell it for a new one). Hope we can post it...it is a beauty and ready for 10 days in Utah soon.
In your Photobucket account, there is a place where you can "invite"someone to see your pics. You need to copy and paste my email into that thing, and I will receive a link to your gallery.
Maybe if you just tell me your username in Photobucket, I can go there and do what I need to do myself. I'll check to see if you used iconoclast there, like you did here, but if if's different, you'll have to tell me.
Not sure if I have time this AM, since I am wheelin' today (had to work yesterday). If not this AM, will do this evening.
Tomster
Tom
Just
Empty
Every
Pocket
I spent $500 + buiding a shed yesterday to put my hardtop in for the summer,, why is it that everything I do cost $500 or multiples of $500?
before buying my jeep,, i made pottery on a potters wheel,,,, $500 of clay would last me 2 years !! now I don't seem to have time for the pottery...
I bought my softop as a dealer take off. and have no instructions,,,,
The owners manual has a better description than I imagined, but the diagrams aren't the same as pictues. one of the parts is a long black, piece of cushion / foam, it looks like it was glued in place on the original jeep, what is it?? and is there already one of those in my jeep that won't need replaced??
I have a service manual that I bought from EBAY,,,its only for regular length jeeps,,
the unlimited tops are slightly different--- correct??? ( yes I know they are longer )
jts
hoping the sermon is SHORT this morning,, i want to get onto this project ASAP
In that case get the biggest body lift and cheapest suspension lift you can find. It'll be cheap, not much good off road, but it meets your criteria. Wouldn't be my choice though.
If it were my Jeep (you did ask) I'd be looking an Old Man Emu (OME) 2 1/2" kit for about $950.
I'm not sure what you could have there. The Unlimited's top is different than the short wheelbase soft tops, but since my Sport is a hard top, I'm not sure of all of the differences, other than the Sunrider option and its associated hardware. It looks like there's basically the header, a couple of bars for support, the windows and the top itself.
When I bought mine there was an addendum to the owners manual that had better instructions. I'll go outside and take some photos, but they will be with the top up.
