Noise at start up
I have a 08' Silverado with a 5.3L AFM with 72k miles. I use Mobil 1 5w30 and ac delco filter. The truck has a loud ticking noise when it starts, it does not do it all the time but is getting worse. I took it to a dealer they had it two days and found nothing wrong. Five days later it was so loud I recorded it on my phone which lasted two minutes while the truck idled in my garage. I sent the recording to the dealer over a week ago and have heard nothing. U The noise gas gotten so bad that you can hear it in the cab as you drive down the road and lasted a whole 7 minutes this morning. I have been around cars all my life, currently have an old Vette in my garage doing a frame off. I am smart enough to know there is something wrong but no one seems to care guess GM assumes if the engine makes it to 5 years or 100k miles they are off the hook. Very disappointing, I just want my truck fixed before I get stuck with the bill!!!
If you wanted for us to work with you on finding another dealership for a second opinion on the noise you're hearing with your Silverado, or check into the diagnosis performed by your current dealership, please send us more information at socialmedia@gm.com (include your name and Edmunds username, phone and address, the last 8 of your VIN and current mileage, and the name of your dealership).
Sarah, GM Customer Service
I also have the drivers side rear exhaust manifold stud broken off (from the factory do to over torquing it during assembly) which causes a ticking sound until everything heats up and it seals itself. You might want to check for a broken stud on exhaust manifold cuz that takes longer time frame to go away and it comes back every time you start the truck till it heats up and seals itself. You can't get to this rear stud for a fix unless you pull the head and drill it out (mucho $$ to do that repair) Wish I had noticed that before the warranty had expired.
All I can say is keep good documentation, but don't expect to much help from GM they already got your money when you bought their product and your beyond :lemon: law time frame. If you haven't spoken to GM Customer Service Rep. I suggest you do and get a file started. Good Luck with your GM (General Malfunction) vehicle. Keep us posted.
Ray T
Kindest regards,
Sarah
GM Customer Service
Take note that GM Sarah (to me) is a useless piece of trash posing as a GM Customer Service rep who is merely a go between with the GM Service Dept. you chose to bring your bucket of bolts to. Her purpose is self serving and she does nothing for you other than setting up an appointment that you can well do yourself. If your within warranty time frame not an issue, if your out of warranty your gonna pay period ! The customer is better off calling GM and starting a complaint file ( as long as your warranty is still valid). The other tool is NHTSA complaint.
GM Sarah,your function on this board is actually disgraceful, stop posing as someone who cares when all you actually do is justify your job by pretending to do a service to those GM owners wronged by a defective product. :lemon: They can just as well make an appt. with a dealer as well as you which really seems to be your only function in "caring" about the once loyal GM customers with legitimate product problems.
I have always found it easier to represent myself rather than using a poser like GM Sarah
Ray T
If you would like for us to follow up with your dealership to see if there are any options, please contact us via email at socialmedia@gm.com (include your name and contact information, a summary of the situation, the last 8 digits of your VIN and mileage, and the name of your dealership)
My :lemon: 2000 Silverado has the 5.3 and the piston slap. The routine I suggest you follow short of replacing the engine is simple; start it up and let it idle for 4 to 5 minutes (yea I know it means you have to sit and wait) by doing so it lets the engine temp heat up and the metal parts to expand to within tolerance range, the slap goes away and your on your way with the GM junk we all once trusted. I have followed this routine for all 96k miles I have on my truck and it has not had any ill effects other than an annoyance factor. GM extended my engine warranty to a 5 yr/100k when I established my case file back in 2001.
The final advice is show GM your lack of confidence in their products when it comes time for a new truck, buy something other than GM. They will never go belly up because our government bails them out when they do stupid things.........as Larry the Cable Guy stated "ya can't fix stupid"
As for GM Sarah, she can take a long walk off a short pier in shark infested waters to join the bottom feeders she swims with, no one would miss her, not even her children if anyone was stupid enough to mate with her....... :surprise:
Case closed.... Ray T :shades:
