Mitsubishi Outlander Timing Belt Failure
Anyone with experience with timing belt failure on the 2.4 liter, 4 cyl Outlander engine? I just broke a belt on my Outlander (it's a so-called interference-type engine) and am wondering what level of drive train and/or lower end damage to expect.
If the engine is switched off inmediately after the collapse of the timing belt it may produce little damage in the engine but the damage can only be evaluated by a specialist mechanics. Sometimes the damage can be severe that may require the engine change all together.
Ask for a second opinion and if the car is still under warranty you may request the change of engine (included valves) to have peace of mind.
Looking through the maintenance schedule for the 2010 ES, replacement of the timing belt at 105,000 miles is a requirement except for the 4B1 engine so failure of this component must be very unusual.
Assume you are covered under warranty?
