CFI to carburetor conversion on 1984 Lincoln Town Car
I have a 1984 Lincoln Town car, and am thinkabout converting it to a carburetor. I have most of the parts picked out that I need for it. I am going with an Edelbrock Performer intake manifold. A 500 cfm carburetor. A bigger cam, a mallory dual point distributor, and possibly headers.
What I would like to know, can I use the current in the tank fuel pump and use a pressure regulator? Or do I need to get a different fuel pump? When I assemble it, I am going to put on a different timing cover, and an eccentric on the cam, so if I need to go to a mechanical fuel pump in the future, I can.
Has anybody else here done this? What compications might I come up with while doing this?
It is getting ready to fire up. Right now, I am searching for a set of Headers that will fit it, and have found a set of Hedman's that might fit it.
This project has been very fun so far. I'm excited to see what kind of performance gains that I get out of it.
Also, does anybody know if there is already a fuel pressure regulator in the fuel line somewhere? If so, where is it at?
I'm 99.273% certain there's a return line. Maybe trace it back? I'm also that certain there is no regulator. From what I understand many do convert to a manual pump.
I got the engine fired up last night. It sounds healthy and runs smooth. I idled it at 2500 RPM's for about 30 minutes to break the new cam. You can check out the progress of it on my facebook page. All of the pictures are in the mobile uploads photos. Not all of them are there, because my phone isn't allowing me to upload pictures right now, but I'll get them on. You can look up my profile with my email, which is freedom_fighter1000@hotmail.com
Here is a list of things that I have done to it.
I have dissasembled the heads. Polished them, and port matched them. New power sealed valves, new valve springs, and keepers, and freeze plugs. Has an Edelbrock Performer Plus cam shaft, and lifters, new push rods, and rocker arms. The entire valve train has been gone through.
I went with an Edelbrock Performer intake manifold, and a 500cfm carb. Has a set of Heddman shorty headers with a dual 2 1/2" exauhst, and Cherry Bomb Turbo Mufflers.
I think that is about it. This has been a very fun project. If anybody has any questions about this, I would be happy to awnser them for you.
Yes,
It is the Hot Rod Lincoln.
How compatible is a 331 connected to the factory computer designed for a 3.8?
Almost 10 years later…LoL! I have many questions as I currently have a 84 town car that is in progress of converting the TBI system to a Carburetor system . The work is getting done at a shop but was wondering what all issues came from doing this conversion?
