Dodge Ram Problems
jwg_aggie03jwg_aggie03 Member Posts: 6
I bought my Ram 2500 4x4 diesel the last day of
march so I've had it about 7 months and have
almost 23,000 miles on it. A little over a month ago, my wheels started to get stiff when I was at slow speeds or stopped. Now, especially when stopped, they don't turn at all. I took it to a local Dodge dealer to get it fixed and they replaced everything but the steering wheel and the linkage, still the problem persists. Chrysler now tells me that it is a normal condition aggravated by my one size bigger than stock tires and my aftermarket bumper, and they won't fix it any further, sounds like an excuse to get out of fixing it. Now my question, is anyone experiencing these kind of problems, and how do I go about getting this resolved. I have already returned the tires to stock size and no changes were noticed, but Chrysler still won't deal with it.
Jon
«134
  • jwg_aggie03jwg_aggie03 Member Posts: 6
    The bumper weights less than I do. I used to work for the bumper manufacture, and we would put these bumpers on all kinds of trucks, even 2wd 1/2 ton's. This is a 3/4 ton 4wd diesel, it should be able to handle it. The manufacture has been building these front bumpers since `94 and they have never had any problems with them, except on some of the lighter duty trucks (2wd half tons). Thanks for the thought though.
    Jon
  • firemandavefiremandave Member Posts: 58
    Jonathan:
    I have the same truck as you. I got mine in April. I haven't experienced the problem you describe, but I did have steering problems from day one. I had the track bar and steering box replaced before the wandering and slop in my steering was eliminated. Has your steering box been replaced? Dodge has had a lot of problems with the boxes on our Cummins trucks. The TDR website would be a good place to check for others' experiences, although I haven't seen your problem discussed there yet. Another possibility may be the power steering pump.
    The dealer that I'm working with has replaced everything, power steering pump, gear box, hydro boost, pressure lines, still nothing. And that's why they and Chrysler are blaming it on other items now(they sure didn't mind my oversized tires when they only though it was the pump), because they don't even know whats wrong with it, they and Chrysler are taking the cheap way out.
    Jon
  • baddawgbaddawg Member Posts: 2
    Guys,
    I got a call Friday from my Dodge dealer. After hearing a progressive ping/rattle upon acceleration, I decided to take my 99 Ram Quad Cab in for service. The service tech called me and told me that they've been running into "factor defects" and the intake manifold gasket was never installed on my truck and if I had driven it any longer, I risked ruining the engine. At the same time, they said the valves were ruined (claimed factory defect again) along with the catalytic converter...I think I've had one Dodge experience too many.
    SD
    Jon:
    Since you can't steer at slow speeds, it seems clear to me that you have no functioning power steering. Were all of the power steering lines replaced? Or did they just replace maybe one and the pump. Maybe the new pump is defective - a long shot, but not impossible. Did they remember to put fluid in the new pump?
    I'm assuming it's an '00 or '01 and still under warranty. If so, make sure they fix it before the warranty is up. Other possible actions for you would be to make a scene with the sales manager that sold you the truck, go to a different dealer, or contact Dodge directly to complain. If you've returned the tires to stock, then you've eliminated that theory for them, and unless you hung a Yugo on the front for a bumper, that can't be the problem either. My translation of the "it's normal" response is that what they really mean is, "we don't have a clue, and we're too lazy to find the solution". I'd try another dealer for a fresh look. There are good dealers out there, but sometimes you have to search them out.
    Dave
  • jsayrejsayre Member Posts: 2
    GOT SOME BAD FUEL IN 2001 DIESEL RAM AND HAD TO
    CHANGE FILTER NOW TRUCK JUST TURNS OVER BUT
    WONT START...HOW DO YOU GET THE AIR OUT OF THE
    LINES...DO YOU LOOSEN LINES AT INJECTION PUMP
    OR AT HEAD. WOULD APPRECIATE RESPONSE FROM SOME-
    ONE WITH KNOWLEDGE OF THIS SUBJECT.
    Try the TDR website or Dave Fritz's Ram site.
    www.turbodieselregister.com
    www.ecpe.vt.edu/~dfritz
  • wildmanbakerwildmanbaker Member Posts: 65
    Its possible that a missing intake manifold gasket would make it ping, air in-leakage causing a lean mixture. This could result in burnt exhaust valves, and possibly overheating the converter. Make sure you look at everything before you take it back. Make real sure that the problem is fixed, and a new one does not take its place.
    good luck,
    Wildman
    It appears they added one more thing to the list. They rebuilt the thermostat housing as well. After checking their work, I'd say they did a very good job. I test drove it for a good 2 hours last night and spent some quality time under the hood. That's not to say I'm happy with the truck at the moment. This is just the latest in a long line over the past year.
    SD
  • rocketman00rocketman00 Member Posts: 1
    I test drove a 2001 Ram Quad Cab 1500 w/ the offroad package that includes a limited slip 4:10 rear-end. Turning a normal right-hand corner from a stop, the tires started grabbing indicating that the limited slip was engaging. Does anyone know if this is common or indicative of a potential problem?
    It was also interesting to note that the idle was not as smooth as I expected & then find that to be a hot topic here.
  • lariat1lariat1 Member Posts: 461
    The slight jerking you feel when going around a corner is normal with a LS rear end I wouldnt be concerned about that.When you test drove the truck and noticed the rough idle was the engine warm? I ask this because I just picked up my 2001 1500 and it idles with a little bump until it gets warm then it smooths out.
  • pajimpajim Member Posts: 1
    my 2500 2wd 360 auto/od . At 700 mi noticed fuel in oil took to dealer for a year before they found the bad gasket. Truck now has 16000 mi on it ..trans. been rebuilt 3 times and went again. Front main seal went at 15000 mi.
  • amoraamora Member Posts: 204
    I will still consider the purchase of a DODGE
    RAMBLER hemi in '01, '02...being all the makes
    of cars, boats, planes, pick-ups have problems...
  • hooper3hooper3 Member Posts: 1
    I'VE HAD MY 2001 Q/C 4*4 DIESEL A COUPLE MONTHS 10,000 MILES . HOW MUCH SMOKE IS NORMAL ON COLD START ?IF THERE IS ICE OUT SHE SMOKES UNTIL I DRIVE OR THE GAUGE MOVES [ BAD ENOUGH THAT MY NEIGHBOR COMPLAINED ]. HOW LONG DO YOU HAVE TO RUN BLOCK HEATER, CONSIDERING A TIMER . ITS NOT TO COLD HERE IN THE NORTH WEST BUT SMOKE IS A PAIN. ALSO DOES THE ANTI LOCK BREAKS FEEL LIKE AT THE LAST 5 M,P,H. OR SO TO RESTRICT BREAKING PRESURE?I DON'T LIKE THE BREAKING .OTHERWISE HAPPY WITH TRUCK.
    Smoke is normal on all dieselss until you load the engine which means that until you drive the engine will smoke, the ABS will work great until the speed is less than 10mph then the ABS is useless. I used to own a 98 24v and that is what it used to be like
  • davids1davids1 Member Posts: 411
    I have had numerous annoyances with the front end of my 99 ram 1500 quad 4x4. I do have some noise. Mostly noted when the truck rocks from side to side. Also worse in cold weather. Is your worse in cold weather. Let us know what happens with your dealer.
    Try this. Put your automatic transmission in 1st gear. On a level surface, accelerate until about 1800 rpm. manually shift the transmission into 2nd. That's the roughest upshift I have ever felt. Does anybody else's tranny shift rough when shifting manually from 1st to 2nd on the auto? Enquiring minds want to know.
    I will have to try it with my truck I have never tried to shift from 1 to 2 manually with this truck,my 98 ram shifted hard but it was a diesel.I only have 1700 miles on the new truck so I havent tried to much yet.
    The upshift isn't necessarily hard or firm, just the opposite. It jerks around quite a bit before going into 2nd. Give it a shot and let me know.
  • dodgeramdodgeram Member Posts: 202
    I have 2000 ram 4x4 qc diesel, auto. The problem is a week or so ago, I started the truck let it warm up for a few minutes temp -3celcius around 26
    F. Anyway I put the truck into gear and proceeded, but the steering would not work and the brakes did not work either. Itwas like the truck wasn't ruinning, but it was, It;s a diesel. After ten 15 minutes, Of checking for leaks etc, I reved the motor up to 2000-2500 rpm, and the steering and brakes started to come back. I took it too the dealer but by the time I got there the truck was running fine. So he looked it over but didn't fined anything wrong. He said if it did it again then come back. Today after this snowstorm (I live in ontario Canada), I started plowing the snow, but on my first reverse I backed right in to a wood post damaging the tailgate and bumper,and bent the tailgate brackets and hinge. The brakes would not apply, I didn't hit it very hard but enough to cause $1900 worth of damages. My question is the reason I hit the post was because the truck malfunctioned (no brakes), Can I get chrsyler to repair the truck or AM I out of luck.
    P.>S the truck started to work fine after a couple of minutes.
  • pocahontaspocahontas Member Posts: 802
    Copy/pasted for aamalibu:
    #24 of 24: Auto-Trans Problems (aamalibu) Thu 14 Dec '00 (11:55 PM)
    I bought my '01 Ram 2500 Quad SLT Plus Cummins in
    May '00. It didn't seem to have the power it
    should. The dealership, instead of fixing the
    problem right, bent the throttle pedal up to get
    full throttle. Within 10 miles I could tell it had
    a lot more power but the trans was not shifting
    correctly and the converter would not lock-up. The
    dealership ran the electronics test said nothing
    was wrong and would not look at it again. So I took
    it to another dealership. They ordered a new pedal
    assembly, adjusted the TPS and to make a long
    story short...after 9 visits to the dealership its
    on trans #3 has no power and still doesn't lock-up
    or shift right. I LOVE this truck but hate all the
    PROBLEMS. Anyone have any advice??
  • jbeardenjbearden Member Posts: 1
    I've got a '99 Dodge 1500 Quad-Cab Sport with the 5.9L engine... I have 26k and my 4x4 will not engage... Is this a know problem? Another friend has a '99 2500 Diesel and his 4x4 quit working after 25k? Any help?
  • currie1currie1 Member Posts: 1
    Ive got a 2000 SLT Quad the steering went out at 6,000miles the problem was the power steering box the shaft inside snapped.Ive found others with the same problem its nasty when it happens out on the highway.
  • checotahchecotah Member Posts: 1
    I have a '97 Dodge Ram 1500 5-speed 5.2 with 26,000 miles (and out of warranty this past August, 2000). During a trip home from out-of-state I noticed a rattle upon accleration. Shortly after arriving home, the check engine light came on and then the oil light. Being only about 10 miles short of my 3,000 oil change, I was surprised to find very little oil on the stick. Very confusing, as there was no oil puddle where I park, no oil on the engine, no oil sprayed on the undercarriage. Put in some oil -- 3 quarts to be exact, and drove to my mechanic. The question of where the oil went is simple -- the intake manifold plenum gasket was blown on two sides, so it was all sucked through the manifold and burned in the engine mixed with gas. What fun! And to top it off, my mechanic found Dodge issued a TSB -- #09-05-00 (revised and dated 2/25/00) -- for several models of Dodge Rams, Dakota, Durango, Van, and Grand Cherokee from 1994-1999. So Dodge is well aware of the problem, apparently it's not new, and there's been no recall. So if anyone else out there suddenly has disappearing oil and acceleration rattle, look at the intake manifold first!!
  • jschroer1jschroer1 Member Posts: 1
    I am wondering if anyone else is having the same problem that I am ? My truck has 60,000 miles almost all highway and the dealer told me that my torque converter is bad and I need a total rebuild on my transmission. called Chrysler and they told me that I was out of luck and I would have to pay for the repair It seems to me that a truck that has a towing package should be able to last longer than this ,what do you guys think.
  • apolloxxxapolloxxx Member Posts: 1
    seems as though I got a solid and reasonable 65,000 miles out of 96 RAM until lately -- now, a numebr of things have decided to go "poof" in the night: fuel pump, brake switches, cruise control "electronics", CD player, front end (steering box), numerous things I have to go back an look at...all of this in just a few months! in fact this vehicle is the first o leave me without warning (the loss of fuel pump). I have not changed the way I use or maintian tthis vehicle (gets babied through dealership)... so my question is: given the spectre of a Chrysler's notorious transmissions nowadays + surge in repairs = should I sell this thing and move on to GMC? Toyota? The brake switch failure was intriguing: 1st thing I noted was the trans was varying 500 to 700 rpm under CONSTANT load (level road, non accelerating), the cruise control went out (once again), and unbeknownst to me for a day, brake lights that would come on without depressing the brake pedal -- after TWO days in the service dept. and $140 labor for $20 switch, the repair "seems" to work (trans = OK, c/c = functional, guessing lights are AOK....). Seems to me that Dodge trucks fail "rapidly" and without warning... something I am not used to even in my FORD 4x4 (owned 4, last one = disaster!!)... cheers....
  • dirtyonedirtyone Member Posts: 2
    I have just installed 315/75R/16 BFG T/A's on a 2001 Dodge Ram AC Diesel Auto 3.73 rear. The stock tires were 265/75/16.
    After installation I have really noticed a change in the shift points and overall performance.
    Will recalibrating the speedometer/ speed sensor correct some of this? Has anyone out there done this? I'm in the Baltimore area, Any shops someone can recommend? Anyone know how to figure out what my final gear ratio is now?
  • myhorsemyhorse Member Posts: 1
    i am about to purchase a new 2500 4x4 ram with the cummins...is the 6 spd man trans the most durable ... does it suffer from the same rep as the other trans? How about the 5 sp HD ....same?
    my goal here is RELIABILITY OVER TIME Although of the dodge subject, i have also been looking at the f250 superduty but i have heard very bad reports about the electrical and servicability
    can ay one comment?
  • dgrover1dgrover1 Member Posts: 2
    My husband has a 92 Dodge Ram Diesel and the speedometer keeps going out. He replaced a part about 1 year ago and recently it started to act up again. It will work and then it will quit working. Would like to know if this is a known problem with these trucks and can it be corrected?
  • davebowen1davebowen1 Member Posts: 1
    I have a '98 1500 Quad cab 4X4 with approx. 42,000 mostly highway miles on it. The truck has not been used that often for heavy hauling or towing. I recently had the front brakes replaced, at which time I was told there was transmission fluid all over the rear axle & brakes-- indicating a broken seal. The folks who did the brake work said there is no reason the seal should have broken with so few miles, and that Dodge should pick up the tab for fixing the problem.
    The dealer, of course, disagrees, stating that these seals can go at any time.
    Does anyone have any knowledge of who's correct here -- is is unusual that the seal should be less durable than a set of tires?
  • faze3faze3 Member Posts: 2
    First off - I tried to search for an answer to this, but indexing was going on, so that was out.
    I've got a 2001 QC Ram 1500 5.2L 5speed that developed a rough idle after starting the engine after letting it sit 8 hours (maybe less). The dealership was finally able to reproduce it (after 4 days, and I was able to do it every morning before and every evening after work) but were unable to determine the cause.
    The sucker shakes like its got a racing cam in it, and is otherwise fine after warming up. Now, you may be thinking "cold morning/evening - cold engine". Nope. Its happened adter the vehicle has sat in 70+ degree weather.
    ChryCo corporate was supposed to send a mechanic out the week of Christmas but he was "too busy" to make it by. I'm concerned that whatever is happening is causing damage to my engine, that will eventually cause it to fail..
    The ChryCo mechanic is _supposed_ to be ou this way the last Thrusday of this month. I'd _really_ hate to have to take it to another Dodge dealership, and then go Lemon Law on them. I loved the '96 5.9L Xcab and now the '01, and would hate to have to give it up (especially since I tinted the windows and put a bedliner on it as well...)
    As for the wandering -- I noticed that its damned difficult to keep it straight on the road. I read over on alt.auto.dodge.truck to check tire pressure, to see if this was the cause. I'm running the Michelins that came with it I can't tell if the rear is whats wandering, or if its the front end...
    Anyone got any helpful suggestions?
    Try rotating your tires. My 99 Ram has the Goodyear RT/S tires. After some persuasion, Goodyear replaced 3 of the 4 original, and after I rotated them myself, I feel they should have replaced the fourth. Truck handles great now. When I rotate back to front the handling goes to pot. Pulls hard to the left. Swap front tires pulls hard to the right.
    My point is: OEM tires suck. Rotate your tires and see if it makes any difference.
    I'll give you that (OEM tires SUCK). But should I have to rotate them so soon? The truck has less tnat 5k on it.
    My suggestion at early tire rotation has nothing to do with wear. You could have a tire that is not perfectly round, or that has a broken belt, or is of a slightly greater/less diameter than the others. If you rotate your tires and the handling gets significantly better/worse, then you know there may be something wrong with your tires, and not your truck. I was amazed at the difference on my truck.
  • micks1micks1 Member Posts: 1
    we own a 98 dodge quad cab w/ 5.9 it has pinged under a load since we bought it.we have had the intake gaskets changed twice,and fuel injection cleaning($150 out of my pocket),tried different brands of gas,and changed plugs.none of these things helped.brought it in the other day and the dealer "flashed "the computer with a new program.
    this seems to have done the trick on my truck.this must be some kind of recall because i didnt have to pay and my vehicle is out of warranty,but dodge isnt puting this info out.
  • newbamanewbama Member Posts: 11
    Can anyone tell me if the fuel filter can be replaced with out much trouble or is it necessary
    to get the dealer to do it. I have a 1996 Ram
    2500HD 5.9L. It doesn't start after the first
    try but does on the second try, cold or hot.
    Had the plugs, wires, battery checked, air filter
    and PCV and crankcase filter done. Using Chevron
    87 octane. Anyone have any ideas. Also how
    about replacing of the fuel pump? Thanks.
    The fuel filter is located in the gas tank. Lots of fun to change. You can't even buy one at NAPA (at least a few years ago when I called and asked if they had any in stock).
  • markstoys1markstoys1 Member Posts: 2
    I have a 97' 1500 2wheel drive that was great for the first three years. The truck has always been well maintained, never abused. In the last 5 months the steering column broke, (I got Dodge to pay for the parts, it was a known problem) I was stranded with a bad fuel pump,$530. I was stranded with a computer problem, $290. The rear end went, just started growling. Dodge agreed to pay for the rear end parts, I payed $350 labor. I had them service the transmission, oil and filter. When I left the dealership the transmission started slipping. The truck is now at the dealer being "annalized". Needles to say I am shopping for a new truck. Never had a truck fail so quickly, and have things breaking that should not break. Where is the "tough" in Dodge Ram Tough?
  • ram_98ram_98 Member Posts: 1
    One 5.2 Stick, one 5.9 Auto with consecutive VIN numbers. 70,000 & 110,000 miles now.
    The 5.2 needed a power steering pump at 30,000 and intake manifold gaskets at 60,000.
    The 5.9 needed only the intake gaskets at 85,000 miles. NO other problems to date.
    Both exhibited severe pinging even on level road, excessive oil consumption (500 mile/qt),
    reduced gas mileage, "check engine soon" light. The intake gasket replacement ($300.)
    out of warrrenty cured all problems. The 5.9 would leave a cloud of smoke after coming down
    a hill and throw raw oil over the right rear fender. The 5.9 has always idled rough,still does,but
    only first few moments of day then smooth thereafter. Use the 5.9 to pull a 3 ton generator all
    the time. At 110,000 miles it will still do 125 mph, smoke the tires on dry pavement,deliver
    14 plus mpg, uses NO oil at 3,000 mile change. Original plugs/wires. Gotta love em'.
  • kbrittainkbrittain Member Posts: 2
    I am seriously considering trading my much loved Chevrolet 3/4 ton for the grounding-shaking power of the Dodge 3/4 ton diesel. After reading through some of these problems and concerns from all of you guys, I can't help but wonder if I am doing a good thing. I wonder if some of the problems concerning early transmission failure, electronics, as well as many assorted malfunctions prior to warranty's end, occur in more cases than not with these trucks. I would hate to think that this manufacturer has a problem with putting together good quality vehicles for hard-working consumers like us. If I could get any feedback from you guys concerning what you really think about these Dodge pickups, it may help me make up my mind about a trade.
  • alamow1alamow1 Member Posts: 1
    Owner of a Dodge Ram DRW 24 valve Diesel 2001, was purchased on Jan. of 2000 and delivered on April of 2000, was very pleased with the vehicle. At that time I was told by the dealer that the 2000 couldn't be ordered any more that they we going to take orders for the 2001 at the beginning of the 2000 since Chrysler was stopping that mid year order process. Based on this info. is how I ordered a 2001, the way I liked it. Now I find out that as of Jan/01 that the 2001 ram DRW has DISK BRAKES and some other features as to my rear drum brakes? My Ram was built in Feb of 2000 as the sticker states and I feel I am Cheated of the up grade and wonder if it's really a 2000 instead, and I paid for a 2001. Calling Chrysler '' to make it short'' they said that my vehicle was a pre - release and the later trucks with disk were a re-release. To me it sounds like my Dodge conv.van, when it needed a converter being a 94, it took a 93 model year converter, sort of clean up shop with parts? According to the vin numbers of my truck they were reg. as a 2001 vehicle. Questioning Chrysler Rep. Cust assistance, of what happened to the ordering process that they were going to implement at only the beginning of the year, they responded that it was only done that year. Does any one know, encountered or are aware of this . My point is disk brakes should have been a component in the 2001 from start.
  • jcmdiejcmdie Member Posts: 594
    No, disk brakes were not standard issue on the 2001 model. This was a mid-year upgrade. It happens all the time. The 2001 model year was identical to the2000. They changed the the designation due to CAFE. They would have encountered fines from the EPA otherwise and the 2003 models will have more fuel efficient engines that will take care of the CAFE problem.
  • texasdodgetexasdodge Member Posts: 2
    I have been wanting a 3\4 ton Quad cab for quite some time and I am the owner of a 79 Power Wagon. I have noticed numerous complaints and questions about the transmissions. There are at least 3 transmissions available that I am aware of in current Dodge trucks. The 5 spd auto, the NV3500, and the NV4500. None of the messages I have read so far, concerning transmissions, indicates which transmission has had the problems. I know one person with a 97 club cab, 1/2 ton, 5.2L 4X4 with about 80k miles on it and an automatic. He has had no problems at all with the truck. I have heard of problems with automatics in the diesels but only from rumors. I have been a subscriber of the major 4X4 magazines for many years and the NV4500 is considered to be the strongest transmission available today in every article I have ever read on the subject. It is highly sought after by builders of heavy duty off-road vehicles and I have read in more than one article that it may be the strongest transmission ever offered in a standard production truck. I am very curious to find out about the long term strength of the Dodge transmissions from a person who actually owns one though, so if someone who actually knows which transmission they have could respond I would greatly appreciate it. For the person who is considering trading the Chevy, from the research I have done and personal experience, as long as you stick to the NV4500 you should be OK. The biggest difference I have noticed in driving and riding in the Dodge and Chevys, is that the Dodge is still very much a truck whereas the Chevys are more like cars with beds. I much prefer the interior of the Dodge over the Ford or Chevy but the Chevy will drive and ride better, at least when new . For heavy duty use though, especially off-road, I would have to go with the Dodge. I am always amazed when I am in my wife's Volvo S70 and I am out accelerated by a 2500 Ram Quad Cab long bed with the Cummins diesel towing a trailer. I still have yet to figure why the Z-71 exists, other than to have people think you are cool, and the Chevy diesel, although improved, still does not have the reputation of either the Power Stroke or Cummins.
    I just read some of the earlier messages. It seems that the transmission problems are all occurring with the automatic. Has anyone had problems with the manual? It does not make sense to me to buy a heavy duty truck and then get an automatic transmission since they are inherently weaker. Even after owning an older Dodge with the very strong LoadFlite 727 automatic (truck version of the famous TorqueFlite 727) and a newer Jeep with a relatively weak manual AX-15 I would still never buy another truck with an automatic.
  • bluffbuzzardbluffbuzzard Member Posts: 1
    I just joined the town hall here, and I own a 1999 Dodge Ram Quad cab Sport. It's been a great truck so far (34,000 miles). But, from all the discussion going on, I'm curious to see where it takes me.
    About the only thing that I have noticed with it so far, is the wandering while trying to drive straight down the road. I notice many of you have talked about the tires... It sounds like some have replaced the steering sector, some have had a radial pull (tire defect), not sure what to think or say on that.
    My main question though, is that looking through the governments web site: http://www.nhtsa.dot.gov, several of these issues seem to be posted in TSB (Technical Service Bulletins). What I'm curious is, does anyone know of a place on the web (or by book) that a person can see the full document for a TSB and not just the subject? It seems to me that if many of the problems are discussed in a TSB, it might be much easier to find a solution (from the so called experts at Dodge or whomever).
    If anyone knows of a place, let me know!!! I'd really appreciate it.
  • unosteveounosteveo Member Posts: 1
    I was told by a Dodge Dealer that the reason lots of automatic transmissions fail in the Dodge Rams is people pulling large loads (5th wheels) and leaving the transmission overdrive on.
  • sebring95sebring95 Member Posts: 3,241
    Before we bought our 01 Ram for pulling horses, I consulted with a relative who is a service rep for Chryco (been there 20 years). He said the auto trannies aren't that bad and thought we'd be further ahead with the auto. Lots of people seem to burn up the clutchs hauling heavy loads then want warranty to cover them after 12K miles. He did say to keep it out of OD also.
    He told me a great story about a guy that bought a new truck a couple years back. He installed a new stereo/speakers, alarm system, and remote starter. Whatever clown installed all that stuff totally destroyed the wiring in the truck. Cut all the wires prior to the main control harness and proceeded to wire everything off of that. Nothing ever worked right on that truck again. He had 17 warranty claims in 2 months, all from electical problems. Stuff was surging and blowing relays all the time. One of the dealers finally pulled all the accessories off, put them in a box, and rewired the truck. But he still had occassional gremlins.
  • ddelehantddelehant Member Posts: 1
    My '96 Ram 1500 5.9 is used for commuting and towing and has begun to slip when shifting up. Odd thing is it only does it when I am accelerating slowly and without my boat in tow. (gross tow load: 6500lbs.)any ideas on this out there in Edmunds' land? Dan D.
  • john301john301 Member Posts: 1
    I own a 2001 Ram 2500 4x4 W/Cummins diesel and I was driving down the road and suddenly lost my power brakes. Once I pumped them they were fine after the first stop.I was told by a friend that someone he knew had the same problem and it ended up being something with the crank case venting and the brake booster. Any help would be thankful
