Other than that, 87k is pretty good for an original set of shocks, whatever expectations you might have had for 100k. If you're considering a lift then now would be the time to do it, as you'd have to replace the shocks anyway.
Thanks as always,
Mike
so are you spending what you saved on your son or on mods ... better yet,, tell your wife that your son REALLY wants new tires and a winch....
jeff
how about some pictures??
of the jeep and your son
Congrats on both!!
So yeah, best advice is get new wires (if you haven't already) and don't be afraid to use lots of muscle!
Ryan
How old is your Jeep? At only 24k this should be covered by the warranty.
As I related earlier, my Wrangler was wobbling consistently from 55 - 60 mph, and then at lower speeds after hitting large and small bumps on normal pavement. I started noticing it about a year and a half earlier, and it gradually got worse. I finally had to do something when I just slowed a bit at around 57 mph, and the entire Jeep violently shook to the point it was dangerous and I really felt that I may lose control.
I put a set of BFG AT 31 x 10.5 on it and the vast majority of the wobbling stopped, especially in the 55 - 60 mph range. This did not make any sense to me, because the other tires, even though worn, had been rotated and balanced several times with absolutely NO CHANGE to the wobble characteristics, nor did any of the repair facilities (Dodge dealership and private repair) mention anything about tread separation or out-of-balance problems with the tires themselves.
Now, I *think* that the wobble is still there on bumps, and I am worried about it getting worse. It seems to be more noticeable when I hit bumps with the right front tire. I don't have the engineering understanding of the system, but I wonder if that is somehow related to how the components link up?
I have had a shop check everything out the front suspension and steering components twice, and they are telling me that everything is solid as a rock. Just as a precaution, we went ahead and upgraded the steering stabilizer to a larger one, and that *might* have helped some. The shop (which I have alot of confidence in, but they are not Jeep specialists) is giving me the proverbial "its a short wheelbase Jeep with big tires, blah, blah, blah... live with it, its normal" routine now.
Mac mentioned that the tires probably did not solve the underlying problem and I agree with that. It is really strange that the wobble gets worse as the tires wear (at least on the first set, although I unhappily expect it to happen with this set of tires, too).
This is my 2nd Wrangler TJ Sahara, and the first one did not do this, although I sold it at 36k. I can also tell you that if this one begins doing it again, and I am unable to figure out the problem, I will be in the market for a TK model, which I really don't want to do, because the one I have now is exactly like I want.
Don't know if this helps, but maybe the Canyon wheels and hi-pressure shocks are common to all of our experiences? I would be willing to install the Bilsteins if that theory has validity.
http://www.reese-hitches.com/cargo_carriers.html
Or on e-bay:
http://cgi.ebay.com/ebaymotors/1000-LB-Hitch-Excess-Cargo-Carrier-Hauler-60-X-24_W0QQcmdZV- iewItemQQcategoryZ33653QQitemZ7995685076QQrdZ1QQsspagenameZWDVW
Hope this helps
The shocks are black, and are supposed to be the "high pressure gas charged" ones, but even if they are covered by warranty, it's worth it to me to go out and pay for better shocks. It may not solve death wobble, but I assume it will improve the ride. If you say so, I will accept that 24K is normal for the shcoks to wear, but I'd rather invest in some heavier duty, longer lasting shocks. Kinda like how everyone dumps the GSAs for better tires.
Thanks as always for your expertise and time.
-Mike
Roy Rogers used to have an old Jeep parked in front of his home in Apple Vally (not far from my Dad's house). Not sure if it was Nellybelle but it looked the part anyway. I never did stop to ask but you'd often see Roy and Dale out working in the yard before they got too old and sick.
I plan on picking up XM radio for it, and an aftermarket security system/electronic key system. A buddy of mine installed an electronic system that detects when they keys are near the car so the doors unlock automatically.
I think I might even wake up at 6:30 A.M. and drive to the dealership to see my new Jeep come off the ramp.
Can anyone one help me? Can you tell me the different between the 2005 Wrangler Sport and the 2004. And if I get a 2005 how should I get it equipped, thanks Shawn. :confuse:
If it is the pan gasket, and assuming you were scrupulous in cleaning the mating surfaces, it's most likely that you didn't torque the pan down correctly. Either the incorrect pattern, incorrect setting, or a combination of the two.
There's nothing high tech or out of the ordinary in the way the components fit.
Anyhow, torque settings and pattern of the transmission pan bolts is critical to achieving a good seal. Tightening should be done in a 'criss cross' pattern, first to 6 ft/lbs then to 13 ft/lbs. This is a relatively low figure and most problems arise from overtightening and crushing the gasket. Too many 'shadetree' mechanics assume they can do it by feel alone, which just isn't possible. Not only will a torque wrench do the job accurately, but it will do it consistantly, which is just as important.
It seems weird in driving a pleasant to drive Jeep TJ due to the Bilsteins and Bridgestone dueler all terrain tires that are even quiter than most regular highway tread tires. Also I have not seen any Jeep folks running Bilsteins, I guess it just seems alien to them to run German shocks in a Jeep.
Edmunds started a separate forum just for us to introduce ourselves, post pictues of ourselves and our jeeps.
check it out if you haven't seen it.. and let us hear more about you and your jeep(s)
jeff
I purchased a 2005 Wrangler Unlmited 1 month ago, enjoying it so far. This is my first Jeep.
One thing I noticed is that the Interior Blower Fan (that sends air through the vents) is very loud on full speed when in re-circulate mode. Very much a "brrrr" sound coming from the fan blower area that is reduced when not in recirculate mode. Radio has to be turned up quite a bit to compensate. I believe I heard this in another Jeep I test drove, but didn't remember if it was this loud. So, I am curious - have others noticed this in your Wranglers? Please advise, I did a search and did not see other comments about this.
Second question - any suggestions on "hoists" to lift off hard tops? I have seen 3 products on the Web. The most advertised seems to be the hoist-a-top, but I see that to use it one must leave the rear window fully open, and my garage ceiling has obstacles that do not allow this. The second worked with the window closed but still placed a winch at the rear window area. The best product I have seen is one by Rnventions, which does not involve the back window, but not sure it is the way to go.
I am now inclined to make my own solution. It also seems that the best solution for long term storage is to support the top on 2X4 or larger boards hung from chains from the ceiling, but regardless one needs to use straps or hooks to initially raise the top from the vehicle.
Thanks in advance for any advice.
kevin
It's easy to make your own hoist, either with a hand winch or using ratchet straps instead of the chains you mention.
link title
I'm really only looking for hard wired solutions. Does anyone have any experience with these types of hookups?
Thanks - Norm
That option is not bad, however, it is an FM modulator. If you want to get closer to digital sound then look at the PIE adaptor. I use it for my Ipod and Satellite Radio. The PIE adaptor plugs into the CD changer control on the back of the OEM headunit.
Here's a link to where I purchased mine: PIE adaptor
Well, yesterday Death Wobble happened twice. For you SoCalers, once on the 10/405 interchange. Then again, coming back on the 405 while making a lane change. Typical symptoms. Hitting a section of road with what feels like washboard bumps, then the Jeep bucking violently, shuddering through the steering wheel, feeling like the front end was going to collapse and I was going to careen off the road. In heavy, fast, traffic, I had to hit the breaks, throw the hazards on, and hope nobody hit me; then when the Wobble subsided, get back into gear and accelerate.
Not happy about this. Guess I have to make time to hunt down and solve this problem before my luck runs out. Sadly, money and time are at a premium. I'll keep you updated.
-Mike
This looks like the best option. I would like to do the same thing. However, how do I know if I have the CD Changer controls it requires? I have the basic 2004 dash radio with 4 speakers ( no 7 speaker package). The instructions say you have to have the changer controls to make this work. I do have a mode switch, which activates the CD.
Did NOT need to use my winch or 4 wheel drive here at all (Huntsville), and there is very little standing water around. Given that we are below average for rainfall this year, it has absorbed the 1.5 inches we got yesterday/last night pretty well. We are in Tropical Storm Warning until 10:00 Central time and it is supposed to be sunny the rest of the week after today.
I truly feel for those who were caught in the storm closer or in the landfall areas. It was one nasty beast!
-Paul
Mike
Also, if you've only had a soft top before, make sure any channels or other soft top hardware are removed first. The top needs to sit on "metal" all the way around.
The visors should be out and folded to the side. I also leave my doors open. I'm not sure when the white "pins" first came into use. My 04 has them. They are white plastic "nubs" on the bottom of the top that fit into special holes in the body rail on either side. This also helps you line it up.
Where is it that the top doesn't seem to fit? (Windshield, rear gate, etc?)
So, one style of hardtop will fit '97 to '02, the other style is required for '03 onward.
The install is a piece of cake if you've done anything like it before. You could always pay a professional, though. Took me and a buddy about two hours, but we were also installing XM and a permanent powersupply. You just have to pull the head unit out far enough to plug into the CD changer control. I used doublesided tape to secure it to the firewall.
One thing you need to order with the pie adaptor is a Y adaptor to plug from the PIE adaptor to the Ipod.
Has Jeep done anything to compensate for the wobble in later models? Would an Unlimited have less of a chance of shaking loose due to the longer wheel base? Just curious....
Mark
