Visitor Agreement.
I researched several brands, including MM, TMax, and Warn. For me to consider it, it had to be a name I knew (TMax was the exception).
In researching the facts about the winches, all seemed excellent and decent performers. However, it was the examples of failure or rescue that ultimately swayed me to the winch I got. TMax has the potential to be a great winch if they get the marketing down and get it out there for people to use. It's specs rival or beat Warn in many areas, but there is a HUGE unknown with them.
I am personally not willing to gamble with neither my or my Jeep's safety. If I'm in a pickle, I want to know the tools I'm using will help protect, save, and extricate me reliably. THAT is why I chose Warn. Their warranty is by far the BEST in the industry and their track record is proven. That their product lifecycles are measured in decades and not years says something. The 8274 has been produced for over 30 years with little or no changes.
To trust my tools, especially if I were to go offroading alone, I want the best. I'm not willing to have a potential failure just when I need it the most.
The Champion winch may very well be a MileMarker with generic badging, but the fact that I don't know or can't find out has me concerned. Speed is of little use to me in winching - slow is usually better there. But reliable is even better than slow. I know of a few people who have purchased these winches, but have yet to test them out, so cannot offer real-world advice on that portion.
Whatever choice you make, please be sure to understand HOW to use the winch prior to needing the winch, including having the proper safety equipment (snatch blocks, tree savers, gloves, winch line-weigh down (to reduce damage/injury from snapped lines), etc). You do NOT want to be learning how to use it when your vehicle is hanging by a (steel or synthetic) thread.
-Paul
Again, it's very rare in an unmodified vehicle and I don't see DC making modifications to either short or long wheelbase models for a virtually non-existent problem.
http://home.comcast.net/~1redcreek/jeep/jeepin-toplift.htm
Certainly if you're going to be scaling cliffs and hanging your Jeep by the line, then you want the best heavy duty winch that money can buy. However, those sort of adventures are usually planned for and don't take you by surprise on the trail.
My experience of getting stuck (both of myself and others) has been that a short and gentle pull of a few feet will get you going again. I'd say that a cheap Chinese winch is certainly better than no winch, and as erickpl said, learn how to use it before you need it.
Just to extend the possibilities and make the decision harder, I'm very satisfied with my MM hydraulic 9000lb two speed! :shades:
A bargain winch is DEFINITELY better than no winch, again, I agree. I had meant to mention something about that, but forgot.
But if the means exist to get a higher end, better name winch, then I would recommend that. Buy the best you can afford. If you get a bargain winch, just use it VERY wisely and work to not get so stuck that you risk damaging your only means of escape. Wheel smart!
-Paul
Why would something like that happen? In his case it might have been caused by the (no kidding) five or six 8' panels of chain link fence he had lashed on top of his ladder rack! :surprise:
Be careful out there.
Dave
Just another reason to know your equipment and be all the more careful out there.
Roommate has a cool thing on his Apple. Using the "Dashboard" widget program (OSX 10.4 only I think) he has a program that pops up like a gas tank price display and will find the lowest fuel price based on your specs (grade of gas, zip code, radius, etc.).
-Mike
While I love my bright green Unlimited, I'm beginning to think that I should have just bit the bullet and bought something like the Prius for commuting. The days of spending $20 per day to get back and forth to work sure look good now...
There is a well documented problem with leaving the top suspended by hooks for an extended period of time: the top will apparently distort (spread at the bottom) over time. The common solution is to place a length of 2x4 under the front and rear of the top and suspend it from the ceiling with chains. The weight of the top is then transferred from the hooks to the flat surface of the 2x4's. A google search should turn up a bunch of photos/descriptions of the set-up.
Mike
The photograph shows the hoist I just completed. To avoid spreading of the bottom of the hard top I used synthetic slings to lift the top. One 4-ft sling on each side did the trick.
Hope it helps.
David
Again, use the search to check for specific issues, but feel free to ask anyway on any specifics you may have.
-Paul
I would also agree that if you trade, go up to a 97 TJ with the newer suspension. Unless of course, you have lots of money invested in suspension or other items on your 95. If that is the case, maybe you'll want to go ahead and try to improve the power. Or, maybe you just love the one you have. In that case, money may be a non-issue.
What mileage do you currently get? Maybe it would be worth it to you in the current climate of 3+ dollar gas to get an intake and a cat-back exhaust.
Also, if you don't already have them, going DOWN in tire size (gasp!) will effectively increase the power by increasing final drive ratio and rolling resistance. Most 4-cyl from that era had the steel wheels and basic tires (I think like a 215/75). I worked at a dealer way back then, and they would always order a bunch of those (4-cyl, soft top, steel wheels, manual trans, and no carpet, air, or back seat). It was pretty economical. 22 or so rated mpg, and only about 14k$ out the door.
One of my fellow forum members sent me a link on lubricating the (seven, I believe) zirks, which I feel confident I can do myself (I have a golf cart, so I purchased a lube gun for its lube needs).
My question is; for those of you who change your own oil/filter, do you grease the fittings at each oil change? I don't suppose it hurts at all to "over grease", as opposed to neglecting to do so when needed. Also, I imagine it may depend upon the vehicle's usage conditions (lots of off-roading, mud, etc).
And..since I'm lazy, what is the correct Fram/AC or preferred (other than Mopar, I guess) filter for the 4.0 (2005 model)?
Thoughts, recommendations?
Randy
Yup, you're lazy..................discussed ten days ago, it's an AC PF13.
..........do you grease the fittings at each oil change? I don't suppose it hurts at all to "over grease", as opposed to neglecting to do so when needed.
Every 12k, it's in your handbook. If you overdo it you'll split the boots that retain the grease. Clean the zerk then give one careful pump at a time until the boot begins to swell. One to two pumps will normally be enough.
Mike
In my search, I see the typical WWII gerry cans and their bare bones housing that I'm guessing you bolt onto the back of the Wrangler. Also see newer designed cans, and big time storage racks that go on / over the spare. Some require drilling, some use existing holes.
I don't want to make a huge deal out of this. Browsing thru old posts, I see that Steve once warned against keeping the can in sunlight for extended periods. I really just want to keep it in my garage and hope I never have to load it up on the Jeep. Slight problem that I live in an apt. bldg. with a shared garage.
I guess I'm asking for suggestions on cans / carriers. And a quick guide on safely storing auto gas.
It occurs to me a simple way around this would be to adopt a policy of never letting the gauge get below 1/2. That way, should the stuff ever hit the fan, I've got at least a 100 mile window.
Somewhere in the world, Ed Begley Jr. is sitting in his canola-oil powered Prius saying, "I told you so!!" :P
Mike
Wasn't there some emergency gas in a gel like substance on sale a few years back?
-Mike
In addition to the safety aspect of garage storage, you might want to check your rental agreement and additionally your insurance policy. Give some thought to your personal liability as well, should there be an accident.
In regard to keeping the tank at least half full..............an excellent idea! I always refill at one quarter full, out of consideration to the life of the fuel pump (it's cooled by the gas in the tank).
As I've said before, I never park the car at the house with less than a half a tank. If it's not a brush fire, it will be "the big one," or even just a rolling black-out causing a loss of power in my area. That's one of my ways of being reasonably prepared in an emergency, and it's an easy one for us, since we can't comfortably make 2 round trips to work without stopping. We fill up every day - I think it was Paul who asked a while ago what I spent per month - well now it's gone up to $30.00 per day, and those days of $20.00 per day that I was complaining about look better and better now...
There are a lot of trails up there to run my Sport, and I plan to explore them all.
I do hope you are working a shift that will allow you to miss most of the traffic - won't your commute involve far worse traffic? Are you going to use the Wrangler as your daily driver? If so, I won't mention having a $30 per day gas allowance any more - your's will be worse! Keep up and let us know how it goes.
For anyone new around here - I bought a Jeep, spent most of every weekend in the local mountains, and about a year of doing that, decided to just move there. Now Glen's doing the same thing - just a different mountain range. Gotta love those things that suddenly become important when you own a jeep!
It's tough to complain about the price of gas when there is absolute horror happening in New Orleans, but I had to make a comment anyway.
-Dan
They say it’s because of the interruption of oil and refining in the gulf. Now California supposedly gets most of its oil from Alaska and refines its own gas for the most part. In fact they have said in the past: when our refining capacity is interrupted our fuel prices go up because we can not get our gas from other states because of the additives we must have in our fuel, that other state’s refineries are not required to use.
Now if all this is true why is the oil and refining interruption in the Gulf affecting our fuel cost? I understand California is part of the world market and will be affected by that market, but the market can not be the only explanation when the oil companies are making billions from it.
I am a pretty conservative person. But I believe it is not in the country’s best interest for the market to be used to make huge sums of money from a disaster. I am not saying a profit can not be made. But hearing on the news that gas prices have hit $7.00 plus in the Gulf area where people have lost every thing and have nothing left to give, gives me a chill.
Remember that fuel costs effects whet we pay everything eventually.
Just my opinion
The site takes awhile to go thru but if you don't have the patience at least check out the sections labeled Selection and Design and the Specifications section. (Mac-you may find this interesting) They just finished the journey in July. I am still reading the daily journal (I am in the Boliva section). I have hesitated recommending this because its not directly Jeep related but they do a tremendous amount of off-roading (Jeep related) and alot of their own repairs (Jeep related) that I believe it is relevant to this great site. It is the ultimate road trip-with pictures. Go Easy, John
Right now I start work at 6 am and miss most of the traffic. The evening ride home is not so good. However I am working a 3/12 shift which gives me 3/4 days off a week. I am planning on finding somewhere to stay 2 nights in the OC to limit my driving.
As far as snow I am not sure what the snow fall is like there. People tell me it’s not that bad. It’s not like the Big Bear area (witch is about 18 to 20 miles away and several hundred feet higher).
The good news is that the street we are on dead ends into the County yard where the snow plows are stored. So our street will be one of the first streets plowed.
If some one can give me (or tell me where to find) instruction to post pictures I will post a few of the property to give you a feel for what it looks like.">
I absolutely LOVE the compact-ness of the Wrangler, I can squeeze just about anywhere. It's a great Jeep, and I plan on having it for many years to come.
About emergency gas options, I'm also considering a siphon. Not to steal gas mind you, but I figure if the family has three cars, and we ever have to get somewhere in an emergency, we're probably all going to pile in one car. So that's two extra tanks I can siphon out of to at least get full before hitting the road. Siphons are legal, right?
-Mike
We're testing a photo upload thing here, but no word on if or when it'll go out of beta.
Gas was $2.76 last Thursday here in Boise, fwiw.
