Visitor Agreement.
Overall, I'm very impressed with the Jeep. I like to sit up higher so Jeep wins that round. No comparison between the two interiors though, Cadillac wins that one hands down. Both exteriors I love, so they're tied. I plan on keeping both, it seems to be the best option.
Edge wear is often a toe problem, though it can be camber or caster related. If it's equal on both tires it's likely to be toe, one side only points towards the camber of that wheel, while wear on one tire with a pull on the steering as well indicates a caster problem. The only way to tell for sure is an accurate alignment by a specialist.
Cupping can have many causes including worn shock absorbers, snatching brakes, incorrect pressures and infrequent rotation. It can also be indicative of a manufacturing defect, but that won't also be a cause of edge wear. I agree that you should get more than 40k in reasonable conditions, but before you can take this further you need to be aware of the alignment figures for all four wheels.
The pressures have been maintained at 30 - 32 PSI according to Jeep on a regular basis. They have also been rotated every 5,000 miles. It tracks straight. I also had the shocks checked by the same dealer and they are supposedly OK.
I'm leaning toward a manufacturing defect from everything that I have seen so far.
The idiot at Goodyear was the manager of the local Goodyear service center. I don't believe it is a Wrangler problem as there are so many on the roads.
One constant reminder during this time (late 80's and 90's) was NEVER to pass on the right! It is strictly forbidden! When we had German colleagues living in the States for a period of time, I re-heard all these same concerns, especially about passaing on the right. They would actually "white-knuckle" it when they were a passenger, and we passed someone on the right on an interstate. However, after they had been here a while, driving, and realized that the entire US highway system would be moving at 45 mph if we left it up to those left-lane hugging morons that we have an abundance of.....well, they took up passing on the right as well. I'm sure they still cringed, but at least they understood!
On a Jeep-related note, I guess I've never flashed anyone over from the fast lane here!
Y.H!
Gary
Since both Jeeps were Saharas, I am wondering if the shocks could be the culprit? I think the shocks that come on the Sahara are optional on all the other models, so there would be fewer of those on the road, so many Wranglers would not exhibit the problem.
-Mike
Oh, almost forgot, yesterday a driver in front of me was all over the road. Swerving, etc. Obviously not paying attention. So I got alongside to see what the deal was. They were eating an ice cream sundae in the driver's seat.
If I'd had my clinometer, I would have thrown it at her.
-Mike
Also, because GSA's have an asymmetrical tread pattern, they often appear to show greater wear on the outside edges when in reality it's just a function of the finer and shallower tread in that area.
embeeduece, keep us posted on your experience. I've already mentioned that my death wobble went away after putting on new tires, but I feel like there is still something wrong - just no one can figure it out, and I have a hard time articulating exactly what is wrong. My mechanics are telling me the front suspension is tight as can be, and I keep getting the standard "its the way Jeeps are; ...big tires... short wheelbase, etc. I am expecting the death wobble to gradually return as the tires wear unless I can figure out something to fix it.
I checked the build sheet for my current 2001, and it specifies that it was built with SDUP, Suspension, - Heavy Duty w/ Gas Shocks. I also checked the window sticker and at least at this particular time, the 30" tire and wheel group came with the high pressure shocks. Standard items for Sahara list "Shock Absorbers - Gas Charged" but I don't know if those are the same. Anyway, time to stop beating a dead horse. I don't know what my 97 wrangler had other than the Tire and Wheel package.
There is no doubt that the GSAs have shallow tread on the outside, but there is no doubt that both my Jeeps also cupped the tread in that same area. Maybe it does have something to do with toe or camber?
Maybe, but it could be to do with the rotation interval and pattern. Were you following DC's recommended pattern of switching the rears straight to the front, then the fronts diagonally moved to the rear?
I rotate my tires every 3k (when I change the oil etc.), and when I had GSAs I would always get a little noise and vibration afterwards as they wore in to their new positions. I never noticed any cupping for the life of the tires, but it could be that it was present in a very minor way but was 'cleaned up' at every rotation.
This has me even more confused.
After having the doors off for a few months, I decided to put them back onto my Wrangler this afternoon. Everything went well, until I put the nuts back onto the door hinges. When I tightened them, I gave one of them a few turns too many. Now it seems that the treads are stripped. I tried unscrewing it and it just turned and turned without getting unscrewed.
Is there anything I can do about this? This apparently is not an emergency situation, as I don't intend to take the doors off until next summer. But I sure would like to be able to have them off again next year.
Any help would be greatly appreciated!
Ray
That's why I always do it myself!
If you want to include the spare in the mix always switch it with the same tire (I use the right rear), after the others have been rotated.
Some people even cut the threaded portion of the hinge bolt off, so that there is nothing protruding below the hinge. I didn't go that far.
Tomster
Have you hugged your Jeep today?
Obviously a lot depends on where you park, and having the doors properly secured will only slow a thief down to a limited extent, but when you consider the cost of replacements then every little helps.
Sorry Tom, but I'm feeling cynical today!
1: Block pattern tires. Tread patterns that wind uninterruptedly around the circumference of the tire tend not to cup. My GSA's cupped, but the Michelins I now have (with continuous tread "ribs") don't cup.
2. Unidirectional force. My rear cycle tire did not cup, because it was subject to forces in both forward and reverse directions, but my front tire always cupped, because the only force on the front wheel was the braking force. Thus, the tire wore unevenly in the direction of deceleration. In my YJ, the front wheels experience braking force without significant acceleration force (little 4WD time) while the rear wheels see a blend of the two opposite forces. Is it possible that a GC would have full-time AWD and thus see both forces on all 4 wheels, thus cancelling out any cupping tendency on the front tires (in contrast to my part-time 4WD set-up on the YJ)?
1: Block pattern tires................
Takes me back to the Dunlop TT100's I had on my Norton Commando (many years ago)!
Actually it's as good an explanation as any, and would also explain the benefits of correct and regular rotation.
-Paul
Alan in the desert
-Mike
Alan in the Desert
(PS: Please don't SHOUT!)
Jeep Unwraps 2007 Compass and Patriot (Inside Line)
Alan in the Desert,
soon to be in the mountains.
My wife and I will be doing a ski trip this year, but not sure if we'll hit Mammoth again or go someplace new (for her) like Colorado. I REALLY like Crested Butte and the Rockie Mountains...
-Paul
Road trips will probably take us to Hot Creek for some theraputic soaking and some jeeping up by Lake Mary. Maybe a trip by the Postpile if time permits. I always take my wife away for our anniversary. I used to go to Catalina every year but the annual art show and the Seagrams marlin tourney coincide with our anniversary and Avalon just gets a little too busy for my taste. Its no fun waiting an hour to get your Wiki whacked at Luau Larry's, if you know what I mean.
Bishop and parts north this time of the year however are perfect. Tourist season is about done for and the crazy skiers haven't materialized yet. Lots of antique stores to peruse and a great restaurant at the resort if we don't feel like cooking in the cabin.
Yes I'll take pictures and put them up at the Bucket. Y'all have fun while I'm gone.
Alan soon to be in the mountains
Harlan
Anybody know a fix?
Terry
Try doing a refresh on the starting page and see if that helps. Are you "subscribed" to this forum? If not, try it (using the "subscribe" button below). Then you can come directly to the forum showing the most recent postings.
-Mike
We like Whiskey Creek in Mammoth Lakes. Good food and great service!
Hope you get to take your jeep on some nice trails! I look foward to your pics.
-Paul
here is a link to bestop.com installation guides. they make replacement tops for jeeps. if you can find the type of top you have, i assume you can follow the instructions in reverse.
jeff
1. Pull the top up so the front edge of it is near the windshield.
2. Attach the hooks into the header, but do NOT tighten them down all the way. Make them as loose/long as possible. Then pull out the long plastic side clips that sit above each door so they are not squeezed between the top and the door surrounds (2 per side). Do NOT attach them at this time.
3. Verify that the web strapping on each side (between the middle bow and the rear) is flat and not twisted.
4. Pull down on the rear bow and attach the rear vertical corners (plastic pieces under the fabric) into the lip surrounding the back of the tub.
5. Attach Rear window completely.
6. Attach side windows. This is a lot easier if you hook the back edge of the window (the flap that ultimately covers the zipper track) onto the velcro to temporarily hold it straight and level while starting the window zipper. Once the zipper is started, only zip up an inch or two. See step 7.
7. Insert the front edge of the soft windows into the groove of the door surround. Make sure the zipper is only started an inch or two. Once in the grooves, zip the window the rest of way and tuck in along the bottom.
8. Fasten down the header hooks that you loosely attached back in step 1, bringing your top tight against the windshield header.
9. Attach the 2 long plastic clips (per side) that you pulled out from under the top back in Step 2.
10. Drive.
-Paul
Another neat place to eat is at the foot of the Tioga Pass road. A Mobil gas station there has an international chef cookng for their deli...Lobster taquitos anyone? Cajun food is tops too!
Loading the Jeep commences now!
Alan on Hwy 395
You can get the Owners Manual for $10 from here: DCTechAuthority
It's also the place to get the genuine Factory Service Manual and other technical data.
I lifted my TJ three inches with a Terraflex suspension lift and that's when the problem began (I also had a warm winch on front).
I went round and round trying to figure out the source. In the end, simply adjusting the front caster fixed it. (i.e.-move the axel forward)
this link explains wheel alignment pretty clearly:
http://www.familycar.com/alignment.htm
He has had arthritis in his left front leg for a long time, but this thing with his hips just came on today. He has had a little bit of stiffness in his hips for a while, but nothing like what he has today.
I'm scared. He is ten years old, and I'm so afraid that this might be the beginning of the end for him. Please, my friends, pray that there will be good news when I take him to the vet tomorrow. I would have taken him today, but he wasn't this bad when I left for work this morning.
I cannot imagine life without my Best Bud. How will I ever be able to go wheelin' again after he is gone? I would look back to "his spot" in the back of the Jeep and not see him there. It would tear me to pieces.
Please, please, keep us in your prayers, and I will let you all know how things go tomorrow.
Tom
