Visitor Agreement.
Tires, rims, brake drums, wheel bearings, and propshaft are all moving items in the rear that can cause a rubbing noise under the right conditions.
-Paul
Can the Rubicon axles be upgraded to 4.88 and still retain use of the factory lockers?
What would be involved to do that swap from 4.11 to 4.88?
-Paul
Does anyone know how to remove this handle and adjust it? It looks like it's held on there with a clip, but I don't want to screw anything up...
If you wanna see how it attaches, just check out a replacement crank at a local auto shop like Autozone...
-Paul
BTW, I took Tom's advice and bought a TJ-specific mounting plate on eBay. Saved me a whole lot of work trying to fabricatre something. Thanks!
Mark
It's actually a good idea, but you'll find one of the correct amperage quite expensive. You'll find that they're commonly used for similar applications in the marine world. You might also want to consider a high amperage switch or continous duty solenoid located, as you say, close to the battery on the positive lead.
Changing the gear ratio involves changing both the ring and the pinion gears. Ideally, new bearings will be fitted at the same time, and of course the new gears will have to be re-shimmed to give correct pinion depth, backlash, and tooth contact.
I have a question for some of you mechanically inclinded people (Mac and co.);
As the weather up here in Windsor is starting to get cold, especially in the mornings, I have noticed some trouble with my clutch/tranny on my 97 tj in the morning, or when the vehicle is 'cold'.
When shifting into second gear (manual) the tranny grinds, sometimes a little bit, sometimes a lot. I am forced to slow down, downshift to first, then try again, which usually works. Second gear just doesn't seem to be friendly when the weather and car are cold. Once the vehicle warms up, it shifts as new, as it always has. The first shift is usually very harsh (into second gear, that is), and the next few seem to still show some resistance. It only happens in second gear, and when the jeep is cold. I had the tranny fluid changed this past summer, so that couldn't be an issue.
Anyone have this happen, or have any advice? Is my clutch, tranny on the way out?
Ryan
Speaking of semi's, you might look this up for giggles. A woman here (Gladstone Missouri) ran right into a stopped one the other day while on her cell-phone. Seriously. Witnesses said she was so engrossed she didn't even see it.
The only real fix is to strip and rebuild it, but as a tempory measure there are two things you can do. First, is to refill with a synthetic gear oil. Second, is when you start in the morning put the transfer case in neutral, then start the engine and engage a gear, making sure the parking brake is on of course. Run the engine with the transmission engaged like this for three or four minutes, which will heat and circulate the transmission oil.
Finally, when you previously had the oil changed, it was a GL3 and not a GL5 wasn't it? The sulphur additives in a GL5 can eat away at the brass syncro rings.
I had the fluids changed at my mechanic's (very loyal to him, he's seemed good n' honest throughout my previous two cars), so I'm not too sure, but I left him the owner's manual and he said he added everything that was recommended.
I will switch to synthetic blends (most of my fluids, actually) the next time I have them changed, perhaps in the spring. Until then, I will try you other advice, which I am sure should help, since it only has this problem when cold.
Again, thanks very much!
Ryan
For a period of a few consecutive years the owners manual called for the wrong lubricant for the manual trannies, and I'm almost positive that the 97 model year was one of those years.
You might do a search in here on this subject. DC never admitted their mistake, but they changed the recommended lubricant at some point.
There is some additive in GL-5 that eats the brass synchronizers, as Mac stated.
So, following the owners manual would result in the wrong gear lubricant being used for certain model years.
Tom
Have you hugged your Jeep today?
P.S.
I just did a search on "GL-3," and several posts from October 2003 came up. It appears that the wrong lubricant, GL-5, was specified in the 1997 owners manual. Beginning with the 98 model year, DC recommends GL-3. Apparently this problem with the wrong gear lubricant being recommended goes back even into the YJ years.
Are there any other 14" wheels from Dodge/Chrysler that fit the Wrangeler?
Thanks, Kreis
Thanks for clarifying; I had no idea, and I suppose that's what Mac was getting at. Better get that changed ASAP and hope no damage was/is done. Thanks for the research, Tom, I really appreciate it. That's why this board is the best! What a great bunch of guys/gals!
Ryan
Regarding the GL3 gear oil for my manual transmission...
Where can I get it? I looked all over this morning, hoping to get the correct fluid for my tranny, but nobody carries GL3. Best I could find was GL5 synthetic.
Again, any help is very appreciated.
Ryan
Anyone have any ideas what kind of struts are on the Wrangler? Also, anyone have any idea what is involved in replacement, if needed? I thought about taking it to my local Jeep dealer.
Since I am new to Jeep ownership, I would appreciate any thoughts on the subject.
Thanks - Chuck
Wranglers have shocks, not struts. Wranglers have a solid front axle, not independent suspension.
You could have a hub/bearing assembly going bad. Something could be loose in the suspension. I would get it checked out by a reputable mechanic, Chuck.
Mac, your thoughts?
Tom
P.S.
Just thought about this one... loose lug nuts? Chuck, I would not drive that Jeep too far or too fast until you get it checked out.
Ryan, do some checking, but I THINK there might be some GL-5's that do not have sulfur and are safe for yellow metals. Not sure about that, though. Mac?
Tom
As Tom also said, you have a traditional solid axle and coil springs, not struts.
Tom,
Excellent call on the wheel. (Should remind us to always check the simplest things first.) A shift and the dull thud could very well be the wheel moving on loose lug nuts. You would think we would notice that kind of thing, but I've had it myself! I purchased a used Audi GT years ago, and finally felt the front end vibrating and occasionally making a thud. Found the right front lug nuts loosening almost off the studs! They were probably that way when I had bought it, but I never checked. Somone may have taken the wheel off at the dealership, then not tightened them back down properly. You never know.
Either way, a possible problem with the front suspension is a "non-driving" issue until you find it. I've also lost a wheel to letting a ball-joint failure go to long on another car, so I can attest to how scary it is when the front suspension lets go at speed. Get this checked out soon.
The Bestop soundbar looks interesting, but (of course) it's the most expensive of the ones that quadratec carries. Any ideas?
I've been "lurking" here for several months, and have read this board almost daily since. Also, I've read over half of all the messages.
Well, I finally made it official (I bought my Rubicon last weekend
With rebate, I paid $25,879 + 6% tax & $75 doc fee (MSRP $30,500) from McGonigal Jeep in Kokomo, IN.
I live in NJ, but with a $138 flight to Indianapolis, and the benefit of getting to drive my new Jeep home (~750 miles), I thought it was a great deal! Also, McGonigal picked me up at the airport.
I now have about 1,400 miles on my Jeep - been driving it every day - and I absolutely love it!
Yeah, I had to get used to the quick response of the steering, as compared to my other vehicle, a GMC 2500 HD Extended cab, but the ride is better than I expected, the mileage is better than my truck, and it's so much fun to drive!
As you can tell - I love it!
The details: 6-Speed, Dual Tops, Speed Control, Security Package, 6 Disk CD, Floor Mats, & Locking Fuel Cap. Deep Beryl Greem with Dark Slate Gray interior. Everything else standard Rubicon.
I won't post often, as I'm not as well versed as all of you, but I will continue reading nearly every day.
Now to save up for all the modifications... :shades:
Thank you all.
Art...
The reason I'm asking about 14" wheels, is the Wrangler I'm thinking of getting has a SOA suspension lift, 3" body lift, 33" tires and the 2.5L engine. I'm possible going to be towing it a long ways (750 miles) with my car (Dodge Intrepid). The smaller wheels and tire, hopefully, will make for easier towing by lowering the JEEP. Not only would it be more aerodynamic behind my car, it would also reduce the angle of the tow bar.
Even if I don't tow it, and wind up driving it, the lesser wheels and tires should significantly improve fuel economy.
As far as any interference is concerned, such as brake calipers, I'm not sure. Stock 15" Wrangler wheels have a low to medium offset, so I'm thinking there shouldn't be any interference. But, I'm not sure, that is why I'm asking. It would be best to play it safe with the 15" wheel, and perhaps a lower profile tire, but if anybody out there has more experience/information, I would greatly appreciate it.
Steave
How bad is it if I were not to run our second vehicle more than once in two weeks? It seemed like GiGi wasn't real interested in starting this morning - she sat for a full 2 weeks. It never used to bother the Sport much - he always started right up (except when the 6 year old battery finally failed). This was the first time that the Unlimited has sat for more than a weekend in the 13 months we've owned her.
Another question (besides the question I asked earlier about the sound bar) - how difficult would it be to put cruise control in the '98 Sport? While the thing I miss the most (after the XM radio) is the outside thermometer, my other half really would like cruise control. Is this something I should talk to a dealership about?
I have to suggest against this, but I know you'll have to make your own decision. I used to work for a Chrysler dealer (when the Intrepid came out in 93) and I can't believe that it's rated to tow that much. It's a unibody, with nowhere near the braking to bring down an extra 4500 lbs. And, where would the 33's go while you were driving?
I hate to say this, but you need a truck. Or, just drive the Wrangler to destinations. I think you could get a 14 with small tires back in the YJ days, but maybe I'm mistaken and they were just steel 15's...
LOVE the color (check out my very similar photo a couple pics back).
I found my LJ at a carmax while shopping for a new one. At the time LJ's were VERY new, so I was pretty pleased to save a few thousand on a Jeep with less than 10k miles. Little did I know about the employee pricing to come!
Anyway, I waited one full night thinking about it, because I really wanted black like my first YJ. I'm glad I went ahead. The Beryl Green looks great with the black top and accessories. Sure would like a set of those excellent Rubicon wheels...
Welcome, and post all you want. Gets quiet in here on Saturdays...I can use the company!
Two weeks isn't too bad, it was probably reluctant to start because the battery was down a little and everything was cold. What's the temp where you are at the moment? If you're going to leave it regularly though, you should get a trickle charger to keep the battery fresh.
.............how difficult would it be to put cruise control in the '98 Sport?
You can get a factory kit (Mopar) to do this yourself, though I don't think dealers list it any more. It's very year specific, with a different spec kit for each model year. There's a brand new one for sale on eBay at the moment, '98 Mopar Cruise Control Kit, for $199. Comes with everything needed including instructions. If I was in the market for one I'd grab it. I've no connection with the seller apart from having bought something from them once.
WELCOME AND CONGRATULATIONS!
That is one fine looking Rubi!
Sounds like you are totally happy with it, but that's not surprise, is it?
Now that you have broken the ice, keep on posting. We want to hear all about your early days with that Jeep and all the fun you are having.
Tom
Nah................I just know a little bit about a lot of things.
As for the Lottery numbers, that's easy, just go here. :shades:
