Chevy Silverado/GMC Sierra - Owners hangout
My 88 Ext Cab w/the 4.3 had 88k on it when I started towing a 19', 3500 lb. travel trailer, the tranny went at 112k.
Ray T.
Sounds like you recomend moving up to a bigger truck.
kip
Another thing too on my old 88 was at 85k had to rebuild the motor, was using qt.of oil every 200 miles. I think my volunteer fire/ambulance dept activity had a lot to do with that. When your on call during the winter months and it's -20 outside the truck only had 30 seconds to warm up before I blasted off to make the 4 miniute response time, that took a toll on the motor. The 4.3 has been around for quite awhile though and is a dependable one.
Ray T.
3,000 isn't a lot, but day-in & day-out w/steep hills & high mileage thrown in does give me a little concern. I really don't want to invest in a new(er) truck just yet.
Ray T.
A friend has the 2500HD, 6.0L, 4.10 and the best he can ever get is 10.2 MPG. The 2500 HD is a little heavier, don't think it would change the MPG that much with the 3.73.
http://autorepair.about.com/cs/productreviews/fr/aafpr052002.htm
Good luck!
Ray T.
I am getting things ready for this spring (when it gets warm again). You said you replaced your brake fluid. How did you do it? Sucked out the old fluid and put in new? What kinda fluid did you use and how much does the reservoir hold?
Thanks man
Now my question.
Would anyone have any concerns with buying a 2001 1500 Extended Cab 4X4 Z71 with 65,000 miles on it? If I am right this truck should get me to 200k if taken care of properly right? Also, the repairs should be pretty easy and cheap, right? or at least cheaper than a Toyota, foreign, etc.?
Last question. Does this truck require Premium fuel or can you run it on Regular?
Thanks for the help.
Ray T.
(BTW there are only a couple of companies that actually manufacturer this stuff, everyone pretty much packages it in their own bottle. Bell Chemical Labs is one that I think I remember that is a main supplier.)
Using a piece of clear plastic hose that is the right diameter to fit snugly over the bleeder valve, and the other end into a jar with some fluid (about 1/2 inch in a typical large "jelly" jar) set up a siphon on the RR wheel caliper bleeder. When the fluid runs clear in the hose, you're done. Watch you don't run the reservoir out of fluid...just check it a couple of times... should take about 15 min to clear the line.
Then go to the LR caliper, then the RF, then finally the LF. When the clear hose shows the fluid is clear then move on.
Take your time and close the bleeder valve before you remove the hose. Sorry I didn't take any pictures, but I think I have a drawing that I can send if you need it.
Have fun,
matthew
No flame just want to keep the record straight.
matthew
1. Rattle feeling in steering wheel when going over bumps - Intermediate steering shaft replaced.
2. Single loud clank sound from inside driver’s door when rolling up driver’s window - Regulator unit in the electric window replaced.
3. Occasional clunking/jolting sound/feeling from back end when braking & almost stopped, or when releasing brake from a stop. - Replace yoke in drive line with upgraded one.
These three problems were all fixed under warranty and now the truck is back to being perfect, just like it was on the day I bought it new.
With regards to the fuel, I always use 89 octane from Chevron or Union 76, with no knocking or pinging even when towing. GM recommends you use 87 octane.
Hope this helps.
-David
I found something funny that mine doesnt clunk when the truck is in auto or 4 wheel hi.
You might try eBay also. Do a search on Silverado as well as Sierra. Might find one from truck being parted out.
Hope this helps
matthew
The silicone I use in my classic car but that was only after flushing everything and changing all rubber parts. It will not absorb moisture like the regular brake fluids do and the ole classic sits for longer periods in a garage w/dehumidifier to help control the enviorment.
Ray T.
Talked to my youngest brother again this morning, who I mentioned before had installed it in his, and he is still happy with it. We bought identically equipped trucks (me - 02 GMC/him - Chevy)two months apart, he has over 100,000 miles on his, I'm at 49,000. I installed the K&N FIPK, him the K&N OEM drop-in. Both are running FlowMasters. His last two tanks have averaged 15.3 in and around Houston. I'll give it a go and see what happens. Will let ya'll know how it works out - good or bad..... Happy Holidays to all!
I took a quick look at the point where the top radiator hose goes into the engine - and it did not look like it was the "normal" set up.
Does anyone know how to replace the thermostat in the 5.3L ?
DOT 3 401 Degrees F Dry 284 Degrees F Wet
DOT 4 446 Degrees F Dry 311 Degrees F Wet
DOT 5 500 Degrees F Dry 356 Degrees F Wet
Silicone brake fluid falls into the DOT 5 range. There are some alternitives to the adverse situation of a spongy pedal with silicone. \
When I was involved in FRAM/Autolite motorsports, I ran across Wilwood 570 which is a glycol fluid with a 570 Degree Dry point. Their website,
www.precisionbrakescompany.com/wilwood_brake_flu- id.html,
also lists a EXP600 fluid with 626 Degrees Dry and 417 Degrees Wet points. As one might imagine a price to match. (sorry you'll have to copy and paste, I forgot how to do html ref's in this),
Incidently, A wet boiling point is reached with about 4 - 5% moisture absorbtion.
I guess it costs money to go fast (or stop quick), how fast do you want to go (or stop)?
matthew
Any thoughts on this? If this is common and I've just never noticed it before I don't want to spend $185 for them to tell me that they can't find anything wrong.
Ray T.
sounds you are hearing, are they like a clunk-clunk?
The fix is to slack all of the crossmember bolts, then retorque to factory specs. The crossmember is the one that gets in the way when trying to change the trans filter.
however, the procedure sounds way too difficult for the Dealer............better to send the truck to the islands and have the pro work on it........
good luck on this one now!
All they did was replace the yoke, no fluid was replaced as far as I know. Problem is 100% gone.
As for the intermediate steering shaft replacement, the dealer use to just rebuild them using that special new grease. But after too many complaints that the problem would come back after awhile, they started replacing them rather than re-greasing them. No more complaints.
-David
seelig- got enough of them trucks here. don't need no more especially them creakin ones. lmao
I looked on the net but I was wondering if any of you have one.
I noticed that a Palm is needed or a link to your PC and also a hotsync cable. I can't figure out what is the best way to go.
From what I've seen on their web site, you could read and clear the DTC's going on in the OBDII, view in real-time the sensors data and many other things.
Any input to guide me in the purchase would be greatly appreciate. Thanks
Stef
stef7
I've had the autotap for a couple of years now. Depending on what you want/need it for, it pretty much does all that I need and in some cases it does things I have no clue on. Wish I could be of more help.
Stef
Stef most all scan tools are read only. The only ones that I know of that are bi directional are the dealership/OE proprietary scan tools... $1.5k + plus updates... ouch... if you want to do some modifications to various parametners, the aftermarket chip/plug-in devices seem to work OK.
matthew
with that earthquake.
http://www.jdsperformance.com/index.asp?initemuid=516&fcmd=it- em&inmake=all
http://www.granatellimotorsports.com/predatorgmtruck.htm
Everyone finish their xmas shopping? I finished today. Took my truck in for emission testing (darn indiana laws) then went and bought the silverstar fog light bulbs
Happy holidays everyone
