Chevy Silverado/GMC Sierra - Owners hangout
Ray T.
Did your 2000 vehicle have the locking rear axle? Your Z71 has a locking rear axle. When one rear wheel spins 100 rpm faster than the other (at speeds under 20 mph), the rear axle will lock so both rear wheels spin at the same speed. When the rear axle locks up, it can make a noticeable clunk/jolt, especially if you are accelerating quickly. The clunk you feel may be the rear axle lock-up, not the engagement of the front drive axle.
truck been sitting outside .. I have this annoying rattle near my passengers airbag area .. if I pull slightly the pull bar on the passenger
side of the dash the rattle goes away .. it
eventually (the rattle that is) goes away also
when the cabin area gets warmed up ..
I'm curious to see if this is common on '03's and
what you did to resolve ?
Thanks in advance!!!
When going downhill at interstate highway speeds with the cruise control engaged, I can feel hesitation/surging, like the cruise control unit can't figure out whether to accelerate or not. Feels like a miss in the engine, but it has to be something related to the cruise unit. Doesn't happen without cruise on.
Any thoughts? Probably going to get blank stares from service dept. when I take it in.
Mikey
Ray T.
-David
Another issue I just had happen. It's cold and snowy and damp here (SW MO) and my truck wouldn't idle. Never had that before. Of course, it wouldn't duplicate that when I took it in this morning. I don't know if there will be an on board diagnostics code from it. I'll find out later. Right now, the RPM's are running a little low (500) at idle. Since I have all of 24k miles, this one should be a warranty issue, but has anyone else had this happen?
Your thoughts would be appreciated!
I have also had to have it in because the four way flashers would come on when I activated the left turn signal.
I now have to bring it back in because the heated mirrors do not work on passenger side.
Had to have the tires rebalanced because of shaking.
I also have the 2to3 and 3to2 klunck in drive line.
Mine also idles at 500 RPM but I find it idles way too rough(dealer says it is normal).
Believe it or not I still love the truck, drives beautiful; took it on a 3000 mile trip last fall; Four guys, two ATVs plus gear approx 1500 lbs on the truck and 2500 lbs in the trailer. It performed admirably and took $200 less gas than a Nissan Frontier Crew Cab on the same trip/load the previous year.
Only problem was that the truckers wanted to run me off the road because my headlights were aimed too high. Dealer said they were aimed to specs but lowered them anyway because apparently almost every owner of that vehicle had the same complaint. OK now.
I drove the truck and it is sweet but is only under warranty for another three months. Can anybody tell me if this a good truck or not? Are extended warranties worth the cost? I am alos looking to change the tires form the Firestone Wilderness ATs to the Bridgestone Dueler AT Revos and wanted to know if anyone has any thoughts on the swap? I live in New England so I see all sorts of weather. Tahnsk in advance for your help.
Hopster
"Buss Interface by gmhellman Feb 01, 2004 (1:23 pm)
I checked with my professional radio installer and he said that basically the radio has a buss interface which lets all the chimes run through the radio and speakers and helps to reduce the number of wires and parts that go into the overall model. This unfortunately makes it almost impossible to remove the chimes like we used to be able to do in the past by simply cutting the wire to the chime. He does say good luck in finding out how to change/delete the individual chimes and if you do accomplish it, let me know so that he can do it."
Just wanted to give you an answer to your problem. Go to www.jpcustoms.com and look for 2003-up Chime Module. The CM1 retains the warning chimes when you replace the factory radio that have the warning chimes built into it. it is $29.99 and I know it will solve your problem.
As for the Bridgestone Revos, I think you will really like them. I put them on my '00 Rado Z71 this past August. They are great in the snow.
One thing I would caution you on, see if the truck has a limited slip rear. If it doesn't you will have some problems when stopped on wet surfaces. If you step on the gas a little too quickly you will have a tendency to spin the rear tires. Not a good situation when you think you have time to pull out into traffic and the back end starts spinning on you. Just my 2 cents. I have the standard cab with over 45k on mine and have had no major complaints. Only problem was to have my sliding rear window replaced(cracked seal around the molding, replaced under warranty), and the shims installed in the back end. I think there was also a small recall notice. It is a good truck and gets good gas mileage, better mileage than the Dodge Ram gave me.
Okay 2000 miles with them now, still happy.
Handle great compared to those Firestone Wilderness,.
Regarding the YOKO's I still have not seen them in person, Is the price around the BFG's ? If so maybe next time. But anyway if anyone does not like the way their 1500 4X4 ext cab handles, get rid of the firestones and go with a heavier side wall ! It will bring tears to your eyes !!!
Looking at www.tirerack.com the Yoko's go for $50 less than the BFG's.
Good luck
http://www.paceedwards.com/rolltop.asp
The highlights: GTO, C6 Vette, 2500HD CC Dmax (awesome truck) Anyone have $80K they could spare me for a dmax and gto (well i need something to pull it around with haha)
Lowlights: nissan titan and ford F-150 doors/handles. Man they feel CHEAP! and chinsey.
The new F-150 extended cab windows are pretty cool. They actually roll down. Also the colorados are pretty nice. They are a nice step up from the S-10s.
am thinking of switching to dino...........should there be any problems with doing so?
http://www.blackstone-labs.com/index.html
BTW- you might ask the same question over at Town Hall > Maintenance & Repair. Some of those people are certified fanatics about oil.
-David
with the Silverado, i'm torn as to which way to go as well as i know a fellow who has gone back and forth as well and he claims that his 5.3 has the clod knock when using syn, and it's gone when using dino.
like Dean says though, it may not be a good idea to switch to dino since the engine has been on a synthetic diet since 5K miles.
before we got rid of the wife's truck i had switched it back to dino and it stopped consuming oil to the tune of 1 qt per 3K miles when it was using syn.
with my '00 however, it has yet to need an ounce of oil between changes even when i've gon 8 K miles without changing.
-David
broke it in like i use to do my rice grinder motorcyles.........little high speed then back to a decent cruise speed, then back to some high speed, then etc.......
funny thing is that it's got the diesel sounding lower end (especially noisy at drive thrus).
the wife's was quiet but burned the oil.
i changed oil at 1K miles and then every 3K till it hit around 40K and always been Mobil 1 since i made the switch.
Ryan
One service call on a 4l60e and you are in for over $1k.
If you are picky about how your truck runs, I would suggest getting one. The last two trucks I have owned, I purchased extended coverage. It paid for itself in spades both times.
Just remember the cost of the coverage is negotiable. They mark it up alot.
I'm gonna take my chances on future vehicles and buy nothing but the vehicle, no more ESP's for me unless I can get a deal like Obyone did. LOL !
Ray T.
when i bought the wife's Jaguar this year, the dealer told me not to waste money on the extended warranty.
i'll keep my fingers crossed.
I average 12.5 city and 16.5 highway with the 6.0 and the 4.10 gears. I was thinking of trading it in on a 1500 with a 5.3 and 3.73 gears. Can anyone tell me their mileage for this package? Also I noticed that when I am at a stop and if I am about to make a right or left turn I hear a small vibration noise for a second under the vehicle - but not if I take off without turning. Can anyone identify this? Thank you.
any help please?
my'00 with 118K miles on it will spin the rears all day without a huge load in the back.
but since you're truck is new, i don't see why you couldn't get it checked out.
