Chevy Silverado/GMC Sierra - Owners hangout
Chris
Thanks to obyone, too, for his input.
I can't hear the sound it makes and that makes it more difficult to figure. Has to be one of three things. Either shocks, springs, or limited slip. Again, it depends on the sound it makes. It could also be a combination. I would have another dealer look at it, checking the springs and shocks first. I would think a tech would be able to tell on a test drive. Not sure if your current dealer is motivated enough to help you out.
http://www13.inetba.com/mrbobsdistributing/promotions.ivnu
I heard the same thing about the Granatelli and the HPIII. I installed the Granatelli about a month prior to the HPIII. Disconnected battery for half an hour when installing the Granatelli. Month later installed the HPIII programming and had no problems.
I have hear about TRUCKLOGIC for a bugshield and PERMA-TECH or LINEX for a spray in liner. Has anyone purchased these products.
$49 for the bug deflector
$375 for spray in
pics
http://www.picturetrail.com/ryanbab
pat
- Tim
- Tim
You could also do a search on this site as someone there has done it and can give you the part nos. and details:
http://209.35.112.209/performance/discussion.html
Had a painted bug deflector on my 99 GMC. Looked good , not cheap about $98.
Hope this helps
- Tim
I am now curious about the bumpers - Post #476 stated that people still buy bugshields that require bumpers because of lack of info. Are there specific bugshields that I should NOT buy for a 2001 GMC?
('01 2wd Silverado) Lower balljoint to spindle nut,& tie rod to spindle nut, rear leaf spring bolts to hanger and shackle, axle u-bolt nuts. Thanks for the help!!
ricsch
I now understand why the dealer techs shy away from problems...it's too hard to find the info in the 4 volume manual. I would say tighten till tight, but not too tight....I'll see if I can find the info.
Oby, if I could bug you...what the torque spec for cab bolts? I'm still trying to convince the wife that buying a tech manual is worth it.
The Z71 suspension package is available on the LS or LT models. It appears you can order an LS Z71 with a V-6 and a 5 speed or a 4.8L V8 and a 5 speed. The LT only comes with an automatic.
Both of my Silverado's were special ordered to get a manual transmission.
Mike L
gear to frame bolts 136 lb ft
inner tie rod to steering gear 74 lb ft
intermediate shaft coupling pinch bolt 33 lb ft
outer tie rod to steering knuckle 50 lb ft
power steering cooler mount bolts 7 lb ft
pressure hose connection at gear 24 lb ft
pressure hose connection at pump 20 lb ft
rear pump mounting bolt 37 lb ft
side cover bolts 45 lb ft
tie rod jam nut 50 lb ft
upper control arm ball joint stud nut 37 lb ft
lower ball joint to lower control arm nuts 52 lb ft
shackle to frame bracket nut 24 lb ft
shackle to spring nut 70 lb ft
ubolt (14mm) 59 lb ft
ubolt (16mm) 89 lb ft
This sure will make the job easier. Have a good one!
My dealer says it's just the torque converter and that it is normal. Sure doesn't feel right to me. Anybody have this condition?
Thanks, Phil
ricsch
Ubolts...theres one over the axle and one over the leaf spring. it's listed by size.
ricsh- makes ya wonder if it took another 2,200 miles to make the truck decent enough to put up for auction. nah, the service mechanics aren't that dumb right?
GEEEEEEZZZZ
LOL
- Tim
JUST PICK 1 jeez
