Chevy S10/GMC S15-Sonoma: Problems & Solutions
Wrote "Jumpstarting through the battery doesn't always do it if the battery is bad. Once had a vehicle with a bad battery where i had to hit the starter terminal with the jumper cable to start it. Canufixit has good advice, but so does gonogo and im betting u need a new battery! "
Sorry - re-read my post - Following what I said would catch all what you said (Check the connections = bypass the cables with the jumper cables direct to starter, etc , etc.). Unless they have all the wiz bang Test Gear (amp draw tester, full test gear, etc. - which I assumed they did not ) - my advise stands ...
Can "U" fixit ??
Been having intermittent problems with the driver's side window not operating. Window operates fine for months, then won't go down for weeks on end (going on a month this time). There doesn't seem to be a problem with the switch as I can operate all the the accessories from the block (pass. window, mirrors, locks). Had the problem even during warranty, but as usual problem would cure itself as soon as it entered the dealership or into the work bay.
Wondering if anyone else has had this problem and if so where should I start, switch or motor? Would like to know b4 I start taking the switch and panel apart and going down the wrong path. Seems that block as well as the switch itself is getting power (did a quick/dirty voltage draw test by depressing the switch and looking at the dome light - light dimmed for split second), plus the other buttons work so I think I'm ok to that point.
jae5
I called a guy (I'm new to my area) that seems reliable, but he is saying that to replace the heater core (part is about 40$) will be 480$ in labor. He says that he has to take out the dash (understandable) but also has to discharge and recharge the A/C system and has to drain and replace all the coolant.
Just curious if this is THAT major of a job? 500$ in labor? For THAT much, shouldn't I just bring it to a dealership?
gonogo[#1501] "battery look old replace" => [i replaced the battery]
wally 7[#1503] "Jumpstarting through the battery doesn't always do it if the battery is bad" [ this is good to know and found that out myself, but did not realize that ]
bigall[#1504] "You make it sound like you have a manual transmission and tried to start it by popping the clutch" [yes that is correct]
Canufixit[#1502] "a bad connection and 15 min. cleaning time" => [I checked all the connections and cleaned the [very] rusty connections and after 15 + minutes the car was back on the road]
"I've seen multiple cars have lots aof parts changed - onlyt to find out a bad connection...."
[ I am glad i asked and followed your advice before making these obvious mistakes myself and I could relay this information to a friend to solve his electrical problems with the brakelights of his S10].
thanks a lot
ajowel
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1- 8/be/55/0900823d8018be55.jsp
Sean731,let your shop have the problem of sorting out all the wiring and vacumn hoses under the dash......
Any helpful information is appreciated!
robtwall
- If it's failing hard when level - it is the BEST time to trouble shoot the cause (Fuel delivery - at the injectors, Spark at the plugs, etc .... ) Failing to do so now and you may run the risk if having it go "intermittent" - which would be a real bear to fix ....
With that Said - and assuming you check the obvious things ...
- Water in the Tank (lift it and the water moves from the intake in the tank).
- Foreign stuff in the Tank - A friend of mine found a plastic bag in his tank - some one obviously stuffed in.
- Upon lift up - the suspension shifts and "kinks" the fuel line ??
- Try it on a hill and face the truck in various positions - if it's OK there - it may prove it's not the "Angle" but a suspension shift ...
- Wires getting moved / pinched when lifter (to Fuel Tank/pump, other at the engine sensors, etc ...
- Doe it do it when you try the steering wheel in a different position when lifted ??? (Thinking of the key chip ion this one ...)..
- Drop the tank - then lift angle the truck - or the Tank - see which one makes the diff...
Pease let us Know what you find !!!!
Best Luck
Canufixit
Good Luck !!
Did it run Ok when you run it through a recent Car wash??
Run your fingers down most wires - especially any that have a lower loop/droop to them. See if you feel any bumps (Corrosion inside the insulation from water that gravity sent down the inside of the wire due to an open in the wire higher up ....) Don't forget the Tank/FuelPump AND all the fuse connections ....
I'll try to think up some more ...
Damo
Possible Vacuum lock in the Gas tank ?? In the AM - after a few miles - the vacuum lock sets in - starves the gas ... in the PM - the heat of the day pressureizes the tank w/ expansion from heat and it does not happen (but probably would on a longer drive ...)
Try loosening the gas cap ...
Regardless - any bad/leaking vacuum lines will affect the overall starting, idle/roughness of the engine. Hoses are cheap - change anything that's suspect - I'd do them all as they are so old anyway .. BE SURE the lines are hooked up correctly. Check under the hood for a diagram- or get a good book and check every hose - Don't trust what's there -as a hose may already be on the wrong connection !!! Check at the fill end of Tank fill pipe for hoses as well .... Be sure you get hose rated fro Vacuum - others may collapse ... and the right diameters - there may be multiple sizes needed ...
You may want to just check all and only replace the suspect lines one at a time and then re- check the engine problem - so not to cause yet another problem and make it worse by changing all at once...
Let us know how you make out ...
any ideas?
Over the years - I've looked through my 2002 shop manual and owners manuals ... The only thing I saw was how to disable them "temporary" After you shut down the vehicle and re-start - they return to factory settings ... Perhaps a computer hook up may do this - but i'm not sure otherwise ..
Anyone Else Know ???
Canufixit
Remember, the people at Auto Zone aren't good mechanics or they wouldn't be working there......
I think Alcan is on the right track, listen to him.
I know from searching the net that this can be done, but instructions are sketchy. I'm looking for some help on the simplist way to get this accomplished. Does anyone know any technical resources with instructions on how to do this?
Thanks much in advance.
Mark
Mark
Mark
I don't know if this action is controlled by the PCM. Mabey someone else knows. If you read other threads on this website, there are people expressing their contempt for this annoying feature, and others praising it. These threads are found in the Pontiac and Honda forums. I want to be able to defeat these daytime running lamps and the auto headlamp sentinal perminantly, without having the instrument cluster indicating a malfunction; and I don't want any other function impacted. There has to be a fix for this (even a strategic wire clip at the ECM?) I don't know, but someone disabled the DRL on my wife's 99 Tahoe. They stay off, but the red "Daytime Running Lights" instrument cluster indicator stays on. I guess that what the black electrical tape is for..... Best Regards,Bob
I drove 100 miles afer losing overdive in my 93 Silverado. Sometime sliping out of third, sometimes able to catch it wid the throttle others having to coast and grab manual second. Changed fluid. Alot of black pwder in pan and burnt oil. Still doing it. Is the tranny gone. Its a 4L60E. The electronic THM700-R4, and can i swap the cheaper reman 700r4 in my 2wd 93 silverado by adding a tv cable ang the governor. Please help JBTrailer
Also dealer says water pump leaking out weep hole . 34K miles. ? !
Damo
