Chevy S10/GMC S15-Sonoma: Problems & Solutions
From what you listed - it does sound like the battery - although it sounds like the cables "might" have contributed to the issue (Bad connections = bad starting AND bad charging ... Deep cycling hurts the battery... )
As for the batery test - from my old DC circuit class (and it's been a while ...) I seem to remember that the chemical make up of batteries cause an internal electrical resistance in the battery.
When new and fully charged - it's minor and little voltage is dropped / lost across it. As the batery dies/ages - the internal resistance gets very large - and the voltage gets dropped across the internal resistance and the available terminal voltage to the starter drops - HOWEVER - this drop is a function of Load (amperage draw). since a small meter has little load - the battery measures 12 - 14 volts and looks OK.. Good battery testers have a heavy load that will pull amps from the battery - and THEN measures the voltage. Missing power is dropped internal to the battery.
As to why it the batery was fine up unitl that one time you tried to start it ?? - Unknown to me - but I'll say this - it had to die sometime and somewhere.
Now, what exactlly am I looking for when I check the exhaust? If I do find something like unburned fuel or something, what is internaly wrong with the engine and about how much will it set me back to fix it? Thanks.
I have a problem that has just started. The other day when I started my truck I got a small puff of blue smoke, it hasn't done it again. When I went up the street it kind of bogged and almost stalled, I gunned it and it kept going. Sense then it has almost stalled every time I start it when its cold, but as soon as it warms up a little it runs just fine. If you have any suggestions, fuel filter, fuel pump, new engine, a cliff or something let me know.
pateric
pateric
I don't get black smoke, it starts ok and it has EFI so I don't know if there is a "choke" like in a carb as in the old days... I haven't a manual so I haven't done much to it. It has been running good, not the greatest fuel mileage 25MPG, but ok.
I'm thinking of replacing the OE Wranglers (235/75r 105S) on my 2002 Sonoma 4wd Ext Cab. with these .. I relly can't find anything negative on the web - other than a one or two who hated the tires overall ... Ratings I see are very good and this is a "quick pick from" Consumer reports ...
SteveC
This is not a real expensive tire - and, hopefully, this will be The last set I buy for this Vehicle.
I just wanted some kind of assurance that I would not find that , right after I put them on , - that they were real loud, the ride was terrible and had numerious other problems to come... As long as these are smimilar to the Good year Wranglers RTS (OE's) - I'll be quite happy ..
I don't mind spending some money - but I'd like to only do it once, get my money's worth and hopefully satisfied.
Thanks !!
As you and others stated they have the equipment to do a battery load test but many do not know HOW to do the test. Many will just get the battery to 12 (should be minimum 12.6~12.7) by putting a high charging current into it and send you out the door. The bulging is a dead give-away of this and a clue that the battery is cooked literally. And many don't know that it has to hold a load for a certain length of time and shouldn't discharge. A fully dead battery takes hours to fully charge, not minutes. If it discharges fast, you have a dead cell or two. A good investment is a digital VOM, I use it all the time and really comes in handy for the house and cars. I would HIGHLY recommend staying away from the Wal-Mart batteries unless you selling a vehicle and in need a cheap battery.
:sick:
-Joshua Lee
Good luck,
John
Don't be bashful, be prudent and save $ in the long run. Take it to a transmission shop you trust and let them test drive it for you. In my haste, I dropped my tranny out and had it overhauled when the problem wasn't the transmission to begin with.
Good luck,
John
Thanks for the uplifting encouragement. I'm looking for some place that will run diagnostics on the truck before i do anything else. I talked to someone and they said if I just recently installed a new CD player it might have fried some fuses. I checked everything and there were no bad ones. So my next step is to run diagnostics and solve this problem once and for all.
-Joshua Lee
:confuse:
What should I try next?
James
- I Purchased qty 4 Toyo A/T open country p235/75R 105S.
Replacing - 4 Good Year Wranglers - same size tire (OE) - on a 2002 Sonoma.
- I'd say the Wranglers had a tad more "Rumble" noise. The drive train in the truck is a little more noticable - but I do hear the new tires - suspecting increased air noise from the tread. Not too bad - but there is a difference. Perhaps to the fact the old tires had low tread and the new one have have maximun ...
-Traction seems much bettter -dry and wet - and handling is better.
- Tires are inflated to 34/35 lbs - and the ride is slighty worse on bumps and small holes - but not real worse. I'll try dropping the pressure down to 32 once I'm sure the Alu wheels are not leaking at the rims (I did have them cleaned and coated ..)
Overall - the tire seems OK - but a little more "truckie" and my not be a great fit for an SUV - But usually the SUV's vs the trucks have more body insulation - so perhaps the noise is not noticable...
Now - and my only major concern - when I get up to High way speeds - at about 65 -ish - I get a very slight washboard like vibration. Kinda like you can feel the large tire tread cleats hitting the pavement and making a buzzyou can feel inthe body. Steering Wheel is virtually no vibs - it's partialy noise and partialy feel in the Body. Kinda hard to explain. It "Might" be a minor wheel balance issue - And I'm thinking of having the balance re-checked. But this might not be so ... Again - it's at over 60 MPH (I normally do not hit 70) when I get this - and it is minor. But if I was doing long hours at high speed (which I do not) - it would probably wear on my nerves a little ...
Any comments ??
Rgfards,
Canufixit
Mike
Does the Vent blow air (i.e Air diverts work ok) when you cycle the switch from floor to top Vent ??? and also at the normal A/C setting ?? If so - it sounds like the diverter (Baffle, Vacuum line/motor) is working OK for the Vent and AC.
To my limited knowledge on this - I beleive the only difference between A/C and A/C Max is that "another" baffle moves to change from outside air to "re cycle" inside air (to give the fastest cool down / max AC). that's the reason for the Fan noise - the fan is recycling the Air through the fan and you can now hear both the in /out side of the fan.
So ... if the vent baffle is working ok (as questioned above) I'd check two things first;
- the diverter baffle - to be sure it is moving - and "FULLY" open / closed. (Diverter, Hose, line, etc.)
- or - the Panel vacuum switch may be not be working or plugged up .. and not just for the "Recirculate" baffle - but for the "Vent" baffle (at THIS position in the switch ... the Switch must control all baffles at all positions on the switch .. Perhaps just one opening in the inside of the switch is plugged only at max a/C ??
(Also - thanks for the help on the Tires - Apparently I'm all set now !!)
Canufixit
I agree with your comments ... A clarification on my earlier E-mail for you ... re: the switch. Just in case you are not aware (and That I'm not wrong as well)..
All the bafffles, as you know, run off "Vacccum" motors. So all the vac lines go into a "Block" that has vac channels made in it. a Rotating valve will cross connect these various channels as it is rotated. For example if you have three vac lines to motors (A.B,C) and at switch position 1 the switch connects A and B to Vaccum (only) - then at position 2 the switch connects the channels so only C and A get vacuum, etc ....
Anyway - the only time I think the "Recirculator" line has vacccum - is at Max AC - So, the baffle door or the motor/line may be blocked/stuck - or the switch at that position has some crap in in preventing the vacuum from getting to the holes ...
Best of Luck !!
You might have two issues here ...
1st - Since you had issues with power before the tank change - and I assume the 90's had an in tank fuel pump?? Check the pressure/flow (Bring it to a garage if needed - these can be trick / dangerous to test and if it's not correct in fuel output - you'll chance your tail for hours ..) ...
2.) I'd debug this second - ( as it's easier to do with the tank accessable) - but check the in and out wires for correct signal - Might be just a bad connection at the connector... If I remember the circuits correctly (and I might be wrong here so get a Chiltons) - the Gas gauge circuit (from the dash) emits a low vlotage/amperage limited pulse that goes into the gas tank / sender - and grounds (completes) the circuit there ... So I'd check for the pulse voltage going to the tank and check the tank sending unit ground using a meter (with a decent meter) ... ALL the way back to the battery as well.. (use a jumper to the negative terminal if needed ..)
As for fixing #2 second - if #1 (fuel flow /pressure) is bad - you are going to draop the tank anyway - and then debug the sender ...
Good luck and keepus posted ...
SteveC
please help
http://www.3rddoorhandle.com
(No, I am not affiliated at all with the company. I've just had two broken plastic handles even after adjusting the door according to the TSB. The door has always been a huge pain in the ___ until now!)
With our truck it started out as a faint hiss that would change as the gas pedal was pressed. Then it progressed to when switching between AC/vent/floor/defrost it would occasionally stick or take awhile to change. Eventually, the controller stopped working entirely and it was stuck in defrost. As it was under warranty, the dealer replaced the air controller. It broke again. They replaced the air controller and vacuum lines. It broke again. They replaced the air controller, vacuum line and did some other mystery fix. We've been good for 25,000 so far but I'm not holding my breath. They said something in the vacuum lines was corroding the seals in the controller.
Does anybody have an idea of what exactly was happening?
