Oldsmobile Aurora: Care & Maintenance
and yes, i will get to changing the filter (i was being a smidge sarcastic) - an endearing trait im told
thanks for the feedback . .
Jay
To
Although, this may be that "red light" in the roof conversation all over again.
I remember reading somewhere an interesting article about brake pads/rotors and why they warp. I can't remember where it was posted, but basically the idea was that rotors get build up on them from slow, easy stops. The guy seemed to suggest that you need to re-bed the pads every once in a while if you are a sissy stopper. This seemed interesting because oftentimes rotors will develop vibration even though they aren't used hard. Anyway, today I figured I'd make 3-4 stops from about 45 down to 5 mph. The first three stops I pushed the pedal pretty hard but not panic hard. I then decided I'd try pushing it real hard for the fourth stop (I don't like doing that as it seems sort of abusive; in fact, I don't like flooring the gas a lot as it too seems abusive). I was quite surprised that the ABS activated right away from about 50 mph. I was on straight, dry, clean road, so I didn't expect that. I guess the 12" front rotors have some guts to them. I've never locked the Corvette up at that high a speed, although I also didn't like to brake hard in that car if not necessary. Plus, it had steamroller 255 tires on 9.5" wide rims, and only had 11 3/4" rotors. The Corvette was also lighter, but I can't figure if that would make it harder or easier to lock up a tire... Anyway, I just thought it was interesting, and it's nice to know the brakes have that sort of power if it's needed.
Abusive: I guess I'm guilty of abusive acceleration once in awhile - OK, sometimes a lot. Maybe I'm wrong, but with frequent changes with M1, I figure I should be protected from the adverse affects of an aggressive acceleration. I never hammer it until the engine is fully warmed up too. I've generally been going no more than 3,000 on M1. From the results of the oil lab, it does seem wasteful, however, with very frequent changes you flush all contaminants out - even those that the filter cannot remove.
I'll mention this again. If you get a replacement drain plug from any GM dealer, you will get one with the magnet on it. It's less than $3. They do collect the worn metal (iron of course). It's surprising to see. It has to help with reducing wear and maintaining top performance.
About the brakes, did you bed the pads in when you got them? It seems like it isn't just abuse that caused rotor problems. It seems like they can be caused from driving lightly or stopping hard or who knows what. I wish I remember where I saw that article, or where I saw the link posted so I could put it up here. It was an interesting take on rotor vibration.
I don't think there is anything wrong with accelerating hard. I'm just weird about things. Sometimes I get in a mood where I punch it all the time too. I'm sure the car can handle it.
I don't know how true it is, but after reading it I tried changing my braking behavior.
I'll slow down to a stop and leave some room in front of me. Then after 10 seconds or so I'll roll forward a few feet to allow the covered portion of the rotor to rotate out from under the pads.
Maybe I was/am misleading myself, but after going through front rotors like mad on my Ford RotorWarper...errr, I mean Probe GT, I did seem to notice increased rotor life after applying the above technique. (And so far, so good with my Aurora)
As always, Your Milage May Vary
The interesting thing is that here in New Jersey the temp stays around 150 to 175 during the winter (like now).
nne3 - rotors, yeah, I've done the "move the pads" thing too. I'm sorry, even if the "you can't drive too much this way or that" is true (maybe it is) that is really really sorry. Stupid %$@(&% rotors should not have to babied like some lab specimen so they don't die. Good grief. I think there is a lot of junk on the market as far as rotors are concerned.
One note when I got my new rotors. They only had 1 ray's rotor in stock (how can you only have one of those - think about it) but assured me they would get another from a different store to do the job. I wonder. Apparently once they are out of the box you don't know who made it.
Temp: my car generally runs a little under the 200 line. Sit a little and it goes a little over the 200.
At first I was really concerned but now I don't worry. Who knows if the guage is that accurate anyhow. If it does get hot, you'll know it.
Anybody know more about this????
My manual for both cars calls for 180 degree thermostats. I stopped in at one of the automotive suppliers to see what their books recommend and they said 180 degrees. GM calls for the 195. I wonder if the person that has their temp. running so cold if they didn't have the 180 installed. I have often wondered how a 180 thermostat would work in the summer?
Not too long ago I changed my spark plugs on my S2. Propably my longest spark plug / cable greasing operation ever. Took 2 hours. Had it not been for the removal of the AIR pump valve and all that, it would have been much quicker.
Anyways, anybody noticed that the spark plugs from the rear bank seem to suffer a bit from heat compared to the front ones? I also noticed that the plug closest to the passenger had signs of slight rusting, and so did the coil tip for that plug, and same for the closest coil pack screw.
I'm thinking of making a splash guard, that should take care of the humidity. Plus I used silicon grease. There was none left on the rear bank.
The grease missing and the color of the plugs is telling me that the rear bank sees a lot higher temperatures. I'm thinking of getting air from the front grille (passenger side, the part that is currently blanked out) and ducting it to the splash guard to bring colder air where the rear exhaust manifold is.
Anybody else noticed that?
BTW, I switched the original Denso platinums with NGK TR55IX iridium.
i think 35 is something for the stereo ? i get it sometimes, and my multicd changer doesnt work - coincidence
in the last 2 months i have had the following changed
alternator (that was bad timing, failing at 1am, 30 min drive from home)
water pump and water pump belt
all 4 tires (thats happening tomorrow actually)
new front pads and machining of rotors
wiper blades
i now have 200,000 kilometers on it, its a 97 and i like it. keeps the camaro off the road, and does it in stlye.
r.r. power window just stopped working (in the up postion thankfully) , but since i sit in the right front seat, im not worried
Homer- "D'oh". Just messing around. BIG Simspons fan over here. What's the back ground on the screen name? I remember you saying before that you sold Zaino, right? I've been reading the http://www.autopia.org/ board and what to give it a shot on my white 96.
Let me know
taylorsturf@attbi.com
http://www.cardomain.com/id/800wattaurora
Zaino is AWESOME. I've done 5-6 cars (mine, wife's, relatives) and they are completely in awe how well their cars look (even when dirty), how easy they are to clean, etc. Lasts long, too (haven't put any Z on my wife's car since June, and it's finally seeming to wear off/not beading as well). I also use the leather cleaner and conditioner (use it on my leather sofa, too :-) and their glass cleaner (also great).
There's a Zaino discussion over here on Edmunds.
Highly recommend you check Zaino out.
http://www.zainobros.com
Not a shill, just a happy customer,
--Robert
my name?
big simpsons fan - and when i joined up here wayyy back when, i had a new Black 2000 SSEi . ..
so there you have it - actually, i frequent about 15-20 car forums, and usually i have a different name "Homer2" - but it was taken here when i registered, and im not terribly creative in a pinch - PLUS - i LOVED that car, and couldnt see why not to use that name . ..
cheers
I know that when I find a product I really believe in, I too will tell anyone about it who will listen.
He's probably just trying to help us all out. Afterall, if he was trying to sell the product, I'm sure he could find a more efficient method of advertising than the Aurora board....
Cheers
If you're interested, there is a very active discussion devoted to Zaino in M&R, as there is also a discussion devoted to Store Bought Waxes (No Zaino posts).
Rjs, You never pushed it, I just said I wanted to try it because I've heard good things about it. On a side note, I searched Aurora in the Autopia board and your name came up. Mis-understanding there. I plan to start posting there when it gets warm enough to start the weekend wash routine. I always like a clean car, and don't want anybody to touch it. If I pay for a wash it's at Delta Sonic only. All jets, no brushes, except for the hand drying. So usually on saturdays, I'm out in the driveway washing my cars. All my friends and family know that I do this and stop by and wash their cars too. I'm a good son and usally wash one of my parents cars every other week. Mostly it's Mom's 99 Z34, Dad likes his dirty escort wagon. That's the Dog car. Literaly! He's always taking our 100lb dog Domino somewhere. The front pass seat is hair infested. I'll ride in the back and you wash it.
As for paint prep. I need to do it anyway, after being 6 years old and 92K, theres a fair amount of micro scratches. I'm going to clay bar the car and bring it to a pro and have him buff the top layer of paint with a mild abrasive. Then bring it home and strip it and start the Zaino process. This should be a good base start with. I'm willing to put 4-5 coats on in the first week. 6 months durability isn't a problem for me either. 1-2 coats a month. Baby better really shine! In prevention for future micro srcathes, going to use a 3-bucket system for washing, and get all new car towels. I Dry it with a car squee-jee (sp?) best way I've found. With the sleek areodynamic design, the silicon squee-jee works great. No scraches either.
Anyways, hope the Pro does a good job.
the secret - get references and check them out . .
Watch out when you have those people dry your car at the touchless wash. That part isn't touchless. Water jets never get all the dirt off, and they reuse the same towels for everyones car, so they end up wiping a lot of grit around on your paint. This doesn't help the micro-marring.
As far as a pro, Homer is right. Try to see some of their work. Just because they have a buffer and charge you doesn't make them a pro. Buffers can put in worse scratches than they remove if the guy using it is a dope. You might try to find out exactly what products they use, and maybe probe them about how they think it works or removes scratches to see if they seem knowledgable. Make sure they will check the paint to ensure the swirls were removed and not just filled in.
3-bucket wash... Man, I always think that's overkill. I use two buckets, and that's like 4-5 gallons of water right there. With three buckets I'd have more water in buckets than I spray on the car.
The orbital buffer is safe too. I've really leaned on a scratch, got it out, and you can't burn the paint with the orbital motion and something as mild as no 7.
A high speed rotary buffer is another story. You can burn the paint with that, but I don't think it is needed much. Only for really serious damage, or the first buff after a wet-sanding job.
I do need some help with leather care though. I've tried half a dozen leather cleaner and conditioners to get out the marks from the heated seat coils. You can see the coil pateren very easily on my light color leather, from lots of toasty buns and black shirts and jackets. I think I'm SOL. Only the drivers seat has this problem, since It gets used almost every time I drive.
Rjs, I know what you meant by being a shill. LOL. It's not a big deal. Although one of my recent posts was deleted during this conversion and I didn't think there was anything wrong with it. Not a big deal though.
I've had great success on engine cleaning with Meguiar's All-Purpose Cleaner Plus. That stuff is awesome on upholstery and carpeting too. You just dilute it to varying amounts depending on what you are cleaning. And it is safe for the environment. Just spray the engine down with a 4:1 mix of it and hose it off. On tougher areas, use a soft brush to agitate a bit, or just let it sit longer. But you will most likely need to brush a bit. Just make sure to be careful with the water. You might check to make sure water doesn't pool in the cylinder's "V". I think the starter sits there. Drive the car around a bit to get excess water out. I use Megiuar's Engine-Kote afterwards and it comes out looking awesome. Plus, the Engine-Kote helps keep it clean. You can just wipe the engine down with a cloth every few weeks to keep it shining.
I've done this procedure on two grungy engines and they both came out looking great. I've coated the Aurora's engine bay with Engine-Kote and I wipe it down on occasion.
It's a cleaning kit for the TB and injectors.
The ultimate test is to park it under a street light at night - or under the lighting of a service station at night. Even my black car under these conditions will look like a mirror. Many a great looking car will look bad under those conditions.
RJS is right - the Lexol stuff is the best I've tried too.
