Oldsmobile Aurora: Care & Maintenance
How do you conclude that not changing fuel filter caused fuel pump to fail? What is the regular interval for changing the filter?
So far I like it, and it is quite reflective. I don't like how much of a pain it was to initially apply. I find the fact that it calls for three car washings to be a bit absurd. I also don't like how water doesn't fly off. It beads a ton of tiny beads, but they don't move even at 50+mph.
I like how reflective it is, and I like that the car always looks very shiny. I like how little of it gets used per application, and application of the actual polish is quite easy.
If I didn't have any Blackfire and didn't have any Zaino right now, but had my experiences with them, I'd buy the Blackfire. If I could just buy Z5 and maybe the QD and still be able to apply Zaino properly, then maybe I'd go for it. The ZFX at $20 or Z1 (which does no protecting) for $10 just to enable the Z5 or Z2 to be applied is a bit of a turnoff. So is the requirement to wash with Z7 then QD with Z6 prior to applying the polish. I guess I don't care for the expensive system thing.
That said, I already bought it all and Zaino is really a very nice product. I might toss a few Blackfire coats on over the winter just to see.
I also find Meguiar's Final Detail QD adds a lot of gloss to the Zaino, and really adds some red to the reflection. Plus, it gets those beads of water zooming off the paint. Some Z5 and Final Detail would suit me just fine. Though, Blackfire and Final Detail is pretty amazing too.
Hey Steve, remember a while back some discussion about what was leather and what wasn't? Ive been scrutinizing it more lately, and it appears that there are parts of the seats that arent actual leather. You can tell a difference in the texture if you look real close. The real leather has very soft creases and texture, and the fake leather has very defined texture. It does seem that any piece that doesnt wrap to the front isnt real leather.
It's actually kind of nice as it means I don't have the problem of getting leather conditioner on the center console when trying to get the sides of the lower cushion. I find it a lot easier to dress the seats now...
I've started applying #40 with a Q-tip to the little bits of rubber that are around the exterior of the side windows, and the tiny little bit around the door handle fixures. I figure they get the worst of the sun and weather, so they could probably stand a bit of help. Anyone else do this?
Also Steve, how was the #16? I just ordered up the Meguiar's October special, and decided to toss in a tin of #16 to try as well...
Steve
It seemed to be the original fuel filter, given its old stock number. The mechanic suggested every 30K to replace, I believe. Having the fuel filter clogged requires the pump to work harder and thus wear out. Hope this helps.
I also got a magnetic drain plug for about $3. It is the GM replacement. I think it is aluminum instead of the iron of my original one. It feels lighter, and there were a bunch in the bag when I bought it. None of them were sticking together. Yet it will easily lift my original drain plug. I was pretty surprised by how strong the magnet was.
I've been using 7.5 quarts since the last change, and over about 7,000 miles and about 10 months, I didn't have to add any oil at all. Though, it was probably about .5 quarts down when I changed it.
Zaino was very reflective, beaded water very well, and likely would last a long time (it has been holding up just fine since I put it on).
However, it had very low gloss. Reflections have very little red in them. I could probably take some reflection photos where you couldn't even tell my car is red. To me, that's not a good thing. It's a lack of depth/gloss. Also, water didn't bead off the car well. It beaded up a lot, but never rolled off. And the car seemed to crud up more. Unless it's just been a yuckier time of year, it seems that stuff like bits of grass and other crud stick to the paint more. These things would have come off during a wash with Blackfire, but needed claying or bug & tar products to remove with the Z.
I might throw some Z coats on Blackfire in the future seeing as how I have the stuff, but I doubt I'll use it much anymore. It is just too expensive and finicky (when you factor in the Z7 and Z6 you have to use to "prep" for subsequent coats), doesn't have a look I prefer (the reflection is awesome, but I want some gloss!), and the prep seems counter-intuitive to getting a nice finish. Dawn washings seem mildly harmful, and certainly dull the appearance. Blackfire can go over anything and last just fine. Plus, I can use any car wash and such when applying subsequent coats.
Final Detail provided a temporary solution to water not flying off the car, and to the lack of gloss, but a coat of Blackfire is now providing a much longer-term solution.
Zaino is definitely a good product, but it just isn't what I want from a product. Blackfire is. I'm also a bit eager about the pro version of Meguiar's new NXT that's coming out. It sounds a lot like Blackfire to me, which is definitely a good thing...
Oh, I picked up some #16 along with some more Medallion Premium Paint Protection, and look forward to trying the #16 out soon. I'm not sure if I'll try it on the Aurora, or stick with Souveran as the topper of choice. But #16 sounds like a good product, especially if it can outlast #26 and provide more shine. It smells like crayons...
The fronts can be any brand you choose. I have KYB and I believe some folks have gone with Monroe.
You may also want o serch this board and the main board for shocks. This question has come up before.
Just my 2 cents.
Thanks for the information. I have already replaced front struts with Monroe SensaTracks. I would have preferred KYB or Koni, but they have nothing for '97s.
VanChevrolet is the place I found lowest price, and I will most likely buy there for the rear shocks as well as a fuel pump.
Go to www. yoursource-autoparts.com and order a pair of 504-96 shocks. For the PAIR, they were $95.00. You can't beat that price. I also put the KYB's up front, they are incredible.
good luck.
Pete
The results were pretty much the same as the other two. Extremely low wear metals and the dirt was very low too. The engine is just not wearing appreciably at all. According to these results, it should perform and operate like new for a very long time. Way past 100k and I think if it goes like this - 200k will be nothing for like new performance.
However - one weird note. The iron numbers were about the same as before - very low. I thought the magnetic drain plug would skew it next to nothing, but it really doesn't seem to do much. All other wear metals were way down next to nothing, so I kind of doubt I could have had much larger iron wear numbers but not see any increase in any other wear metal.
So, maybe the magnetic drain plug just pulls a very small % of what is in suspension or just grabs some particles that would have been filtered or just remain on the bottom of the pan anyway. Who knows?
The plug had very little material. It was more like a gray film - not really any particles you could identify. Still - it can't hurt.
One good thing, I'm more confident on the performance of a K&N filter that's been reconditioned. They really are washable and reusable without a decrease in filter efficiency.
Yeah, I wouldn't really be surprised if the plug didn't do much. Maybe it just grabs the larger particles. But it can't hurt.
Thanks for the info on your testing.
--Robert
Because your car goes more miles per engine revolution on the highway, highway driving means more miles before a change (though not necessarily more revolutions before a change). So you could idle your car all the way through the engine life counter, whereas a set-mileage change interval could never capture that (since cars don't have hourmeters or whatever they are called).
The oil-life monitor is more advanced than you think, and certainly more advanced than a 3,000 mile interval no matter what. In addition to the oil-life monitor, you should change your oil before it gets to be more than 12 months old.
I don't drive a ton of miles so it'll probably end up being a twice a year thing - spring and fall.
Let's see, my last oil change was about three months ago; or no, it was 2,700 miles ago, I think. Where did that windshield reminder sticker go?
Relax. Engineers have introduced technology designed to help those of us who have trouble keeping track of exactly when the last oil change was. And it can help save time and money, while helping protect the environment by reducing waste. The GM Oil Life System is already included on many new GM vehicles and the number is constantly increasing.
The Oil Life System serves as an electronic reminder that constantly calculates oil life based on a number of variables. The factors taken into account include: engine speed, operating temperature, load or rpm variance, and period of operation at any given load and temperature. The idea is to recommend an oil and filter change when it's actually needed, rather than by some predetermined interval.
Based on driving conditions, the mileage at which an oil change will be indicated can vary considerably. Remember, for the oil life system to work properly, it must be reset every time the oil is changed.
The oil change reminder will not detect dusty conditions or engine malfunctions that may affect the oil. Also, the oil monitor does not measure how much oil is in the engine. So be sure to check the oil level and condition on a regular basis.
With the Oil Life System, there's no need to adhere to the old adage of changing your oil every three months or 3,000 miles, whichever comes first, unless you forget to reset the system or you live in an unusually dusty environment.
If you change your oil on the "old schedule" that could easily be four or five oil changes a year. At an average of $25 per change, even if the system only eliminates two of those changes, that's $50 per year multiplied over the life of your vehicle. Not to mention the time saved and inconvenience avoided.
Also, by reducing the number of oil changes, you'll be helping the environment by limiting the amount of engine oil that is used as well as the amount of oil that needs to be discarded properly.
For drivers who may not use their vehicles often, the oil life system may not indicate that an oil change is needed for over a year. However, GM service recommends that you have your oil and filter changed once a year and reset the oil life system at each change. If you don't reset the system, your reminder light may stay on.
To find out more about the GM Oil Life System, consult your Owner Manual. Remember, there are Owner Manuals available online at mygmlink.com. If you have any other questions regarding the oil life system, phone or visit your GM dealership service center.
MyGMLink News vol 1, issue 5; article by Mark H. Stowers
I did not know about MyGMLink until I read your last post. I just registered. Thank you.
I think it would be interesting and give a "feel" for what is going on and also give an idea of how much iron (by comparison) is found on the magnetic drain plug.
The way I see it, 7 ppm is probably by weight. So is it as easy as (7/1,000,000 x weight of 7.5 quarts of oil)? If it's a volume thing (don't think so) then the specific gravity would come into play I guess.
Just a guess trial calc. - 7/1,000,000 x 12 lbs of oil??? (based on a guess on the s.g. of oil) x 454 grams/pound (easy number to remember) = about .04 grams of iron. That's about 1/20th of a paper clip I think - well .05 would be.
If that's in the ball park or at least in the park's parking lot, I can say that what I see on the magnetic plug would need to be multiplied by a huge number (I'm guessing 100's at least) to equal a chunk/piece of metal the size of 1/20th of a paper clip.
So maybe the plug magnet doesn't really do much or effect oil analysis results.
Any thoughts??? I hope I have not opened myself up to another "doh" moment. But I'm curious.
-Brian
Just picked up the new Mr. Clean Magic Eraser. Its suppose to be for walls to remove dirt and crayons so I thought it would be excellent for the door sills and lower door panels (above the carpet stuff) since those get beat-up pretty by passengers who don't care for the Aurora as much as us diehards.
All I could say is WOW!! I now have like new door sills and doors. It got everything off, even the All-Armor Multi-Purpose stuff wouldn't. Works on the black inserts too.
Though it is made of foam and wears quickly and you have to clean up the juice up it really works.
Looking awesome.
What is that product once again and was it easy to use.
Peace.
It is Meguiar's new NXT Tech Wax. It does apply easily and buff off easily. Hopefully it will last a few months as well.
Brian, let's see the picts!
Nice work though, I forgot you got the 2K Aurora.
Peace.
I used my Porter Cable to apply the NXT...I use it for everything, including Blackfire and I wanted to see how the NXT would react. The application was a breeze as well as the removal. I noticed a bit more residue on my microfiber towel after removing the wax than I normally see with Souveran or Blackfire...but I'll chalk that up to my first time using the stuff. I still have to get used to the right amount to apply and all that. I let it sit for about 45 minutes before buffing off, though I'm sure it was ready long before that.
Couple more pics:
The required hood shot
I wasn't all that impressed with the finish right when I was done, but the next morning it looked really great. The surface of the car looked like glass under water and it was super slick. I'm looking forward to some warmer weather when I can add the NXT to a complete detail session....all that I did here was wash and wax. Pretty good results considering the time spent.
Oh..I almost forgot...
Look it's Michigan in summer! Just had to throw it in there to keep my hopes up :P
I noticed it is a bit more dusty when wiping off, but I also noticed I used about 3/4 of an ounce to apply it, whereas with Blackfire I'd probably use about 1/4 of an ounce. And Souveran... I dunno, how much is 1,000,000 applications divided by 8 ounces?
The Regal was a bit dusty yesterday, much like the Aurora is (I'll wash it today probably with some QEW). Anyway, with a bit of dust on it, it looked similar in gloss and shine to the Aurora which has Blackfire and #16 on it. Considering how much time I spend babying the Aurora, and how little I did to the Regal, the fact that they look pretty similar (well, until you catch the Regal in the right light and see the swirls, dings, chips, etc) is a pretty good testament to the way NXT performs. I look forward to trying it on the Aurora, and I hope it lasts a good bit and beads/sheds water the way Blackfire does. I wonder how Blackfire would look on top of NXT? I really love the surface properties of Blackfire.
One of the guys on Autopia mentioned doing AIO and then a layer of NXT. I'd really like to try a round of AIO/SG and then hit it with NXT. It has a very strong scent...reminds me of the Meguiar's shampoo, and makes me think there are some cleaning properties in the product, so if that's true, I'm not sure how well it would layer. I may be wrong though...it might have zero cleaning capabilities and just smell very strong. Can't wait to find out!
Do you other Classic owners have the same FULL line on your cars? In other words, at 8 qurts we know the car is full of oil. What does your dip stick read? -- Henri
