Oldsmobile Aurora: Care & Maintenance
My car is the dark green. What color is yours? Maybe it is a color specific problem.
I really doubt GM will replace it. The car is probably over 10 years old now. Paint will last or not last due mostly to how it is cared for. Even the most awesome paint, neglected or abused for 10 years, will fail. In fact, on used cars, I would bet that the prep some dealers do will substantially shorten the life of the paint. Some places buff the crap out of the paint without any regard for paint thickness or seeing how much they removed. This will definitely hasten clearcoat failure if they don't leave enough behind. I don't think it's a '95 vs '96 issue as much as how paint is cared for (not just car wash vs hand wash, but how often it has wax protection, how often it is in the sun, and what sort of polishing or buffing was done to it) and the fact that '95's are just older and thus had more exposure.
I had read some posts where the original equipment battery was 13 inches and the new ones were 12 so the vent tubes didn't fit. Evidently this was a second battery (I'm the second owner) and the first owner had taken the time to get the right vent tubes for the 12 inch battery.
I popped the dead battery out, replaced it with the new one and popped on the vent tubes. Replaced the rear seat and put my tools away in under 10 minutes. I was pretty happy with the result.
I know must 2001 Aurora's out there got to have some type of Factory Warranty.
Javi.
Les
They say less dust, but my wheels are pretty dirty. Probably still in the break-up part. (Under 2k miles).
177-778 rear
18A488 rear durastop
177-874 front
18A813 front durastop
18A1179 front durastop performance left-hand
18A1180 front durastop performance right-hand
Performance left-hand and right-hand suggest cross-drilled or slotted, but there are no photos or text descriptions on the ACDelco website.
Can anyone provide information about differences?
Les
Here's some info from AC on the diferences:
http://www.acdelco.com/html/pi_brake_main.htm
http://www.acdelco.com/worldwide/eng/pl_eng_brake.htm
Can't find anything on the performance ones, but I seem to recall there being an article a while back on them... :-\
Tim
My car is on jack stands ready for these rotors to be installed.
Les
Other think to keep in mind is that your rotors have slots too. I also don't think it mattered if you switched them as well.
I would mount them with the slots aimed away like / that so it would throw the pad dust away from the hub.
1) Michelin - 235 55 17 Z rated tire at $249 a tire
2) Perillir - 235 55 17 Z rated at $175
3) BF Goodrich Traction T/A price unknown
I have the 2001 wheels I am going to put on the Classic, so that is why I am looking at 17" rather than 16" tires.
What do you guys think???
--Robert
I have the same 2001 wheels on my '97. I chose Continental ContiExtremeContact 255 50 17 ZR tires with service rating of 100W. I looked at 2001+ stock size 235 55 17 tires, but none I saw had a load index higher than 97 or 98. I was not willing to go with less than the load index of 100 for the classics. Plus I like wider tires in general. The Contis have great traction dry, wet, snow. I got them for about $160 each at STS.
Les
Henri, what are the factors you are looking for from a tire? All-season ability? Better grip? Which Michelins are you looking at for $250 a tire?
And shame on all of you with your secret 17" upgrades... Where the heck are the pictures?!?
Load index for Classics' tires is 100.
I have the photos, but I haven't been able to figure out how to make them available since we are prohibited from including them with our posts.
Les
Thanks for the correction. I assumed (a bad thing to do) that all classics have the same tire load rating.
Les
http://www.domesticperformance.com/default.php?cPath=26_313_314&osCsid=743b5da3c23dc30d501- 8d680d5b5a67e
I am going to change out the plugs on my 1997 Aurora for the first time. Any tricks to make this easy? Should I remove the rear coils? Do I need to disconnect battery before coil removal?
Thanks John
This time I did not have the hard-to-start symptoms. The clue I got was periodic pending codes (P0172 and P0175) for rich exhaust. Didn't seem too serious since the codes never set the Service Engine Soon light. Then I experienced one instance where the engine stalled when I let off the accelerator at about 15 mph. That woke me up! I replaced the FPR with another ACDelco at 122,000 miles.
2000 miles later and all is well.
Les
Got my '98 Aurora out of storage today. She needs a good bath, an interior cleaning, and an oil change, but otherwise she's looking pretty good. Plan to hit her up with an orbital polisher and some of the Zaino Z-PC to try to hide some of the swirls and scratches... if that doesn't help, it's wet-sand time.
My buddy and I are planning on doing brake pads and maybe rotors + front struts + rear shocks (at 95k over 8 years, it's time - last spring I could feel the car "hopping" sideways a little bit on large bumps, and the brakes fade badly compared to those on my GTO :-). Any other upgrades I should do on my '98? Sway bar? Strut tower brace? I am so used to the precise steering feel of the GTO that my Aurora really feels sloppy by comparison... but the Aurora interior seems huge after driving in the GTO for 5 months. I sure have missed the sunroof...
Question I have is whether there are any advantages to going with Monroe or AC Delco for the struts and shocks. My buddy has a parts connection through the local Buick dealer for AC Delco, and at my work we do printing for Tenneco (Monroe parent company), so I'll get good pricing either way...
--Robert
I replaced my '97's struts with Monroe SensaTracs and the shocks with ACDelco. I wanted something high-perf like Koni or Bilstein, but they're just not available for our Auroras. I went with Monroe because I decided not to do the job myself and went to STS for the work, otherwise I would probably have bought ACDelco. I also had new wheels (2001 Aurora 17x7.5) and tires (Continental 255/50-17 ContiExtremeContact) installed at the same time, so I cannot sort out the handling improvements are due to new wheels/tires from struts.
Four months later I replaced the shocks with ACDelco that I got at an extremely good price from RockAuto. At the same time I installed a 22mm rear stabilizer bar. This anti-sway bar comes from 1998-2004 Cad STS FE3; cost about $115. It is a direct replacement for our stock 17mm hollow bar. I also fitted polyurethane bushings and end links.
I am pleased with the results, but I cannot claim dramatic improvements.
I want to try strut and shock tower braces. RSM prices are ridiculously high (for me, anyway). Someone has posted about a GM strut tower brace that costs less than $20. There are issues with interference. This reminds me that I want to pursue this bar.
I do not think you can go wrong with either ACDelco or Monroe. Let us know if you try a front and/or rear brace.
Les
Les, when are you gonna take some photos of the 17"s and the wider tires? I can host them if you'd like.
I have the photos. Thank you for your offer. Where do I send them?
Les
I have no affiliation with Advance Auto Parts except as a satisfied customer.
Les
Does anyone know how to reset this on your own or does this need to be taken back into the dealership to be reset?
Thanks in advance for replying to this posting.
From the online owner's manual (register the car at http://www.mygmlink.com to be able to download an Acrobat PDF of the owner's manual):
How to Reset the Oil Life Indicator
Always reset the engine oil life to 100 percent after every oil change. It will not reset itself. To reset the OIL LIFE reminder, do the following:
1. With the ignition on, press the ENG button so the OIL LIFE percentage is displayed.
2. Press RESET and hold for five seconds. The word RESET will appear, then OIL LIFE 100 % will be displayed.
Hope this helps,
--Robert
norman
March94, the proper torque is 100ft-lbs on the lug nuts.
The more people that are aware of being stuck and taking the mechanic for it, the sooner this injustice will go away. It's just not brakes. You start these high speed vibrations with warped rotors and it starts unusual, for your driving conditions, wear paterns in suspension parts, CV joints, tires, etc.
If anyone has dates, I can prove they sold me the wrong kit, when the correct was available.
