Check to see if your bleeder valves are tightened properly. They may seem tight, but when you start the car and the high pressure hits the bleeder valve it might be leaking. That's what I would check...on all four corners. Good Luck!!
My light went on at 25,000 miles and stayed on. I went for my 25K miles service and was told that I need to change the pads, and they can do pads only (instead of both rotors AND pads). It seems like the light is directly connected to the break condition - at least in my case.
You said you had your breaks fixed - can I ask much much you paid? I was quoted $400 at a regular shop for something that everyone says it's "wear & tear". Could you tell me your experience?
Many thanks.
Pads do wear out. Assuming that you have a 2002 or 2003 P5, requiring a brake job at 25K miles indicates to me that you don't drive this car much. What may be happening is that your brakes have seized (i.e. locked up) and then they wore down your pads. This usually happens on the rear brakes. $400 to replace pads is quite pricey, especially if this is for the rear pads only. Your rotors may also have been affected. It's unusual in my experience that a shop that does brake work cannot do rotors. You may want a second opinion. Also, consider having your brakes lubricated annually to prevent them from seizing.
Yes, the headlight bulbs are a pain to change; they are tightly arranged in a dark spot in which it is difficult to work. A half hour may be excessive but the dealer may be charging you a minimum. Try getting the shop to do related activities done (e.g. oil change / battery test) at the same time. That makes it more profitable for the dealership to handle the job, while reducing the overall cost to you of the individual activities. If it's any consolation, I have replaced two bulbs so far and have found it was easier the second time round. Two tips: don't touch the glass portion; work in a well lit area with a flashlight handy.
Went to my independent mechanic who after ordering the correct bulb (not in stock) took a couple of minutes and put them in for the cost of the bulb ($12/each).
The reason for me posting this is just in case anyone else runs in to these same problems. Also, a reminder if your car is out of factory warranty because of "time", remember some of your parts are covered to a certain mileage. Like I found out your emissions are covered for MILEAGE NOT TIME, something to do with federal regulations. So if your catalytic converter went bad like mine, fix your miss fire and let the warranty eat the cost of the catalytic convertor, not you. I think you EGR valve should be covered by this too, highly recommend checking it out, can save you some big money. Hope this helps others, sorry for the long read.
Ouch! In case you want to look at the manual here it is: http://protege5.ugly.net
That is amazing; I've replaced mine once per side since 2002 and we have day running lights (i.e. lights on all the time).
They seem to burn out when I first turn them on. I'm thinking it must be some kind of voltage surge. Who knows.
Same as mine!
Are you installing the lights yourself? It's a bit tricky; including the part about not touching the bulbs with your fingers (to avoid them exploding!) and then fumbling with the paper clip like attachment. I wonder if it's something other than the bulbs that is causing this repeated problem. Consider having the dealer replace the next one and then warranty the work for 90 days or so.
"They seem to burn out when I first turn them on. I'm thinking it must be some kind of voltage surge. Who knows."
I did not mean they tend to burn out right after I install them and attempt to turn them on. They work fine for thousands of miles after I install them, and then on any given morning, I get into my car, start the engine, flip on the lights, and just like that I'll see a flash (like a camera) on the garage and I'll know that one of them just burnt out. It's normally dark when I leave for work so I generally catch it when it happens.
They have burned out at other times and I won't know until I'm driving at night and notice the light output seem diminished. It just seems strange that the bulk of them go first thing in the morning.
Maybe my car is a night owl and just doesn't like getting up early in the morning.
If you have to, you can carefully remove the other lowbeam and note how it is assembled.
Could this be a problem with Mazda silver paint?
- the original bulbs lasted a good while,
- replacements are costly ($C22+tax each); found slightly cheaper (C$17= tax) GE version but have not used it yet;
- replacing bulbs is a pain; be patient or have it done at your garage when you bring the car in for service;
- original high beams still working; hardly used in 5 years.
I feel your pain! Rust proofing is a misnomer, we are actually retarding or slowing down the rust.
Did your dealer have the rust treatment repeated annually? Some rust treatments appear better to me than others; the ones that tend not to work seem to me to be those that trap moisture which actually increases the rusting. The best treatments ones wick the moisture out rather than trap it. Also, they tend to be liquidy rather than tar-like in order to secrete into joints and crevices.
Where on your doors did the rust start? Was it at the bottom? Typically, this is where car doors get scratched as they touch sidwalks or where moisture builds up because the drainage holes are blocked by debris. Run your hand against the bottom of the doors to check for rough surfaces and scratches; paint them before they start rusting. Check your drainage holes and clean them occasionally with a toothbrush. I also dab some oil/vaseline on rusty bolts or other parts to retard the rust.
The rust on the doors is in the middle of the bottom edge, not near a drain hole (which are clear) and there is no visible sign of any scratches. The paint is simply bubbling up from the rust forming underneath. This tells me it is a quality/manufacturing defect.
I have heard as well that the lighter, annual rust proofing products are much more effective (especially Krown Rust Control) which is recommended by most automotive experts. I plan on getting is treatment done after the rust is repaired.
An essential tool in rust "proofing" is that little jar of touch up paint. I use it on all stone chips and many scratches.
So for brakes, I had to have rotors and pads done, they install ceramic break pads to avoid dust on the wheels. I was surprised to have to replace rotors, but understood after a good mechanic showed me what was going on. The humming started just before this and I thought my tires were wearing funny at first. But then the noise changed and the mechanic told me it was the bearings. Are these normal things to replace at 40k miles?
I haven't had anything else that I can recall that needed repaired, kept up on oil changes and the like. It seems 40k was early for a wheel bearing though. What do you guys think?
( I got mine without a roof rack and I love it. )
I have heard that 40K miles for brakes is normal. You could get them to last longer depending on your driving patterns. Personally, I'm at 85K kilometres (56K miles) but I tend not to drive as many miles in the city as most. Also, disc brake parts need to be cleaned and lubricated periodically. Living in Canada where the roads are salted makes this cleaning and lubrication pretty important.
One of the determining factors for the cost of brake work is whether OEM or aftermarket parts are used. You mention $800+, is that U$ and did it include additional services like wheel alignment?
Next time the light goes off, test the system by putting it to the maximum coolness and fan speed.
This is a long shot but if you're still listening, what was the solution to the problem.
I installed the battery backwards for just a moment... the main 100 Amp fuse blew. I replaced that but now I'm seeing exactly your symptoms ... the radio, interior lights, remote entry ... all the items that have power running to them when the ignition is off are now not functioning.
I too have checked all the fuses etc... But cannot find the fault.
Any thoughts?
Thanks very much.
Also, the spare, which is labelled T115/70/D15, is smooth as a baby's butt and the jack is missing. Is this the spare that goes with the car? Where can I buy a replacement tire? Do I need a special jack to work with the car?
Thanks for any advice!
If I have the fan speed set to zero, the A/C does not turn on. I have heard that it's a good idea to always keep some air circulating in order to avoid growing mold, so I never set the fan speed to zero. If you feel there is more to it than that, try asking your mechanic or the dealer to see what they say.
Time for a new timing belt?
