In a generic sense, I'm sure it's gear mesh. However, a couple production changes later, it's still there and pretty hard to notice.
If I can still feel it with the different wheels on, then I'll know it's related to the rotors and not the wheels/tires.
After market rotors is not a bad idea though. What would good quality rotors run for our cars?
Meade
They ended up w/ a CR-V instead.
I think they would have bought a Mazda just b/c their '90 MPV held up so well. Good work Ford
BTW, my mechanic friend also told me that the new Tributes (mid-year 2002) have had the stalling problem fixed. Again, we also shall see.
Meade
Meade
Bruno
Meade
Meade, I'm not sure what changed. Maybe they went from 10w-40 to 5w-30 for the oil filling.
Meade
BTW, don't forget that that the coil wire is a conductor too so the ignition coil has three conductors as well.
The underlying logic here being that the post count on the problems board is indicative of the number of real problems with the car (yeah, yeah - extrapolated from the fraction of Pro owners that frequent the Edmunds website, yadda yadda)
(Don't reply here :-)
i've had my P5 for only two weeks now, and i think there is something wrong with the AC. I'm hoping there is, anyway. I'm driving around in 95 degree heat, and i have the AC on full blast and all the way to the cold side of the dial. The air is a bit cooler than when i turn off the AC by pushing the button, but it is no where near as cold as any other vehicle i've driven. this seems a bit ridiculous to me. has anyone experienced this problem? my dealership is an hour away so i'd like to get some feedback before heading up there.
thanks.
it is a little better when it is on 'face only.' however, even on that setting, the car never reaches a comfortable temperature inside. the fan blows air on my face, and that keeps me from sweating too badly, but the car never reaches a comfortable temp. On previous cars, after a few minutes of full blast AC, i've been able to dial down the fan to 1 or 2 and be cool and comfortable. is this just the way the P5 is, or could there be something wrong with mine?
I don't like that the A/C button is so dimmly lit that you're not sure if it's on. Especially if you're wearing sunglasses.
Jessica
I've been driving in mid 90 degree temps with high humidity most of the summer and have had no problem staying cool. When the car is really hot inside, I start the AC in the recirculate mode, face/dash vents only and the fan set to 4. Once the car gets comfortable I'll turn the recirculate to fresh and the fan speed down.
Exactly my same experience.
Start off with your lever in the fresh mode and the windows cracked so the hot interior air that's being displaced by the a/c air has someplace to go. Once the car cools down a little, THEN switch over to recirculate -- that'll keep the cooler air recirculating back through the system to get even cooler. By keeping your system in fresh, the poor a/c is continually bringing in outside air (at what? 90 degrees or more?) and having to try to cool it to a comfortable temperature. Keeping it in recirc long-term means you're eventually cooling already-cooled air -- which is much easier to do and puts a LOT less stress on the system.
Maybe this will help put things in perspective -- from an auto help site I visit once in a while:
"As most of you know, you can choose air from two different places using your A/C controls. "Recirculate" or "maximum" air means the air from inside the car is drawn up through a vent near the passengers feet and run back over the ice cold evaporator core. "Outside" air is brought in from the vent just under the wipers just in front of your windshield.
"Recirculating the air inside the car is exactly how your home A/C works. It draws the cool air in and cools it more and through attrition, you get the temperature you asked for.
"When you choose outside air, you MUST drop a window a tad or your A/C will not work very well. It would be like pushing air into a closed car. You must give it a place to vent."
Pay special attention to the first few paragraphs in this link (by an a/c specialist) below:
http://home.modemss.brisnet.org.au/~leonp/ma/tips.htm
Meade
That is not true. Every car is vented for this very reason. In your Protege, the vent is on the trunk side at floor level.
Meade
My point was about the proper use of the recirc/fresh air lever.
Meade
OK?!?!?!
Meade
Also, switching to recirculate after the car has cooled down doesn't make that much sense. All your doing is rebreathing stale air over and over again.
I prefer fresh air, so switching out of recirculate to fresh once the car has cooled down seems like a better idea. Maybe I'm just weird though.
Do what you want, but your system will cool better in recirculate once the hot air is out and your windows are back up. And the air's only stale if you make it that way by smoking or whatever. Frankly, here in Virginia with our summer ozone alert days, I'd rather breathe the cool air in the car than the unhealthy stuff outside.
Hey, I didn't invent a/c -- I just use it as prescribed. Do what you want, it ain't my car!
Meade
Erik
I have noticed that the air is cooler in speed position 3 instead of the highest (4) -- which upholds the theory that the longer the air stays in the condenser, the cooler it gets. The fastest setting blows the air through the system too quickly to cool it down as efficiently as in position 3. Give it a try.
(Hey, I'm no expert, but these are Proteges 3 and 4 for us since 1991 -- so while I'm not speaking from technical expertise, I am speaking from experience.)
Meade
The Service Manager says its a pretty common occurance in the early Protege5's (I got mine mid may 2001) so be on the look out for it.
-Finn
