That's it? ;-)
In hindsight, if I had looked at the MPV a little closer, we may not have bought a CR-V. Its very much the anti-minivan sort of like the CR-V is the anti-SUV.
Dinu
Also, I've noticed that sometimes it is difficult shifting into reverse. The car was at a complete stop, and I was shifting from 1st to reverse (was parking the car). The shifter would go partialy into reverse, but not completely. Moving it back into neutral and trying it again solved the problem. Is this normal, or will it fix itself once the transmission breaks in?
I'm not familiar with the inner-workings of the manual tranny so, I can't give any fixes.
WHAT THE HECK!!!
I had to drive a screwdriver through the top to get it off. What a pain in the butt. Not only is it hard to get to. And it's difficult to get any leverage. Then it was on way too tight. Me thinks it's time to invest in a filter wrench. Too bad all filter manufacturers don't put standard 1/2" nuts on the top for easy on/off.
And how about those lugs??? I ended up using a 5 foot pipe for leverage.
YIKES! I'm glad that's done.
I gave up on my wife's '03 P5 after trying for 30 minutes. The lower strut brace really obstructs access to the oil filter, so you can't get any leverage on the filter. I just refilled the oil and advised her to take it in for an oil change so the dealership service department could remove the factory filter. After that, I'd take care of the oil and oil filter changes, as they typically don't torque it down nearly as hard.
Anyway, when driving my P5, once I hit about 30 mph, I'm hearing a noise. Kinda sounds like the faraway drone of an airplane (not a jet, a small plane). The pitch (tone?) changes as I speed up or slow down. Doesn't seem to differ when I'm on different road surfaces. I can't quite tell where it's coming from. Is this normal tire noise, or could it be the infamous 'roof rack' noise I've read about on the boards? Would I need to take off both crossrails, or just the front one (if that's the cause?). Thanks!
Terri
Now it could be that the tires are new and forming their thread like a pair of shoes' will contour to the way you walk, your tires may also need some adjustment to the allignment of your car. Speaking of which, check that your steering wheel is perfectly alligned - many new cars have them off. You can often hear a pronounced tire noise on a new bike (bicycle that is), but as the tires wear off and those little rubber (looks like "I" sticking out all over the tire) bits come off, you hear it less and less - could it be that?
For the P5 it could also be the roof rack as you mentionned. maybe some P5 owners can pitch in their thoughts.
Dinu
Philippa
Most cars will not jerk if you go R-N-D while rolling backwards but will certainly jerk or stop you dead if you try to go D-N-R.
Take an extra second to stop your car completely and save yourself $$$ (AT trannies cost a lot to fix!!!) down the road.
Dinu
-Philippa
I do like the sleeker look without the crossrails. I had considered taking them off eventually anyway, for the better mpg. Like another earlier poster, I was surprised to see rust on one of the clips when I took them off - on a car less than 2 weeks old.
Terri
Don't dealers have to fix something if there's a TSB?
Terri
Anyway, this slight "jerking" sensation definitely happens when I come to a complete stop, and then put it in reverse and hit the gas. However, I've been playing with it, and if I put it in reverse and wait a second or two before hitting the gas, it actually doesn't happen (or it's barely noticeable).
I think I have been feeling the sensation of it shifting as I tend to throw it in reverse and hit the gas all within a millisecond of one another. I am hopeful that it is not actually a problem, but instead it's due to the fact that the shifting with the Sport AT is noticeable in general (not super-smooth).
However, I am not one to doubt all of your expertise, so if you still think I may have a problem, I will get it checked out.
Sincerely,
Philippa
I had no problems with the install, it's fiddly, but not difficult. However, on 1 pad on 1 side, I forgot the little metal backing piece that sits between the piston and the pad back. It's just a thin piece of metal that (I think) keeps things from squealing. Well guess what? They squealed.
So last night I took that wheel apart, wiggled that pad forward, slid in the metal piece where it belongs, and put it all back together.
Everything the same as before.. right? Wrong. This morning I was getting excessive heat and smell from that brake. Almost like it's clamped too hard and dragging too much.
It was tough to get the caliper back on the rotor, requiring a few taps of the hammer, but nothing worse then the first time. I never had this problem after the initial install.
My question is this.. will it adjust itself? I read once that braking in reverse is when they adjust so I did that a few times and it seemed better, but still hot and smelly.
I don't want my car to burst into flames (exaggeration?) but I also don't want to pay a mechanic to check it out either.
Any ideas?
a)I'm getting used to it,
b)I'm getting a better feel for the car and am responding to it more appropriately or,
c) the car is "breaking in" the transmission and it's becoming smoother.
Anyway, thanks for your comments.
-Philippa
Firstly, does anyone notice a change in "positioning" with the side view mirrors? What I mean is that you set the (power) mirrors, drive along (yes, on some bumpy roads), look again in the mirror and it seems to not be in the position you set it in? I thought maybe I was imagining it, but thought I noticed this when I drove both the sedan and P5.
Second, the rear view mirror on the P5 - do people, for the most part get a full view outside the back window? I drive a '99 Protege sedan now and notice that I have a clear, full view out the back window, but in the P5, I could not see out the back window fully and had to keep adjusting the mirror (and kept seeing in my sightline much of the back of the car including those high head restraints in the back seat).
Your views would be appreciated...haven't made up my mind yet, but must admit that the P5 ride was sweet!!!!
2nd: The P5 has a smaller back window than the sedan, and it is further back in the vehicle. I suspect that is the difference you are seeing. This is a result of its wagon-ness.
Feel free to copy/paste any of your recent messages/questions, on this subject, into that discussion. Good luck with your decision. ;-)
And now, back to the subject of the Mazda Protege5 Problems & Solutions!
Revka
Hatchbacks & Wagons Boards
I don't think there is an issue.
On a happy note, I just got my first tank of gas today, and figured my mileage so far to be 29.5 mpg!!! I was also happy that I got up early this morning, to fill up before work. By lunchtime, the price at the station had gone up 20 cents a gallon!
Terri
Asking for what others recommend as replacement tires on the problems board is uncalled for. if you had a problem with the P5 post it here. If you have a question about how something works, prices, accessories, etc, post it in the main forums as there is A LOT more traffic there.
Dinu
I'm really surprised at how much the engine has smoothed out over the last 5,000 miles. It starts up much more quickly too.
The engine computer runs the car at a higher speed (watch your revs) at first startup, and then gradually brings this down to a more sane/normal idle speed after about 30-60 seconds. All cars (and definitely all Mazdas) with the 4 cylinder engine (at least) do this. My 6 starts up at around 1400-1700 rpm and then revs down to 650-700. My older (95) Pro also starts up high and then slows down, but its a DX and lacks the tachometer - so i don't know the exact range. Normal behaviour
After a minute or two, though, it was so warm in the car that I couldn't even stand it anymore. I held my hand up to the vent (switched all the way on the cold setting, and on 2) and then outside, and the air coming through the vents was *significantly* warmer than the outside air. This bums me out so much! Why does it do this? Is it abnormal? I don't want to have to run the A/C whenever it is warm out! Please let me know if I'm going to have to learn to live with this, or if it's a problem I should have looked at.
Philippa
I generally drive either with all the windows up and the A/C on (usually on low) (this is the first A/C car I've had), or with all the windows down and the fan off. Maybe I run the fan at 1 or 2, almost never more than that. The cool side of the hot/cold dial doesn't really do much if the A/C is off.
