My windows don't rattle...
My gf always starts her car by turning the key on 2 or 3 clicks until some of the warning light go off. When I got my new car, she convinced me to do the same. So I always do that, and I still have the problem. Really wierd. I guess as long as it starts it starts. ON a side note, I put Mobil 1 synthetic in there last night for the winter months, so I'll see if that seems to help the cold starts. I don't expect to see any difference, but I'm hoping it will help keep the engine in tip-top shape.
Anyway, its probably just the cold causing the rattles, except for that passenger door thing. I'll remove my door panels in the spring to see what I find...
Douglam - what kind of speakers did you put in? Did you keep the stock head unit? What were the results?
Oh, I put in Polk speakers in all the doors. EX572a's in front and EX602a's in the rear. The stock head unit is still on. The results are not that impressive (as I expected) because the stock head unit doesn't have much driving power (my guess it's like 4x15w RMS). However, the highs are definitely clearer now. The bass is lower, but there's no 'punch' to it.
Since I still have my aftermarket radio from my previous Civic, I was going to install it in my P5 anyway. I'm sure the results will be much better after everything is done.
So for those who are going to upgrade their speakers ONLY, don't spend too much on them, and make sure that the speakers can match your low power stock head unit. With proper tweaking of the 3 band equalizer, you can get pretty 'decent' music from upgraded speakers.
Hope this helps...
I have taken it to the dealership numerous times. The only one they've been able to fix is the front dome light rattle. I was there when they fixed it and all they did is take it a part and put back together again.
I still have all the other rattles that have been mentioned in other posts.
Good LUck to anyone who can get these resolved!!
As an aside, my brother drives a 2000 626 and it comes with an audio system which I think is Bose and the same one they were putting in Miatas for a while (I think). It is far superior to that of the Protege and, as much as I dislike Bose, it's a very competent sounding car audio system. Every time I get into my Protege after listening to some quality audio (car or home), I'm always struck by just how dark and a little murky the Pro's sound system is. I get used to it but it's truly a dark and recessed sound and nothing like the sparkle and shimmer I've come to love from audiophile-grade headphones. I can't complain about bass though because my sub took care of that
The speaker wires are dental-floss thin too! so again, don't overspend on speakers unless you're going all out for a full upgrade. Pioneers are easy to drive speakers and they go well with many head units and they are reasonably priced. My Polks require higher power.
Oh, as an update, I would highly recommend people who are changing their speakers to add in some extra insulation in the door panels. Now there are no noise whatsoever coming from the doors! even road noise! now i can only hear noise from the window upwards. The music seems to sound better also
And one more thing. The rattling noise coming from the door might be caused by the speaker harness that is just floating inside the door . Just to be sure, I wrapped a piece of foam around the harness before placing the speaker in (yeah, i reused the harness with my new speakers).
The stock head unit will not put out anywhere near 15W RMS. I'm guessing 15W peak power. A good aftermarket head unit only produces 20-22W RMS, and the difference between 15 and 20 RMS wouldn't be that noticable. My infinity speakers need a 7W RMS minimum, and I'm guessing that this head unit is just barely meeting that requirement because the sound is still fairly quiet even at with the volume turned up to half. I'm guessing that most of you who haven't replaced their speakers or head unit would find the sound fairly loud at half sound level...
I'm going to wait until the harnesses become available...supposedly in January according to Best Kits. Metra still has no idea. Didn't hear back from Schosche (sp?). Then I'll have plenty of power for my Infinitys and my next project become a small sub setup....
I am trying to decide between the Toyota Matrix and the Protege 5. Here is how I am comparing them, add any comments if you like.
Protege5- better handling, cheaper, better seats, been on the market for more time, looks better.
Matrix-better cargo area, Toyota brand quality, better stature or presence, better standard features (adjustable intermittent wipers, better door lock system, air filter).
Any thoughts? I am leaning towards the Protege5 today, mainly because of the price but it only $1000 difference.
Some of you have removed the roof rack. Is it pretty simple? Just unbolt and bolt those flat covers back in their place?
Rob
While overall I'm pretty happy with the car, there are two issues that are causing me some concern:
1. The engine rattle when the car is cold. Obviously this is a very common problem, I noticed it the second day I had the car, and it took 2 dealers and a call to Mazda to finally unearth a technical bulletin that explains that Mazda "believes" (!) the problem is "the result of the timing between VTCS plates 'opening' and the ignition spark advance command", and is no cause for concern. Even more disconcerting is the fact that this problem dates back to the 2001 Proteges and Mazda has yet to address a solution. I recently read a post that said Mazda was close to devising an ECU reprogram that would solve the annoying problem. Any insight would be appreciated.
2. My fuel economy leaves much to be desired. Granted, the car is an automatic and I primarily do city driving, but 20-21 mpg is far from acceptable--with numbers like this, I might as well own a Yukon. Again, I read a post that said the problem may be due to the oxygen sensor, either a faulty connection or the unit itself.
On the plus side, I've yet to experience many of the interior rattles others have noticed. A common complaint is a rattle coming from the passenger door or glove area. I had a similar problem initially. After sniffing around a bit I discovered a small square panel just below the lower vent on the passenger side of the center console. The piece sits in there pretty loose, so I pulled the panel out until it sits on top of the adjacent panel and that seemed to do the trick, no more rattle.
I'm going to try a few more tanks of gas. Strangely, Mazda suggests that you use the lowest octane recommended for the car, which in this case is 87. We'll see if that helps.
On the engine rattle front, I have some very reassuring news. I just got off the phone with Mazda North America and a fix is indeed on the way. By mid-March dealers should have an ECU reprogram that will solve the problem.
Once again - use ONLY the recommended octane fuel, not higher, not lower! Both will affect the way your car performs (without going into details!)
"Recommended gas: 87 or *HIGHER* ((R+M)/2 method)"
FWIW --
Meade
Meade
http://theserviceadvisor.com/octane.htm
Meade
* Note: In VERY old cars, swtiching from dino to synth can uncover leaks that the dino kept plugged.
Octane is not an ingredient in gas but a measure of performance. the higher the octane the higher the temperature at which the gas will self-ignite.
Higher compression engines require higher octane because higher compression equals greater temperature...if you use lower then recommended octane you get premature ignition or "knocking"
compression ratio is one of the ways to get more HP out of engines of similar size... the high output honda engines such as in Civic Si have higher compression ratios and thus require premium gas.
save your money and just buy 87 octane.
I'm a spanking new owner of the protege5 and also new to the world of manual shifting. I'm wondering if anyone could inform me of the optimal speeds for shifting into the various gears?
The owner's manual doesn't seem to detail the speed ranges, so I'm hoping fellow p5 owners can help me out with their experiences. Thanks!
Shift speeds are almost completely subjective. When the engine is cold, one need to be gentle so shift at maybe 2,400 or so rpm. Once the engine has warmed up, I will shift in the low 3,000s if I have company in the car and have to act respectable, or closer to 4,500 to 5,000 rpm if I am alone and out having fun. The engine zooms to 4,000 rpm with ease. I go to the redline occasionally now that the engine has broken in (I have 8,000 miles on it).
I purchased a mica blue protege5 in the middle of February. Now that the weather has warmed up, I washed and waxed my car today. I noticed that the hood and roof feel as smooth as glass to the touch, but the sides of the car don't have the same feel - they are almost a little rough and have considerable more friction as you move your hand across them.
Is it possible that there is a consistency problem with the clear coat on my car? Has anyone else noticed this with their paint job?
Does anyone else have this problem? Does anyone know if Mazda paint is more delicate in general than other makes? Or am I just being overly sensitive to my car not being new anymore?
Thank-you for your input.
I've got a black mica '01 LX 2.0 5-spd. I can't count the number of chips on my hood. I am going to have to go nuts with the touch-up paint when I wash it next.
I've had my car since June 27th, 2001. I was freaked when I saw my first paint chip...now there are so many!
I don't think it's a Mazda paint thing. Cities in Western Canada (and the highways) use a lot of gravel in the winter...makes it hell on the paint.
I don't really want to put a hood deflector on, but it looks like I may have to
I've had a set on my '99LX since, well, '99. Not a chip in them. Too bad they didn't offer the full front-end protection set (I got mine from Stongard, which offers the kit for 3rd gen Pros and P5s). The headlamp ones were easy to put on. I'd look around for an experienced professional detailer to put on the front-end kit.
The downside, as with all protectors is that dirt accumulates around the edges. The upside is dirt can't get underneath it. It's also transparent, and hasn't yellowed from UV exposure as far as I can tell. They claim the headlamp material will take the impact of a 1in round stone at 100mph (at least that's what one installer claimed on last week's Motorweek episode).
On the same topic, can anyone recommend a way to get wax off the roof rack plastic? I accidentally got a few swipes of wax on some of the plastic parts, and it's a little bit of an eyesore, but very hard to get off.
Also, Mother's makes a product called "Back to Black" that has worked for me before. I've also read that a regular eraser (yes, like on a pencil) will work. Oh, bug and tar remover works too....so take your pick
