Pontiac GTO
This, and the "pedal sensor problem" are exactly why I am upset that GM went with drive-by-wire for the LS2, rather than a throttle cable as the LS1 had in the '04 (and every other car I've ever owned). Why do they constantly need to over-complicate things? As you complicate systems, you introduce additional areas for potential errors or failures. The "pedal sensor problem" is an excellent example.
And, when I press the pedal, I want the engine to respond. I don't want software to do a series of calculations, look up values in a table, and then decide the degree to which the throttle will actually be opened, and how quickly, for me!
I guess I really should have moved on the remaining '04's... While I thought the '05's were better (with the LS2, beefed up A4, hood scoops, and split tailpipes), now I'm not so sure. The LS1 is a proven engine (has had 7 years of experience and bugs worked out), and the throttle table for the LS2 may actually limit your use of the 50 extra hp anyway.
--Robert
Same question applies for the stereo speakers. Seem like good sound but just wondering over time if they maintain their initial quality or develop rattles. (I hate rattles in a car..in case you couldn't tell!).
I replaced the door panel and rear panel speakers, as well as the subwoofers, since the stock ones sound like cr, er, junk. Only spent $150 or so and the improvement (especially in clarity of sound, particularly at higher sound levels) is fantastic. After looking at the stock speakers - they are absolute paper junk. I'm not out to bomb the bass/wake up the neighbors/set off car alarms with my stereo, but I don't want distortion at middle volumes...
--Robert
Certain aspects of the car show its Australian heritage, and how it really wasn't designed for cold climates. For example, there are no HVAC ducts under the front seats. The side windows tend to fog unless you remember to turn on the A/C (something that's typically done automagically when the defrost is activated in most GMNA cars). The door switch sensors on the '04's don't seem like they would hold up well in a cold and snowy environment (revised for '05).
--Robert
2.K/N drop in air filter for 2005 is out? p/n 2978?..does it do anything for performance?
3. SLP 160' THERMOSTAT replacement? does it do anything for performance?
4. PREDATOR Diabolo sport PCM programmer is out for the 2005???anybody heard about this??
thanks everybody...
2. K&N... don't know yet. The '04 proved to have 12-19 rwhp benefits, but the MAF tube is bigger on the '05, so I kinda doubt it will provide that much benefit. Interesting was the '05 GTO prototype at the GTO Nationals had a "GM Performance Parts" intake on it...
3. Some say the 160 thermostat helps - don't know if on an '05.
4. Haven't heard if the Predator is out yet for '05. I'm using the stock predator tune on my '04 auto, and it helps, but it's not the end-all or be-all of performance. Think I'll be buying HPTuners 2.0 soon, and selling my Predator to another '04 owner.
--Robert
http://news.yahoo.com/s/ap/auto_incentives;_ylt=AiiBlEC.Zw9vNeMLc9pu39EEtbAF;_ylu=X3oDMTBi- MW04NW9mBHNlYwMlJVRPUCUl
--Robert
I use it on all our cars and they match the colors perfectly every time!.
Second Question: Are there any other good forums for the GTO? You guys here are great and very helpful just looking for as much information as possible.
Jason
As far as other forums go, Edmunds would frown if I posted direct links. They are out there, though... Google is your friend. Search on LS1/LS2 and GTO, et. al.
--Robert
He implied that it was almost like a line lock or tranny break on a drag car. I was very skeptical at the time.
I will take a look around Google and c what I can find for other forums.
Jason
Thanks allot again you guys are great,
Jason
in my brief experience at a 1/4 mile track with a 94 Z28, i got a couple of great launches... i was running 87 octane and it was warm - i think the low octane caused the timing to be automatically retarded, reducing torque, making for great launches!
ok, so those are my theories about torque & launches.
1) what has been your observed mileage in both city and highway? (the GTO's on dealer lots that I have test driven all say 11-12 mpg on the trip computer).
2) Does the DIC (driver info computer) include an outside temp gauge or compass? I have these in my current car and would hate to give them up.
3) If anyone has had a sunroof installed, just wondering how the installation looked and if any rattles or leaks have been experienced later on.?
4) Can't decide on the dark blue or the cyclone gray???
Thanks for the info.
2. neither
4. I have cy grey. I love it.
2) Nope. I miss the outside temp display and the auto-dim mirror. Considering getting a Gentex mirror for $219:
http://www.simplycheap.com/gent50-genk30.html
There's power to be had from the visor lights. You do need to run a wire through the firewall for the temperature sensor (I'll run that down by the radiator).
3) This is dependent on the installer. The Webasto is the preferred roof - I understand there's a 6+ hour water/leak test the installer has to do. Those I've heard who have the roof say it's great, no rattles.
4) Depends on your color choice. I am not a huge grey fan - I know it tends not to show dirt, but, to my eyes, it doesn't "pop" when it's clean, either. If I had to choose between the two I'd pick the blue. It's a pretty hard color to find these days, and it will be gone for '06 (replaced by a blood red color). Yellow is gone for '06, replaced by orange, so...
Hope this helps,
--Robert
Robert,
You are well appreciated on this forum. Your expertise has come in handy several times now. Thanks
The doors and the rear panel speakers are 6.5". I bought some Kenwood Excelon speakers on closeout from Crutchfield - were $60/pr. and came with the wiring harness adapters (I know they're out of that model). Also got the radio removal tool from Crutchfield at the time, rather than use the Allen wrench approach (though you can probably get these tools at your local Best Buy/Circuit City). I bought some 6.5" Goldwood GW-406D drivers from parts-express.com for the low low price of $9.72 ea. - they sound amazing.
If you drop me an email I can link you to the complete door and rear panel disassembly instructions (lots of screws, not too bad, just be careful of your lock buttons - stripped one of mine, just got the part today after a month and a half). To get at the rear panels and the subwoofers, you don't go through the trunk, you have to remove the rear seats and trim panels all the way from the doors back. It is a bit of a pain - did mine over 2 nights, 2-3 hours a night (left the car out, put the seats in the garage - hey it was easy to put the Zaino leather cleaner on them when they were out of the car :-). I wished I'd had some sound-deadening mat material (i.e. dynomat) - without the rear seats there was tons of road noise/it's amazing how little sound insulation there is once you remove this stuff.
I haven't yet pulled my head unit to complete my XM install (have the cable up to the passenger-side floor - will work on it sometime this week), but there is a security card/radio code. You should call Pontiac customer service - it will take forever to get this security card - but at least get the ball rolling. If somehow your code gets reset, your dealer will have to get this info. Note that my battery was disconnected for 2 1/2 months while my car sat in storage, and it didn't ask for any code when I brought it out, so I don't know if just pulling it will cause it to need resetting. BTW, you should have 2 keyfobs, each with 2 keys on them (one a glovebox lock - I took mine off - useless).
Hope this helps,
--Robert
happy to help out
To make the stereo sound marginally better now, turn off the EQ and the speed-compensated volume functions. All of the EQ settings sound like junk to me. With the stereo off, press On and 4 for a couple of seconds to turn off the EQ.
Set the bass to -2 and the treble to -1. Don't get the volume over 40-45 or the distortion will really annoy you.
Pop the trunk. On the left-hand side, behind the carpet, is the subwoofer amp, mounted to the side of the car. I have big hands but was able to reach my hand in there and turn the amp up - not all of the way, but close. Sounds much better, but the only way to really improve the system is to replace the speakers - can't say enough just how junky they are.
--Robert
That is a mix of city & highway - do both - every day.
Sheesh. The GTO is that heavy AND there is hardly any sound insulation?? Where does the weight come from? Must be just in the body...lack of aluminum or something.
If you got all of this/your dealer did all of this, you have a good dealer. I'd say that 80+% of dealers did not pay attention to these details/follow the PDI instructions...
--Robert
PS I did go through the aggrevation and expense of replacing the front and rear panel speakers with the Kenwood Excelons, kind of disappointed in the results. Maybe I need to replace the deck speakers also or change settings per Hammen's instructions.
Disclaimer: I have an A4 so I can't speak from personal experience, but this is the consensus of some of my GTO buddies.
--Robert
The security card is a credit-card sized piece of paper with black text on a white background, all typeset, not hand-printed or typewritten. I don't have mine handy, but will look tomorrow (reminds me to take the card into work and make a few copies of it - comes in handy in case you lose the card - I kept one with my title on my first car).
--Robert
The stereo mods worked pretty well all by themselves (see Robert's prior posting), and I consider myself to be a little picky when it comes to audio. I do however have a full set of not-too-cheep coaxial and mid bass drivers on the way.
Does anyone have a wire diagram or schematic for the socket on the factory amp. I could spend a while and test for continuity but would rather forgo that if someone already has it.
Thanks, Mark
Once you have the URL (i.e. http followed by www.hammen.net/newgto/images/IMG_6598.jpg ) you can then type
less than sign (no space) img src="URL goes here" width=500 (no space) greater than sign
Like so:
The width command scales your image down so it doesn't run off the right-hand side of the screen/make people have to scroll.
Hope this helps,
--Robert
:mad: every magazine is talking about......"SHELBY MUSTANGS/ DODGE CHARGER R/T SRT8" ....muscle cars of the future....................GM SHOULD BE ASHAMED OF ITSELF..........beaten by ford and chyrsler motors......no camaros/gtos.....just dodges and mustangs..... :mad:
There will be a 2007 Replacement GTO - Holden- for Austrailia, Saudi Arabia, etc on a new Sigma type platform. Why can't they bring that to the USA?
Ford and Chyrsler have their own problems as well. None of the big 3 are perfect.
