Toyota Tacoma Stereo/Audio
Dash kit: poor
service: extra poor
I won't ever buy something of theirs again.
I told them I would post pics on the internet, but they didn't care. So here are pics of the kit, sorry for the quality, it's hard to get the camera that close to something and have the pic clear. (Click icon for larger pic, click again for full size)
THanks
Unfortunately, it appears that the original poster of the complaint was a hit and run, as he never answered the question of what the seller did to help him out.
Some points that may bear on Scosche's "bad" customer service.
- Auction and online sites, especially eBay have created a whole new market for "sideways" gray-market retail. Many of the items sold through this channel are either defective, "stripped", or used.
- In most cases, an "authorized" retailer accepts the customer service responsibility as part of his agreement with the supplier. The costs of this are part of the standard retail markup. In the case of a defective product, many manufacturers and wholesalers will replace the part to the retailer, and expect the retailer to destroy the defective item. Many suppliers don't want the defective item back. Unscrupulous retailers (or individual employees) send the bad part out the back door at a fire sale price, via eBay or a garage business site, because they didn't pay anything for it. These businesses typically don't pay taxes, either.
- Many wholesalers and manufacturers are not set up with standard "customer service" departments, as their cost structure doesn't support one. The customer service is handled and funded by the retailer, as I outlined above. The higher price of the "official" retailer is not usually extra pocket lining for the retailer, but something that covers a real cost of doing business. Many folks without business experience either are unaware of this fact, or they choose to ignore it.
- Many eBay users are so afraid of receiving retaliatory negative feedback, that they won't post negative feedback even when the deal went sour.
- The gray-market issue has gotten serious enough that companies like Garmin have actually placed statements on their site: http://www.garmin.com/support/faqs/faq.jsp?faq=607 warning customers that they may not be supported if they don't buy the item from an genuine dealer.
The bottom line is that there is value dealing with a "real" retailer (and some ARE online!, like Crutchfield). Otherwise, we have to be prepared to suck it up if the seller stiffs us. Once upon a time, more manufacturers would have fixed the problem, but the problem is now so big, they often can no longer afford to!
I wish he would have posted the SELLER'S name!
You payz your money, and takes your chances...
I wanted to know if anyone has the directions to remove the stock deck from my 2006 Tacoma?
I really like my Eclipse AVN6600 too. All the stock wiring just plugs right in. No wiring harness adapters.
I ran the Sirius and GPS antennas out through the 3rd brake light and on top of the roof. Then I sealed around the brake light with black silicone adhesive. Works awesome. I love the Sirius and GPS. Watching DVDs is cool too.
Do the steering wheel controls work?
The reason that everything plugs right in is because the company that makes Eclipse is also the company that designs Toyota's stock radios. Fujitsu-Ten
Are you going to use the Scosche DD kit?
I'm just scared someone's going to steal mine right after I get it.
I ran my Sirius and GPS antenna cables through the 3rd brake light. I pulled the headliner down, then I cut the sealant foam from the outside and pushed the connectors through. Then ran the wires down the passenger side. There's lots of room above the glove box to mount a satelite radio reciever. After I was done I sealed up the the 3rd brake light with black RTV Silicone adhesive.
For the GPS you'll have to tap into a few wires. The backup wire can be found in a bundle of wires under the door sill trim on the drivers side. The VSS (Speed Sensor) wire can be found behind the glove box going into the CPU. It's a thin purple wire with a white stripe. It's in the second plug from the bottom. As for the brake wire, I just connected it to the radios ground wire, so that the head unit will think that I have the brake applied, and then it will let the DVD player play all the time. Otherwise you can only watch a DVD when the truck is parked.
how good is the gps on that system? Looking to get one now! Just need some feed back.
Thanks, and nice truck!!!
You can have the GPS going on while you are watching a DVD or CD or whatever. You can easily switch back and forth between the GPS and the DVD screen. When a turn is coming up, the sound will mute in the speaker by the driver and then the ladies voice will tell you what you need to do. It doesn't interupt the whole sound system, just the speakers by the driver, which is nice.
It will also do a split screen and show you the next several steps of your route, not just the next road.
You can do the fastest route, highway only, scenic route, no toll roads. You can easily add any extra stop-offs, like amusement parks, museums, nature parks, etc.
I really recommend the Eclipse AVN-6600.
Question is, does the factory speaker system follow the same arrangement as the JBL. Are the front door speakers subs or are they standard full range speakers. Looking for the proper replacement speaker set-up. Anticipate using the taco spacers and accesories for the speaker upgrade. taco mentions replacing the 4 speaker with full range 3-ways front and rear. I further anticpate replacing the factory door tweeters with the JBL version to prevent any major fabrication issues. They have to be better than the factory version. Intresting taco does not offer any accessories to replace the tweeters.
Any info would be great.
The stock sound system in a double cab or access cab has: A tweeter and 6x9 in the front door. The rear door has a 6.5". If you have the JBL system then there will be an amplifier and a single 8" subwoofer behind the rear seat on the passenger side. I've heard it, and it's not that impressive. You would be better off by not getting the JBL system and then add an aftermarket sound system.
I replace the so-called stock tweeters with B&G high-end home audio ribbon tweeters. I replaced the stock 6x9s with Dayton Audio RS180 7" woofers in all 4 doors.
The crossover is mounted on the door temporarily. I will soon switch to an Active speaker arrangement (no passive crossovers).
Thanks for the reply. I'm looking for the original CD player with the original dash piece that's a part of it so it will look like it did from the factory. When I purchased the Tacoma it had an after factory dash kit in it along with an after factory CD player. You interested in selling or trading?
Here's a picture of the antennas.
Also, I'm looking for a speaker that will work well with my stock stereo to begine with, then will put out a great sound when I add a new deck, and amp. later. The amp. I have is a Kicker, 35 RMS. 4 channel. I listen to Rock. Anything from AC/DC to ZZ Top. If anyone has any good advice I would appreciate it. Thanks.
If you tap into the stock wiring then you need to connect to the wiring where all the tape is, before the wiring splits off into two pairs. just take the door panel apart and you'll see what I mean.
the PXA Alpine processor only puts out to outboard amps via RCAs. You wouldn't be able to power the speakers off of the headunit.
Thanks...
Well I hope everything goes well with the Truck.
I do have a couple more questions (and thanks to pb2themax for the last answer); does anyone know the size/number of the bolts that tacotunes uses to mount their adapters? I’m getting their adapters, and probably could figure it out, but if anyone knows that could save me a step. Second question relates to the system I’m planning; anyone see any problems? Now I’m an old fart and well beyond the need to make my ears bleed, or to challenge the dufus in front/back/beside me whose vehicle is vibrating due to too-lots o’ watts. I’m just looking for a good sound that I can do myself. However, I don’t want to run into some unanticipated issues
Thanks in advance,
tt&stuph
