VW Jetta Climate Control Questions
in Volkswagen
I have a 2002 Jetta TDI and would like to add an after market digital outside air temp display on the dash in place of one of the unused toggle switches. The installation space is roughly 1 and 1/4 x 2 inches. Does any member know of a source for this kit? ABordelon
:confuse:
*) If it does, try another relay. (usually can swap with like relay in the relay box.)
*) If not, suspect the fan itself is bad.
http://forums.vwvortex.com/showthread.php?968305
Although this is for a 1999 Vortes Jetta, I still went looking on my Jetta and found that this DIY did not apply to my car. Fortunately I did find where the filter is, even though the replacement that I had bought at WalMart was not the correct one.
The filer is located under the dash just behind (or in front) of the glove box. You will have to do as us Old-School guys did back when we installed our own steroes and such.
You will have to get on your back and go underneath the glove box. There is an insulation-type material between the glove box and the firewall held by 2 plastic screws.
Once the screws are removed usnig a slotted screw driver, the insulation can be peeled off easily and reveal the filter cavaty.
The filter is held in place by a hard plastic lid that is removed by sliding it off to one side.
Then just simply pull out the old filter and replace with a new one, or in my case I just cleaned out as much as possible between the folds and then replaced the same filter.
I hope this comes in handy for someone who was desperately searching as I was. I thought about taking photos on how to do it step-bystep, maybe on annother day when the temp isn't too hot.
Good luck!
Javier
I have the feeling the fan itself is continuing to do it's job but it's like the actual airflow becomes restricted-open-restricted over and over. Any ideas????
Since its purchase date all the fumes from outside can be heavily smelled inside (especially when standing in traffic all the fumes from the cars in front of me get into my Jetta causing headache). No matter if the "recirculation button" is on or off the fumes still get inside. To compare, I have an old Saab which doesn't have the same problem, so it is not my nose :-)
Also I don't seem to hear the switching noise of the recirculation flap when i switch the air circulation mode.
I took the car once to VW service and was told there was no problem, but the issue of smelling any outside pollution in the car is a huge issue. I love the Jetta and wouldnt want to sell it. I am not very savy in repairs, but would like to have a go if I know what part needs to be changed. Can anyone help me to resolve the issue?
