You are totally incorrect!
Racing cars and street cars do not have to meet the same needs, tranny and all. An auto tranny for the street uses a torque converter. No top level race vehicle has a torque converter. Top level race cars (F1 & Champ cars included) use clutches but no clutch pedal.
Also a CART Champ car uses a sequential manual gearbox that has no clutch pedal but has an electro-hydraulically actuated clutch and a stick that you move forwards for a downshift and rearwards for an upshift. Makes it impossible to miss a shift. An F1 car has the same thing except the shifter is also operated electro-hydraulically and both are microprocessor controlled.
The clutch pedal does not need to be used for downshifts and upshifts like you said.
Of course it is also possible to shift gears in a normal car without using the clutch.
Something I like to do when I am bored.
Not something I like to hear when I do it wrong. LOL.
http://www.nytimes.com/2002/10/22/business/22CARS.html?todaysheadlines
"...Mr. Smith, architect of a plan to remake Cadillac when he ran the division during the late 1990's, defended G.M.'s decision to offer the loans across its entire car and truck lineup, excluding Hummer, even as it was trying to improve its vehicles' images.
The deals are available even on the trendy Cadillac CTS sedan, which G.M. sees as a landmark in its quest to capture buyers of upscale imports. "We wanted to be able to say, `Every Buick, every Oldsmobile, every Cadillac,' " because such simplicity gets buyers' attention, Mr. Smith said...."
In my case, the incentives did make sense because it made the car cheaper than the Volvo S80 that my wife and I were also looking at. If Cadillac changes the interest rates to better mirror the luxury competition, they may have to look at their pricing since the Infiniti G35 and Acura TL-typeS are far cheaper for a comperatively priced automobile.
One thing I have noticed about the current incentives regime: it is getting noticed by the competition. Has anyone noticed that Toyota has started to offer similar incentives for their cars through October?
http://autoweek.com/cat_content.mv?port_code=autoweek&cat_code=carnews&loc_code=index&content_code=09984489
Also, if anyone has, or is planning to, change wheels and tires, please share your fitment experience.
I read that the Boundurant CTS's will have suspension mods. I'll try to find out what exactly those mods are and will post if successful.
Thanks in advance!
Oh and ccxarch...thanks for sharing, buh-bye now, this is a CTS board.
BTW, why post the "Cadillac 1994 seville" note here? This is for CTS stuff. Or are you simply trying to dirty up GM? It's an eight year old car. If you don't like it, get rid of it.
The sales people are really happy as the CTS doesn't stay on the lot very long. I was surprised at their level of knowledge. If they didn't know an answer, they were willing to call another salesman over to answer my questions. I was just in for an oil change on the other car, but they were eager to talk CTS. What a change.
Mcgreenx - My wife co-signed for a used Explorer for her son, when our grandson was born. An extra key at the local Ford dealer (stepson is good at loosing keys) is $75. Also, do you have an uncle (cousin) Aaron that had a sailboat on Lake Michigan? I used to crew on sailboats with an Aaron Greenfield.
Rich
But it you do see a black CTS on GA400 and the driver has a big grin on his face, keep me in mind. :-)
BTW, its funny how many of the magazine reviewers knock electronic stability control systems like Stabilitrak, but it seems that for the most part, the only place you wouldn't want to use it is weekend racing, or magazine slalom tests. Most of the rest of us in the real world like to know that these systems are there to potentially "save our bacon" if we get into trouble.
calicadi: As I said above, I've been moving around between 40 and 42 psi. I like 40 better, so maybe I'll go lower per pmdriver's suggestion. As far as mods go, my car is a bone stock base model. Except for the shift knob. I have a new shift knob.
I still owe you guys some pics from the last autocross event. I've been a little busy hunting don a prospect for the rally car I'll be building. If anyone has a 1990 Eagle Talon TSi AWD or 1988 Toyota Celica AllTrac they want to get rid of for $2000 or so, let me know.
Also, read that AutoWeek article, and was shocked. I think I, poor driver that I am, can get through the slalom at faster than 42 mph and 0-60 in under 7.5. What was it, intern test day at the mag?
I never auto-x'd on street tires, but the first couple of years I did open track events, I did them all on street rubber. I'd run 37-38F (since 2nd creek is typically murder on your left front tire I'd run it 1 lb. higher) 36 R. These were cold pressures for 235/40x17 tires.
Here's a suggestion: Start out with stock + 1 or 2 psi all around. If you're getting a lot of rollover onto the sidewalls in front, bump 'em up a lb. If not, leave 'em alone. At that point, if you want to get rid of some understeer, drop the rear pressure a little at a time, and keep an eye on rear rollover. Remember what Bob said in the rookie walk: "Sometimes you have to sacrifice a little grip for better balance." Believe him, he's probably one of the best solo drivers in the country.
If you're serious about hunting down a cheap Talon for a beater/project, join the Club DSM mailing list. I'm friends with a few of those guys, and FWIU, there're always cars out there.
More rear negative camber, and more rear anti-roll bar, sounds like you're setting up for higher-speed corners and best use of rear wheel grip. Autocrossers might be able to use more turn-in grip, what's the OEM front camber setting and adjustment range?
I will check out Club DSM; thanks for the tip.
And jemiller has a good point. Can you add more front camber?
http://www.racerphoto.com/gallery/album04/IMG_0184
No CTSes in that run group, so far as I could tell.
As for "the same level of poise" I suspect what he means is that both manage a decent level of NVH control and all-around civility in day-to-day use, but that (in exchange for slightly sharper ride motiions and paying more attention to rear tire wear/rotation) the FE3 is intended to be crisper at the edge of adhesion.
Thanks guys you are great. Thanks trichard and sevenfeet0 for the info you provided to my post.
Before laying down the cash I checked the Audi A6. Audi offers a 2.4 litre A6 which sells for the exactly the same cost as the CTS, and they made me a deal were it would have saved me a $grand over the CTS. Wonderful car with excellent details and fit and finish and excellent dash board, i loved the window shades and wished they were on the CTS, but the exterior is too lame and the 2.4V6 is too weak for me, i want a performance engine. As for the BMW, I would never buy it, too expensive and have its share of regular workshop visits. The Mercedes 240E was too nice and it really had me thinking, but it was the bold styling and sub 7 second CTS engine that won me at the end.
When I went to pay for the car this morning I saw that the dealer is selling a 2002 black new STS for only $37400. That is one grand less than the cost of my CTS, and that STS is loaded including the wood steering wheel and the chrome wheels. I still went with the CTS, what do you think guys, did I do the right thing.
My CTS is sport luxury dark blue with the chrome wheels, will take delivery in 2 days. I can't wait, so does my wife, she liked it over all other cars we saw.
DTS: Deville Touring Sedan
CTS: ???? Touring Sedan ?
Congrats on your purchase!!!!! Hope that you will enjoy driving your CTS and trust me, it's fun to drive.
http://www.cadillac.com/cadillacjsp/models/cts/images.html
I've raced Corvette's on dirt tracks during the mid-sixty's and have driven 427 AC Cobra's, Detomaso Pantera's, Big Block 454 Corvette's and of course my own '98 Vette Roadster. Still, I can't remember any of those cars being more fun to drive than our CTS. The Cadillac engineering team should be complemented on it's achievement.
My one regret is that the new, more powerful 6 cylinder wasn't available for the 2003 car. Retirement means our cars will have to last a little longer, so we can't upgrade next year (maybe).
I know you can't prematurely release information, but are you involved in the testing of the CTS-V? Has the road testing of the next-gen STS started?
Will you be involved? If your team does as good a job at engineering "driving fun" into those vehicles, Cadillac will be back sooner than most " auto buff magazine writers" would like to admit.
I received a CTS CD from Cadillac about a week ago. It shows a young Cadillac engineer taking the CTS around a famous German test track (can't spell the track name this early in the morning). The manufacturing section was great too. Cadillac should have commercials that show "people build the CTS". They live in Michigan and are proud of the cars they build.
Just my opinion,
Rich
I am taking delivery of my CTS tomorrow, and the fisrt thing i will do once i pass the first 1000 miles it to really test the 0-60 times. Hope i will not be dissapointed
Macguy, was the STS new or was it used or a demo? A brand new STS for that price would be VERY tempting. I like the CTS alot and for it's price it is a great car, but the STS is pure luxury. And nothing sounds better than a Northstar V8 at full throttle.
Cadillac Touring Sedan
The car really loves to go fast and I felt if I would have had one more run that day I , too, would have been in the 15 second area. There is only one more chance this year and I'm going to try again.
Just wait til you pass the 1000 mile mark and you will see that the car does what it promises. I did the times with a manual transmission and was really out of practice.
I make it a practice never to accelerate(race) on a regular street but sometimes the person in the next lane just asks to see what a CTS can do.When the challenge is put out, I generally accept. I have the luxury package not the sport so I cannot answer what differences if any there would be.. I don't believe that anyone else has gone to a dragstrip with their CTS. But I just had to go with this manual trans to see what it could do. I also feel that since it was raced the car seems to accelerate more quickly and gets the RPMs up there faster.(Probably just wishful thinking)
I don't feel that you will be disappointed at all. Just enjoy!!!!!!
S in SRX stands for S Series just like the next STS.
Here is how the naming thing works.
First letter:Denotes the series (S Series C Series ect...)
Second letter and third describe what type of vehicle it is CTS (Touring Sedan) SRX (reconfigurable Crossover) XLR (Luxury Roadster)
Haven't seen any reference to it on here, but the current issue of CAR (the Brit mag) has a shot of (a dark-primered CTS with big many-spoked wheels) what they claim is the CTS V, and they quote rumor that it's 3 sec/lap quicker around the Nordschleife than the M3.
CTS does not stand for anything. It is the C-Series Touring Sedan. Escalade will not receive an alphanumeric. Seville and Deville will be discontinued at next model introductions.
Catera Touring Sedan? Maybe...
Cimarron Touring Sedan? Good lord I hope not...
Calais Touring Sedan? Does anyone even remember the Calais?
Well, there is at least a pattern of naming entry level Caddies starting with the letter "C" since the early '60s. So I guess "CTS" works.
Series 61 anyone? :-)
LAst but not least, some guys on this list did mention that they were more impressed by the CTS after having driven a loaner Deville (or may be Sevill). I really did take that into account as well as all the good reviews i read here. My brother did consider an STS 2 years ago, but was put off by the not so exciting posts and problem reports on the STS forum. But htis forum has nothing but praise and very little problem reports.
Ah.. and another thing, this siville comes with free maintainace for the first 3 years or 60,000 mi of owner ship. i.e., you only pay for gas and take care of your tires, and that is it; you pay for nothing else, not even an oil change. The same apply to my new CTS. Do not know if that apply
Will be picking the CTS is 5 hours from now, by US time most of you will be just waking up. I can't wait...
