Don't forget that most - if not all - of those "other" brands that have manuals sell them overseas in Europe and Japan and over there they are the predominant tranny choice. They don't have to sell a lot here to justify the added cost.
Also BTW, I thought I read here that the '04 is doing away with the round steering wheel radio volume control. IMO that's one of the handiest steering wheel controls I've used. The four programmable buttons on the left are nice, but once programmed to my liking, I never change them.
lemon buy backs ? There is a CTS stick with all the goodies in todays Syracuse NY paper at a Caddy dealer for $29,990..........
They have a new base stick in stock for 31k. Plus 2 automatics.....
Also the winshield wipers are not automatic like offered on the old Olds products.
What other things are missing?
The issue is whether offering a manual transmission ON THE MOST POWERFUL MODEL gets the car into a buyer base to which it would not otherwise appeal.
Re BMW 540i/6s - yes, some end up back on the used market fairly quickly, when the buyers tire of commuting in them (notably those who don't learn about drilling out or removing the clutch delay valve.) But in general people who buy 6-speed 540is are THE most loyal of owners.
Somewhere down the road, it'll be something of a non-issue - "sequential" controls are turning manual transmissions into automatics without torque converter losses.
That's fine with me - as much as I hate so many late-model automatics with their "I don't care what you do with that lever, I know better than you do when you should shift" control strategies, I have no love for clutch pedals. If I can have something that shifts when I want it to - not two seconds later, not half a second later, but NOW - I don't care whether it's helical spur gears, planetary gears, or three toothpicks and a rubber band down there.
In response to my question ".... enhancements will include substantially increased horsepower; manual or "automatic-manual" transmission; performance-tuned suspension with StabiliTrak; larger wheels, tires and brakes; additional instrumentation; unique front grille; dual exhaust with visible tips; unique seating surfaces; and V-Series badging, both exterior and interior. We do not know what type of engine, but it will be powerful than the 3.2 V6, currently in the CTS".... from Cadillac.
The suggestion was made to look at a CTS V for 2004. It will have a 6 speed manual trans or a manual- auto trans. No mention of price though! I'm sure that it will cost a lot more with a lot of included features that were named.
All I wanted was a manual 3.6 engine....oh, well.
I'm not so sure, so thought I'd ask. How many of you are first-time GM people? How many are first-time American car people?
Why this is interesting is that I have a Lincoln LS, and it turns out that many of the enthusiasts who have LS's are first-time Lincoln people, so the same may or may not be true of your car. If the goal of Cadillac (& Lincoln) is to bring in a different (younger) demographic, part of the question is whether they're just canabalizing their other lines, or whether they're bringing in people who wouldn't have otherwise bought from that particular branch of the Big Three.
I'm betting on an LS6, perhaps with a few 'marketing HP' shaved off the Corvette numbers. Since the LS6 costs basically the same as the LS1 to make, it's entirely a question of whether GM has the nerve to do it. (Side note: bone-stock 500HP '03 Benz S600 bankerwagen, show up at dragstrip, line up at the tree, put your foot down, 12.45 @ 114mph.)
I'm also betting the first year's production, at least, gets a full-manual T56 - I'd like to think GM might have a sequential-shift test mule running around, but (a) how fast can the software integration be done and (b) did Tremec give Ford an exclusive on the sequential-shift T56 for some period?
Sonjaab.... there's no way to tell what the deal is with manual CTS in Autotrader... all I know is they were used w/about 10K on the clock.
I've only seen those 2 manuals so far, at $20K and $21K they are by far the cheapest used CTS I've come across. We'll see if this continues as more come up for sale.
Regarding price; The CTSv does not neccessarily need to creep up in pirce more than a few grand. The LS1/6 engine is not neccessarily more expensive to manufacture than the ne 3.6L V6. How much more can larger wheels and brake rotors cost?
The only difference is the size of the bore and the size of the pistons.
Buyers are willing to pay it, so DC charges it.
I would guess that the CTS V will be a good 4K+ more than the regular version.
As far as extra costs go it is incredibly expensive to retool parts.
I am sure you are all familiar with the Camaro SS. When it first came out it had the 5 spoke Corvette ZR1 wheel. A few years ago they came out with the 10 spoke design. Cost of the new wheel design was $1.4 million!! Gotta sell a lot of cars to make that up.
You need a different cooling system, different cooling/fuel/vapor/power steering/heater/etc. plumbing, the exhaust system will be completely different as will much of the engine-compartment wiring. On a single-unit basis the cooling and exhaust pieces would probably be 40% more expensive than the V6 parts, but you have to factor in lower quantities.
Presumably Tremec has cooked up a T56 that puts the shifter through the same hole as the current Getrag box (the one they aren't selling many of), that it all fits under the stock floorpan (the T56 is a pretty big piece of hardware) and a lot of the current manual-transmission bits will be used. As an aftermarket piece the T56 is expensive, at the OEM level it was cheap enough for GM to use it in the cheap Camarobird, it may be cheaper than the Getrag box in the manual V6 cars.
You need a shorter, stronger driveshaft and (probably) stronger axle shafts and CV joints.
One hopes the CTSv gets a decent limited-slip - Torsen, Hydratrak, etc. This is a fairly pricey item, but there's no good way to do without it and, once again, GM got the Torsens cheap enough to use in the high-end Camarobirds.
We'll see how far they go on brakes, most of the obvious competition wear four-piston fixed-mount calipers at least in front though the C5-style two-piston PBRs would probably be adequate and not too expensive. The M5 uses a floating iron single-piston front caliper, though its brakes are one of the weaker aspects of the car (numbers are fine, feel isn't.)
Presumably it gets big wheels and tires (hopefully not chromed 20" bling-bling crap), different seats, probably a different steering wheel, various trim changes.
And you have to pay off the engineering and development costs (the time spent fixing the differential-carrier bushings that twist too far under the V8's torque, figuring out the right alignment settings, working with the tire guys to get rid of that road-rumble that buzzes the keys in the ignition, etc.)
When you add it all up, and figure in that pricing on a car like this is based not necessarily on what it costs to build but on its perceived position in the marketplace, I still say $50-54K. That's in M3 country (a smaller car that sells to what I'd say is a different market), about where used E39 M5s are getting to now, the cheapest new competition is around $60K right now (Jag S-type R.)
way to go general.........
same old.
In fact it is Cadillac's only vehicle not to suffer a sales slump.
CTS production:
This week: 1420
This month: 5298
YTD: 14,452 vs. last year: 8,177.
production of the Deville, Seville and all 3 Escalade variations are down.
Cadillac:
YTD: 53,710 vs last year 56,390
Cadillac needs it's new product on line now!
Initially, I thought the CTS interior was too cheap, however I have come to realize that's only because I was comparing it to the ES300. Love the Lexus, but the much maligned transmission problems have scared me away.
Thinking about getting the CTS by Monday so I can take advantage of $1000 GM Loyalty and $500 extra GM Master Card bonus rebates.
The silver CTS with the black interior really looks nice!
3.2 will only come with a manual for 04 and 3.6 wit auto only. I would guess that the auto 3.6 will be priced higher than the current auto 3.2. It also looks as though some options and packages are changing for 04. Hopefully prices don't go up to much. GM raised prices by quite a bit on the Aurora for the second model year and sales fell dramatically. Also, I believe that the CTS was supposed to list at a higher price but was cut by 2k or so just before sales began last year.
I have looked at the options list again for the 2004 Cts and I am puzzled about the manual trans packages. Although there are several new options included if I reading correctly, a manual trans cannot get the memory seats (A45), not even seperately buy it on a 2004. Strange since the 2003 has it.
Bigdaddycoats check this out and see if you concur.
Go back to pmdriver2's comment the other day. He said, "I don't think the manny future is as dire as you may think". Something is coming that he can't tell us right now. I don't know if everyone can wait until it happens, but there is always the 3.2L with a stick or the CTS-V with a stick.
oldsman01 - I own a '99 STS along with our CTS. While I love the power and luxury of the STS, if I want to drive for fun, I take the CTS. If you look at the 0 to 60 stats, they are quite close. My CTS might even be a bit quicker due to the extra weight of a carriage roof on the STS. There is no comparison when it comes to handling. The CTS is a super star and the STS is sluggish.
Still, The STS says "Luxury" sitting on the driveway, while the CTS says "Sports". Whichever you choose, if it's your choice, you won't go wrong.
If the ecomony recovers, my STS will be traded for an SRX in a few years. At 60, I know my driving years are limited. I want to go out with a bang, not a whimper. As such, I will try to own the "sportiest" Caddy I can afford.
Rich
Took the CTS in for the recall on Wednesday. It checked out OK. The mechanic said that they haven't found one with a loose bolt yet, but it was only the second day of the recall appointments. He said that the CTS has been their most "trouble free" car so far.
Rich
(Sorry, no offense intended)
