Lexus ES 350 Real World MPG
To the early buyers: What kind of real world MPG are you getting?
ES 350 Specifications
City to freeway driving. 65% to 35%. But I'm pleasantly surprised with the MPG. I get avg around 25-26. Better than my old 4-clynd '99 Honda accord.
Currently I'm using 91 octane. I'm giving it a break-in period of 1,000 miles. After that, I'm going with 89 octane. My salesman said, 89 should be fine.
25 mile one way commute to work
60/40 city/highway stop and go traffic along with some long stretches of open roadway....45-50 mph along those open stretches.
AC used more in the afternoon than morning, this is Central Florida.....yesterday 97 degrees, huge humidity!
Traveled 212.7 miles (using trip reading)
7.486 gallons = 28.413 mpg
This is actual mileage.....figured the old fashion way.
I think my "tank average" reading on the gage cluster was pretty close to reading the same number.
I only have 300 miles on the odometer.... just bought it last week so this was my full first week of commuting to work....
If this keeps up....I'm impressed!
anyone with octane ratings please post your experiences with 89. is it ok with 89 any technical info might be good. does mixing or changing fuels...work?
I had always thought, perhaps incorrectly, that even if you could use the lower grade fuels you would burn more of it and hence need more frequent fuel stops. I guess this would mean lower mpg, etc. Is this faulty thinking?
SammyS
I gassed up and immediately got on the highway and drove straight for about 45 miles at a fairly steady 65-70mph with the climate control shut down (it was 68°). When I got off the highway and rolled up to the first light the "tank ave." told me I had done 34.2mpg !!!
About a mile later after a bit of stop and go traffic it was still reading 33.3!
The way I figure it, this incredibly efficient power plant, with its VERY healthy 272hp on tap is giving me over 50% better gas mileage than I was getting from my '02 ES 300 (good for only about 23/16mpg in real life driving).
I'm a bit surprised that the almost incomprehensible efficiancy of this engine doesn't get more press. It's really unbelievable. And, let me tell you, when you need the power and you put your foot into the accelerator, this thing is a rocket ship!
Heck, the way I figure it I'm still "only" paying the equivalent of about $2.25/gallon.
I've found the trip meter takes at least 45 minutes of driving before it will settle down to give a consistent and accurate reading.
BTW, these mileage figures are based on dividing the number of miles driven by the number of gallons used, not by relying on the car's mpg readings. In my ES350 the car mpg readings are usually within 1 mpg of what I calculate.
This topic is beat to death on all the auto forums and I doubt anyone actually converts from one opinion to another (it's bad - it's good, it's stupid - it's smart) despite all the discussion. This is simply my experience.
Now that we've had some cooler weather here in NC, I'm finding my mileage without AC to be 1.5 mpg better.
87 or 91 octane doesn't make a difference.
The 3.5L V6 engine used in the '07 Camry is exactly the same engine used in the '06 ES 350. Both "versions" use knock sensor transducers (piezo-electric microphones which pick up the first hints of "knocking/pinging" before human hearing can distinguish such) screwed into the cylinder banks to feed the information to the engine control computer to tailor the ignition advance tuning on the fly. But the EX 350's engine is rated to 4 hp more. Why the difference? The EX 350's recommendation to use 91 pump octane vs. the Camry's recommendation to use 87 pump octane. Next time you're due for a fill-up, pump half a tank of 87 octane regular grade gasoline in. You'll know within several miles whether your engine has any increased tendency to "ping" - it probably won't. But, if your engine does ping (and a few miles will NOT cause engine damage), then pump the remaining tank volume with 91 octane premium gasoline - the combo will net you a tankful of your customarily used 89 octane. No harm, no foul. If, as I suspect, your engine remains as characteristically quiet as previously with mid-grade 89 octane gasoline, it's doubtfull you'll ever miss the extra two horsepower that the mid-grade fuel delivers. Whatever fuel economy difference you note will A) be more theoretical than real,
I've noticed no difference whatsoever between 87 & 93 octane fuel after thousands of miles of driving on both. Same power. Same engine sounds. Same gas mileage.
Good information - thanks for sharing. The same displacement engine used in the 2007 Camry V6 models is rated at 4 hp. less on its recommended 87 octane unleaded regular. It follows that operating an ES 350 on 87 octane would likely result in similar hp. to that of the Camry. Realistically, how important is an additional 4 hp when the Camry is already rated at 268 hp.? Or to rephrase, is an additional 4 hp. really worth 20 cents/gallon extra at the pump? That drop from using regular unleaded is only a 1.47% reduction from the 272 hp rating of the ES 350. The detergent additives in gasoline are federally regulated at the same minimum level regardless of octane rating. "Top Tier" gasolines carry a higher minimum level - again equally spec'd per "Top Tier" standards across all octane grades among gasoline brands agrreing to adhere to the "Top Tier" standards and who pay the price of certification for bragging rights.
Currently, my 90% city (short stop and go avenues) and 10% highway mileage is 24.6 mpg.
I am not sure about the type of the gas filled from dealership, but would think its to be premium. So far not worried about the lower mileage wondering when would I get the improvement. The car has about 350miles on it.
It would have been nice if there was an overall avg speed reading. The avg speed gets reset every time you turn the vehicle ON/OFF. In my BMW I had the overall avg speed reading which I would reset every time I fill gas. So if my avg speed was 25 mph then I knew for that gas tank I did more city driving and less highway driving. And if it was 45-50mph then I knew I did more highway driving and it would explain the variation in the avg mpg from tank to tank.
I'm sorry to say that it's rare anyone passes me on my daily 100 mi roundtrip commute. I get overall 26 mpg driving hard (avg 80-85mph in mountainous freeway),frequently hit 90-100, have been to 125... I dont see much differance with reg vs premium.
Otherwise, I'm doing 55-70 mph.
I live in Florida but seldom use the air.
Anyway, even if you use 87 or 93, for 18,000 miles a year (10,000 mixed and 8,000 pure hwy i.e., long trips), the difference is only $200 extra in gas. This car is $40K. $200 extra a year isnt going to break anybody's wallet who is buying a $40K car.
I am not a lead foot so what gives?????
Needless to say, after reading all the glowing mileage reviews, I am VERY disappointed.
:mad:
Phoenix-Grand Canyon-Phoenix(moderate uphill and downhill)-30.5 miles/gallon
Phoenix-LA-Phoenix(flat road)-31.5miles/gallon
Phoenix-Las Vegas-Phoenix(lot of uphill and downhill)-29 miles/gallon
These trips were with frequent stops and avg 80 miles/hr speed and on couple of occasions going above 100 miles/hr to pass another vehicle. Hope this helps.
