Drivers inside door handle snapped right off one day. Thankfully still under warranty at that time.
Now transmission slipping. Hoping it just needs flushed. Whatever happened with yours?
My most recent nightmare happened just a little bit ago when I was driving home and the car DIED while turning the corner. The lights on the dash remained on, but the steering and gas did not work. I was able to pull over and put in park. I let it sit for a couple minutes and re-started it just fine. Has this happened to anyone? Any idea what happened? I'm a bit freaked out to drive it now.
I had a 06 forenza standard. The power steering light always came on no matter what. Just make sure that you have power steering fluid in the reservoir and you will be fine. The check engine light will always come on. I know have a 05 automatic LX forenza. and my light always comes on. The code tells me I need a new Catalytic converter. I'm not doing that. Somewhere there is a short, a wire that is exposed under your hood. If you can find it tape it up and the light should stop. Let me know how it works out.
Joe
I had to fix the rear brakes as well last week.
Are you satisfied with that car?
GM at the time owned interests in both Suzuki and Daewoo, and rather than let Suzuki sell its own good products here, made some sub-par Daewoos, poof-tada, into Suzukis by tacking a Suzuki label on them. Anyway, GM still has a relationship with Daewoo, but not any longer with Suzuki. Volkswagen has a small (20%?) interest in Suzuki these days.
Suzuki makes some excellent cars and is a great success story in Asia, but has trouble getting any traction here with the small lineup for sale in the USA. Currently, the SX4 models and Kizashi are "all Suzuki," fun to drive, and quite reliable. The "Suzuki" Equator pickup is actually a Nissan. Anyway, if I were you, I would swear off any Daewoo product for the time being, and give little Suzuki a break.
I have had this whistle for weeks after replacing the air breather box cause the plastic holding it on the intake broke, replaced intake manifold gasket and it did not remove the high pitch squeal/whistle it definetely is not the belts because the sound comes right around the distibuter area and and spark plug area. its so loud it echo's and really hard to pinpoint the origin would this be vacuum leak and covered under the powertrain 100,000 mile warranty it goes away not completely though when engine heats up more to normal operating tempature worse when just start up and cold... also I think its reducing my mpg to like 23 mpg.. or so any ideas, anyone with something similiar have it worked on and fixed im pulling hair here to find it
I bought the car in 08 and i remember it having engine trouble and it turned out it was some sort of factory defect. They supposedly fixed it by now in 2011 I am unable to drive the car at all. I have taken good care of this car and I still owe on it. I am having to take the bus to work and walk everywhere. Any advice anyone can give me would be great. And I really don't know that much about cars. I have gotten 3 estimates to fix it and they have all said $1500 to $1850!
Any help will be appreciate
Brian
Any help is appriciate.
--Leela
Any help is appreciated, thanks
Both my back door handles fell off within 2 yrs of having the vehicle. Finally got it replaced this year!
I am having some safety issues with my 06 Suzuki Forenza and have got an e-mail chain going. Could you e-mail me and I'll include you?
davidgonz85@gmail.com
The dealer I bought it from auffenburg in illinois and they sold the suzuki dealership.
I had my seat belt recall and auffenburg refused to do it there I had to drive over a hour away to get that fixed a couple of years ago.
And some mechanics are better than others. Do a google search and see who gets good ratings or recommendations in your area. Or check Click and Clack the Tappet Brothers on npr.com to see if they list a good mechanic in your area. Good luck.
Blinking light is definitely a misfire--this is standard on all OBD-II systems far as I know.
