Chevrolet Cavalier Climate Control/AC Issues
Hi all,
Currently own a 2003 Cavalier 2.2L ecotec. Having problems with the A/C compressor not kicking on or kicking on intermittently. Yes there are some criteria you have to meet for clutch to engage
1. engine temp<250 farenheit
2. engine <5000 rpms.
3. call from dash (have to turn dial on control panel)
4. battery voltage between 9 and 18 volts.
5. High and low pressure between ?
I meet all the criteria for the compressor to engage (although I can't check high and low pressure) and the clutch will not engage. I will drive the car and then the clutch may engage and A/C will work and other times it won't. Problem is extremely intermittent with no real rhyme or reason. Dealer says it works properly but I know they are full of it. Any advice may help.
The standard fan control on a '98 cavalier. It has 4 settings.
the LAST 2 (medium high/high) work. The 1st one (low) works ok,
but the medium low doesn't work. Anyone help me out with that?
Is there something I can check on that?
:confuse:
is that right?
I just noticed a week ago that the air conditioning system wasn't cooling. Took it in to a air conditioning specialist. They said they put some dye into the system...and they at first thought it might be a problem (with the schrader ? valve or the suction valve core ?) but when I checked with them a bit later...they said that they thought they detected a small leak at the casing of the compressor..maybe around 1/2 inch. They said that the cost to replace the compressor would be around $1,000 job and that would also include replacement of the accumulator. I just went ahead and paid for the dye and the service and the added R-134A. He said it may hold for 2 days, 2 weeks or 2 mos. So...I am wondering exactly what I should do about this.
I don't really understand why he can't just fix/repair the leak in the compressor vs. buying a new one. When I asked that question...he just said that he preferred to do it that way...to better guarantee or assure that my problem will be fixed. After all...he would hate to have me come back in to him...and have the compressor replaced after all and then have to pay all those labor costs all over again. Also, something about some seal/suction at both ends of the compressor...and some lubricating would be all new, etc.
If you ask me...it sounded like a lot of razzle/dazzle...and being a woman...I tried to stand my ground and ask questions etc. but...I really wonder...if I am being hosed.
Any thoughts on this ordeal...or if you have experienced any problems like this...I would like to hear from you.
Thanks in advance for reading
All I can say is shop around to see if you can get a better price.
Thanks for your reply.
You are probably right...when you say that getting a remanufactured unit put in my car...would be better in the long run than having my old compressor fixed. I noticed that you used the words remanufactured...So...they are not NEW compressors that the repair shops put in? :confuse:
Interesting?
I suppose...they will then take my old compressor...and turn it in somewhere and get some money for that...and then that place will work it over...and resell it again.
I worked for years as a mechanic this is standard practice. Most mechanics don't have the stuff or don't want take the time to rebuild precision parts like A/C compressors, alternators or starters UNLESS they come from really rare autos. There are lots of places that specialize in rebuilding auto parts and MOST stand behind their work.
any help would be great. Thanks in advance.
Thanks for your reply. We actually got the car back today and it came to a grand total of $791.82, parts and labor. They replaced the compressor, dryer, orifice filter, vaccuum, and replaced freon oil, and recharged with 2 cans of freon. We also had them replace the spark plugs while they were working on it because the head had busted not long ago and the mechanic failed to replace all of the spark plugs. All in all, it wasn't too bad.
it's "97" 2.4LS twin cam
Thank you,
Jim.
I have taken it to 2 places: checked for a clogged line, NONE
