Lexus ES Tires and Wheels
I am from the east coast and have recently purchased a Ruby Red/Black ES350. I am very happy with my choice. I was curious though about the tire brands that are on the ES 350. In the East coast they put on the Michelin Energy tires . While in Las Vegas I noticed that they put on the Toyo Proxes. Is there any difference between the two. Are the Michelin's better for East Coast weather conditions. Just curious if anyone can shed any light on the differences.
Yesterday it was a rack of Michelin's .. today a rack of Toyo's, tomorrow a rack of Dunlops.
My 06 IS 250 I thought was gonna come with Dunlops (which I personally dislike) came with Bridgestones (not bad) probably cause it has the sports package.
Personally I like & recommend Michelin. I HATE Continential and Dunlops are so so. But that's my .02 cents and MY opinion.
have not had much (if any) experience with Toyo
The Michelin MXV's are, at best, a compromise and even as all season's are vastly outclassed by others in the same category.
http://www.tirerack.com/tires/surveyresults/surveydisplay.jsp?type=GTAS
For instance, compare them to their less expensive, but vastly superior stablemates, the Michelin Pilot Exalto A/S'.
http://www.tirerack.com/tires/surveyresults/surveydisplay.jsp?type=HPAS
And I do agree with others, this car is seriously "undertired" running only 215's. A car of this size and power should be running on at least 225's or even 235's. I think the aspect ratio of 55 off the rim is a good choice for a balence of ride comfort and handling.
Ideally, if you want the best performance from a car like this (or any car really), you should put on a good set of summer tires ( http://www.tirerack.com/tires/surveyresults/surveydisplay.jsp?type=UHP ) and swap them for a winter tire or an all season at the first sight of snow.
For maximum driving performance, go with his recommendations. For maximum fuel economy, stick with your all-season Michelin MXV's. If you drive in true winter conditions, winter tires make a big difference.
Does anyone have a problem with slow leaks in the tire(s)? I got the ES350 with Michellin Tires. The low pressure sensor came on and I filled the tire 2x before the 5k service. When I mentioned it to the service department, they couldn't find any leaks. Now, it's been almost 3 weeks since the service and the tire needed to be filled twice to bring it to the proper inflation. It seems like the dealer isn't able to do anything about it.
I was thinking of using one of the tire sealant products but I heard it messes up the balance. Does anyone have any suggestions? Has any one experienced the same problem? I could use the spare tire but then the sensor would still go on when the tire in the trunk loses pressure.
I'm new here.
What are the wheel requirements for rims if you want the tire pressure sensors to work?
AtomicDog1
The Michelin 215/55 handle well, but spin easily from rest.
I assume I could get away with 235/45-17, would be same height and about 20mm, (or 1" wider) could any one comment on this??
So far no problems. When I mentioned to the STS Salesman that
Lexus wanted to charge me $239.95 just for the tire he laughed and said " That's because they have to get it from me."
Why don't you bring the tire to the local NTB, they will install only $18.00 include vale stem and through the old tire alway for you cause I just had it done all 4 tires plus lifetime balance and roadtate. Hope this help.
Can I get away with a 235/45x17 or would I need the 235/50x17 to get the same tire height?? The 215/55 michelins just arent serious tires...
I last posted here 12/07, have since purchased Falken 235/50 ZE912's, which are AA/A and Z rated. While they give the car a slightly stiffer ride, they really improve control and handling...the stock Michelin MXV's are good for mileage and ride, but are clearly inadequate if you want to push the car a little. The above tires are 1/2 to 3/4" shorter, so you are actually going about 2mph faster at 70 than what the Odo says, but, who cares... and the profile is much more pleasing to the eye
Who makes a great replacement tire at a good price?
BTW - I noticed my replacement tires are not what came with the car...can anyone give me advice if this new size (225/50R-17) is okay on my car? I live in TX where the weather is hot 90% of the time.
I have 215/55/17. Comments on wear, noise, traction and price/offers appreciated. I live in Charlottesville VA.
If anyone has seen a better deal on another tire I am interested. I live in College Station, TX where it is hot and humid so I am not concerned about tires for snow.
Have a good weekend!
I had four tires a few years ago, I think they were Goodyears, that if I put to much pressure in them they made a high pitched noise while driving so I had to keep them at the recommended pressure and the noise went away
anyway, I have Bridgestone Serenity's on my 2008 Acura TL and after having Michelins, Goodyears, Kumhos, Yokohomas, and Generals on various vehicles over the years, I have found the Serenity's to have the best overall road feel, road grip, and road handling of any tire; in regards to noise and ride quality, while the serenity's are very good they are not as quiet and comfortable as Michelins or Kumhos
actually you are the first person I have heard complain about the noise on the Michelin Primacy's because they were ranked higher than the serenity's in regards to ride quality and noise level on tirerack.com; I mean you could have just gotten a batch that had a problem or there might be a problem with noise with the Primacy's but I can't know for sure since I don't have Michelin Primacy's
while the serenity's I would say are in the top three tires I have ever had they are extremely pricey (roughly $245 a tire for my TL) and the the only reason I got them was because I got an adjustment due to the severe problems I had with the OEM Bridgestone EL400's I had on my car; keep in mind, that the Serenity's are a Bridgestone Turanza series tire and I've seen the majority of Turanza tires on sports cars and cars that have sport tuned suspension because they are designed to give a sportier ride, high performance, good handling/grip, and a little bit of road noise/feel because those are the qualities you want and expect in a good sports car or at the very least a car with a sports suspension
in my experience and opinion, Michelin and Kumho give the best ride quality and lowest noise level; Bridgestone is best for high performance, handling/grip, sportier feel, etc; hope the information was helpful and best of luck with your tire purchase decision
Anyway, I appreaciate your comments, but I have not gotten any further along on feeling good about making another choice or what that other choice would be. Whatever it would be, I'd want it to be the last change I need to make for a couple years.
I'm thinking of the Bridgestone Serenity tires.
Mike
The Lexus dealership quoted me near $ 1200 for replacing 4 Michelin tires. I bought instead from discounttiredirect.com 4 Michelin Primacy MXV4 215/55-R17 $144 each with no shipping and tax and a local garage installer did the installation for about $65. Bought TPMS kits but installer did not need them. With the $70 Michelin rebate the total cost of replacing 4 tires is roughly half of the dealership quoted me for the exact same tire.
