Honda Civic Tires and Wheels
Hey all:
I seem to get at least two flats a year
I had to run my car on a flat for a distance so although the patch is holding, I am going to replace the tire. It's the passanger side rear tire. Any receommendations? Should I just do the one (they always recommend at least two but who knows if that's honest).
Are the stock tires crap? Should I consider full replacement?
Marc
Marc
Most small sedans come with crappy OEM tires that wear quick and do very poorly in the rain and snow, etc.
Just remember if you replace the one, you have to replace the other one of the other side regardless of if it's the front two or back two. Different tread on the same end will cause odd problems, especially at speed. Dangerous as well.
My choice, replace all 4 with a good quality set from Tire Rack and have a trusted shop in your area install and balance them, etc.
Use the rating system to see how others rate the tires. I myself usually by a yokama tire, the V4 look good. I had a set of yokohama avid t4's on my 86 civic Si and they were great tires.
You can't go wrong with tire rack. If you are unsure, ask one of their specialists to help you and OH, price does not always equate to a great tire.
It was the rear tire and the car only has 6 k miles. So, it should be fine. I will look at the tire rack however, for when I need more or when it's time to replace. Thanks for the advice!!!!!! I really appreciate it.
Marc
We all feel differently and we all have different experiences when it comes to tires and such so it's cool to feel otherwise on my view
I went to COSTCO looking for Mich. Ice-x on steel rims and was told the bolt spacing had been modified for 2006 and the don't stock. The deal is I'm not worried about putting 205/16's on if I can get away with 195/15 which is quite kosher as the diameters are the same. The diffrence is the 15's are a lot less money. Also COSTCO fills with Nitrogen for the money.
Just walked out to the garage and looked at my '06 Civic LX and the rear tires do the same thing also! Intersting actually, both our cars and now yours. Anyone else care to weigh in on this?
The Sandman
Thanks for your help.
Any help would be appreciated. Thanks all.
The Sandman :confuse:
EX Wheels
Wheel Size: 16 x 6.5"
Bolt Pattern: 5 x 114.3mm
Offset: +45mm
Hub: 64.1mm
Hollander # 16114
Structure: Aluminum Alloy
Finish: Silver Painted
Tires: Bridgestone Turanza EL400
Tire Size: 205/55/R16
Civic Si rims:
Rim Width: 7J
Tire Width: 215
Aspect Ratio: 45
Rim Diameter (inches): 17
Offset: 45 Load Index: 97
Number of Bolts: 5
Speed Index: W: max 270 km/h
Bolt Pattern: 5 x 4.50 or 5 x 114.3
Can anyone tell if me if these wheels/tires will fit without having to buy spacers or added mods? Any input on this would be appreciated.
The Sandman
The Sandman
I've searched, and can't seem to find this info anywhere -- can anybody with a 2006 or 2007 Honda Civic EX (with the 16" wheels) report what the manual says about using tire chains and/or cables? I'm considering this car, but make occasional trips in the California mountains, where chains are sometimes required.
My old Neon lacked clearance to the front strut, and required expensive (and bulky) "Spike Spiders" traction devices that I used exactly twice in 12 years (but without them wouldn't have been allowed to drive back home over the passes); I'm hoping my next car can just take a cheap set of cable chains...
Josh
I expect them sometime next week and am figuring they'll be installed next Friday at my mechanic's shop which is within walking distance to my installation.
The Sandman :surprise:
Guess I'm done with the car after this. Nothing more I care to add to it actually. Just want to enjoy it for the next 5 or so years.
The Sandman
Also, why not consider a really good set of high quality snow tires for the treck you sometimes tack.
I will check in the morning for you in the manual.
Oh, I was the proud owner of a 2005 subaru impreza wagon until someone creamed her throught a light. 2000 miles on the car and 15,000K worth of damage. Traded her right after she got fixed.
The car was a great car and is highly rated in all areas of it's segment. Would be a great car for mountain trecks and with 170+ horses in the entrey level "I" model, the mountains would be no problems.
I love my civic but loved my impreza more. I might trade back this year for a 07 impreza wagon. You can't beat a boxer engine for reliability and durability.
We have a 4WD Highlander Hybrid that will get the bulk of any family snow trips; maybe once a year if that we would want to leave that and the kids with the grandparents and take the small car up. It doesn't snow here in Sacramento, so no use for snow tires 99.9% of the time. Even up in the mountains, it's fairly rare to actually need the chains, but if the controls do go up, you chain up or turn around.
I really like the Subarus, but rarely have use for AWD in this car, and would prefer the better gas mileage of the Civic.
Josh
The Sandman
Obviously I am not impressed
They can refill the freon a million times and your a/c will not work. There is a leak in the system which has to be found. Freon doesn't just stop working, it's obv escaping out of somewhere.
My wife took the car in today. In November when the rear tire issue first arose, the service manager suggested that the out of round was because the Civics are so light in the back end that the tires are "bouncing" when hit bumps...I said are you suggesting they are coming off the ground, he said no but they are unloading...I thought this was bull and suggested that perhaps I make the wife ride in the back (no points there). The car was extremely skiddish at the rear on packed snow(first winter we owned it) so we added two sandbags in the trunk over top of the rear axle, since my wife does lots of highway driving by herself. Well aware that this is a front wheel drive car.
Today the service manager said that there was no way that Honda was changing the rear tires again because here was according to him 150lbs of sand in the trunk and the sand bags were the problem!!!
They also addressed the lack of freon by adding a dye to the refrigerant so that the "next time" I bring the car back for an oil change (at 90% right now) they will be able to find the leak...which seems lame since I might run out of freon BEFORE the oil change date....By the way the dealer is 120 miles away.
I will be talking to the service manager myself tomorrow..and then the area service representative...not a good Honda experience :lemon:
Not sure if that would help you though.
The Sandman
The noise in the car is so loud, it is hard to talk.
I have never heard of this before, and in my 40 years of driving have applied brakes hard many times.
Has anyone heard of this before or should I take this up with Honda.
Peter Barone
Chandler, AZ
If they are truly defective, a TIRE DEALER will replace them (possibly prorated) with a lot less hassle than the Honda dealer.
(Toyota will tell you the same thing...)
This same problem seems to be occurring on many new civics. No, its not the tire manufacturer's fault. It IS Honda's problem and responsibility to fix this camber issue. Buying new tires every 20,000 miles is not cheap nor acceptable. Honda needs to recall and fix these cars if this is a common problem to all civic suspensions. I intend to talk to Honda (not a dealer) about this problem and about how many people have experienced it. I encourage everyone to do the same. Maybe this problem has not been properly brought to their attention.
