Ford Windstar Problems
If I remember correctly tow limit is 2000#, but check your owners manual.
My 1997 manual says 2000# maximum weight without towing package. 3500# if the vehicle is equipped with the towing package.
Thanks for your help is really appreciated,
Sharony
Please someone advise me. Thanks!!!!
Sharony
Did you find the problem ? I have a similar problem in my 1998. When I boguht last year transmission was done and I only have 10k additonal miles.
Please let me know.
Thnks
Mehmet
I have the same problem. In fact, my transmission ws done 1ok miles ago. please respond,
I am so glad to see I am not the only one with a possessed Windstar. Our lights will flicker every once in a while and our door ajar light will stay on as well. I will be trying the tips I read here to see if I can remedy these things.
fix. There is a TSB from 2002 about this. Everyone will have this problem and it should be a recall. I believe there is a post from an aggresive consumer that had Ford pay for this. My fix cost me $600. LET's BITC... TO SOMEONE AT FORD!!!!!
Thank You and have a nice day anyway.
My Windstar doesn't run in the rain. Error code P0303. Wires and plugs changed $220 because you cannot get to them... AND IT DID NOT FIX THE PROBLEM!
At about 60,000 miles, the dome lights would not automatically shut off and had to be pulled out permanently to prevent the battery from draining.
Around 65,000 miles, the "Service Engine Soon" light remained on permanently. The dealer could find no explanation for this condition.
Around 70,000 miles, the passenger door power window stopped working. It goes down, but doesn't go back up!
Around 75,000 miles, the cheap plastic hubcap covers began falling off each tire and were gone within a few months.
Around 80,000 miles, the power steering began howling and leaking badly.
Finally, at 92,000 miles, the head gasket blew and rendered the vehicle worthless, even though I religiously maintained fluid levels on the vehicle.
Luckily, my 1997 Nissan Maxima with 100+ miles in perfect working order will be able to tranport me to my next auto purchase.
And it won't be a Ford product.
I have a 2003 Ford Windstar that also is blowing the same dash fuse!
It's almost cheaper to buy and replace the switch yourself to see if this cures the problem...
Bave
needless to say this is my first and last ford vehicle, against my better judgement and family and friends.
Kathy
info@edmontonvirtualtours.com
If oil level is checked to be ok there is only one really important thing!
Check the CMP sensor! Please believe me!
This sensor is not only for the fuel injection system!
It drives the oil pump too!
But the pinion of the CMP used to get worn and so there won't be any oil pressure any more, resulting in a damaged engine!
Don't drive any miles longer, as long as you didn't check the CMP!
Please let me know your results of checking CMP...
I have had the same Problem and solved it by replacing the front engine support.
* when engine start until oil lanp get off ( 3 seconds)
* when tranny in neutral and press gas pedal after 1800 rpm
* when driven over 2,500 rpm
* when going downhill and gas pedal completly at idle....
on all condition oil lamp remain off and engine temp stay 1/4---1/2
more than 3000 miles with exactly same condition
engine shows strong power and not any funny sign ( like when crankshaft is worn out)
can be the lifters??????
It is not that it loses power completely. When it comes back on, the station presets are there and you are on the station you were on.
Baffling. Any thoughts?
I hate to take it to Ford if there is instead a way to simply reset the idiot lights. Or should this be something to worry about?
Any suggestions or cures?
Good Luck
I have no idea where the mechanism is that detects whether or not the rear gate is open.
Did you ever find an answer to your rear gate problem?
They are located in the lock mechanism at the left and right side of the rear gate.
Just spray WD40 in and open-close-open-close....
Thats really the only way it works.
