Visitor Agreement.
I would argue vehemently with the dealer to have this covered. If that doesn't work, contact Acura and deal with them.
Somebody correct me if I'm wrong about this.
Usually wear parts in the clutch will be covered for 12K/12 months as they figure nobody should be able to kill a clutch that quickly.
It's very possible the clutch system may have been substandard and may have caused premature wear, but the idea is this, that a slipping clutch is noticeable to the driver and so if the clutch disk is worn down to the nubs, there is at least a shared responsibility here.
I'd say (speaking for myself) that if my clutch wore out at say 35K and we disassembled it and found no problem with the pressure plate or TO bearing and the clutch disk was worn down, I'd ask for some sort of "you pay parts, I pay labor" settlement.
After 50,000 miles, the whole idea of a "defect" becomes less and less likely IMO.
Really situations like this boil down to how hard-[non-permissible content removed] the dealer wants to be with you. He has discretionary monies to make good will repairs (if he's in good stead with the factory).
Anyway, I loved my TSX and I thought I loved Acura, but I'm just baffled by this.
Yeah, it's a wear item, but a clutch failing at 30K miles is ridiculous. Short of outright abuse, I can't envision a scenario where normal use would cause this, unless there's something inherently wrong with the clutch assembly.
I've been driving MT equipped vehicles for 29 years, and I've never had a clutch wear out in less than 100K miles, and they usually run out to 120K or so.
I've owned plenty as well and only my first MT vehicle wore out that quickly - first clutch at 11K, second clutch at 30K.
Next vehicle was fine at 80K when I traded it and after that was fine at 140K when I traded it.
Besides, many other TSX drivers I know of have gone over a 100K with no issues.
I bought the car used at 35K miles and i LOVE IT, it's the first car I honestly and truly love. at 46K miles, the clutch failed. stopped on the freeway. the car is under extended warranty but ha-ha, that doesn't include the clutch. I bit my tongue and paid $2K to a dealership, blaming the damage on the first owner.
10 months and 14K miles later (today), I took it in for a 60,000 mile service and mentioned that I didn't like how clutch behaved ever since another dealership put in a new one. MY CLUTCH FAILED AGAIN, they tell me. the warranty covers 12 months or 12K miles, so i'm out of luck.
may be i'm not the world's best driver, but I know that I don't burn rubber and I don't ride the clutch. 14 K MILES FOR A NEW CLUTCH!!!!
I called corporate and found out that they don't have:
(1) technical experts capable of telling me about expected life expectancies of any parts
(2) legal advisors capable of offering guidance
am I crazy? or should a clutch last longer than 10 months under normal driving conditions?
please, I'm in dire need of sanity check before I sell my baby ....
Has anyone else had similar problems with a creaky/notchy clutch pedal?
They told me that normally this is considered a wear item but that since I have had all of my services done there previously they will cover the otherwise $1800 fix. I wonder if this is bc I leased it and can just turn it in at the end? Not sure, but I will be raving about Tonkin to everyone I know!! They have always taken great care of me as a loyal customer.
Still CRAZY that my clutch went out at 25K!! Has anyone else had early problems with their 2007 MTs? I have been driving MT for 10 years now, and would hope I know what I am doing by now!!
I believe that the poster ‘levinbrook’ was exploring the possibility of some sort of class-action lawsuit, but I do not know what progress s/he has made in such pursuits.
Terrible... customer service can make all the difference!
Here's hoping your Acura has a long life now after you have replaced the clutch!!
That is really awful that you have to deal with that! With the hard economic times right now, you would think they would be fighting for your repeat business and/or referrals!
I have been driving manual transmissions since I was 15. My current daily driver is a 2002 Corvette 6 speed with over 80,000 miles. Never a clutch problem.
I am highly disappointed with Acura. This is my second Acura ( I had a manual CL a few years back) but likely my last. I expect this kind of blow off from GM but not Honda. Fortunately I am an attorney so I will pursue this in small claims court if need be. Again,my beef is with Acura, not the dealer. From other posts on this site I see premature clutch failure is a recurring problem that Acura just does not want to address.
It's my opinion that the drive-by-wire throttle is a contributor to the problem. Throttle tip-in is more sensitive/sudden than on manual cars of a few years ago (with conventional cable actuated throttles), and it's more strain on the clutch to get a smooth engagement/disengagement.
If you pull off the pressure plate and the springs fall out, that's probably a defect. Certainly a bad TO bearing is a defect (in the warranty period I mean).
But a clutch disk worn to the rivets and a flywheel burned blue---well that's probably the driver. (presuming the pressure plate is functioning well and intact).
Sometimes (often?) it's a combination effect....the hydraulics malfunction and the driver keeps on rolling in spite of that, making life harder for clutch and synchros.
Even geography is an issue. A clutch in San Francisco is going to fail more often than one in Kansas. This goes without saying, all other things being equal. And one in snow country probably wears faster than one in Arizona.
And one that tows a trailer, etc.
This seems reasonable to me and goes a long way to restoring my faith in Acura and its dealers.
I sure hope you are somehow able to make things happen! In my experience, it was the dealer that ultimately made the call to cover my clutch fix... they told me they would take care of it but only bc I had bought 2 cars from them and taken it there for all of its servicing.
I say good luck to you!! It is outrageous for them to not cover that in a situation like yours.
This has been a really interesting discussion. Looks like Acura is either really professional about clutches or there is some design doubt (or both!!)
IIRC, I have the same 6M transmission (don't know about the clutch) on my 2005 Accord 6M coupe...........77k: zero clutch mishaps.
The 2010 TSX I4 6M is a contender. Two questions:
1. Is it the same clutch/pressure place et al for the present generation?
2. Anyone who has driven both Honda V-6 6M and 2nd Gen TSX 6M: your comments on clutch engagement (My 6M is vague) most appreciated.
Holidays best, ez....
It is possible that the clutch *design* might have made compromises that could shorten life somewhat. This is often the case say on hi-po cars.
It has 64k on it, and no warranty. I started to have weird problems for about a month. The car stopped accelerating as it used to; tough time going up hills and the engine revs up higher to 5k/rpm when hitting on gas paddle; some smell from bellow the engine after a ride. I thought it’s something with the sparkles and decided to wait until the next oil service.
I had a major service done on the car recently and no mention of any tear on the clutch. If it's a tear/wear piece then why wouldn't they check for it as they do on the breaks?!
I still need to wait until Monday for the diagnosis. I am a little scared to hear how much it would cost.
I think Acura service charge way too much on any service. In my last major car service, they had to replace the brake pads. I don't understand why they would charge full price (1 hour of labor) when they already had the tires taken apart and already paid 450+ on the service!
Apparently, this is my last MT car. But I still like my Acura!
ez...
If you are having trouble with your clutch (for a month), it's up to you to tell your mechanic that you are having trouble, otherwise, he'll never know.
Dealerships do charge too much for maintenance, but I don't understand why you think they shouldn't charge you for the brake pad service. They have to remove the wheels, remove the calipers, remove the old pads, inspect/clean the calipers, pistons, guides, etc., install new pads, re-install the calipers, then re-install the wheels. None of that would be included as part of a scheduled service, and an hour (flat rate) of labor seems reasonable to me to replace brake pads.
As far as acceleration everything is back to normal. I still smell the clutch though? Is it because it's new or it's something I need to be aware of?
What does it smell like? How do you know it's the clutch and not something else?
