Acura TSX Brakes
Quoting from above:
"4. The alloy wheels get filthy the same day after you wash the car. Too much black brake dust."
Acura must be getting serious about competing with the A4 and 3-series :-). The German cars are notorious for black brake dust accumulating especially on the front wheels. This isn't from "cheap" pads, but rather high-perf pads that are intended for stopping quickly from Autobahn speeds.
Actually, considering how much wheel cleaner I go through on my A4, I'm surprised at 45K miles to still be on the first set of pads! I guess I will be used to it if I end up with a TSX.
I have been owning a tsx for a couple of months now. I am a total novice with regards to cars except to drive it. I have rust on the rotor(or whatever that is called)that is inside the wheels. Why does this happen. Is there something like a anti rust spray and how do i clean the rust that has already build up. appreciate ur advice.
When you apply your brakes, the rust is removed by the brake pads.
The TSX has a very open wheel design, so you are just noticing this for the first time.
If you drop by a dealer, walk around the lot and look at some of the new cars sitting there. They have "rusty" brakes too, until they go out for a test drive!
DO NOT under any circumstances apply any kind of coating on the surface of your brake rotors. You will reduce your car's braking ability.
If you are getting lousy MPG after 4,000 miles the likely culprits are 1) underinflated tires, 2) bad gas (i.e., less than 91 octane). If neither of those issues are involved, they you should see you dealer for diagnostic work. There is no way your mileage should be anywhere near that poor.
BTW, I am no longer servicing the Acura at the dealership. I have been complaining about this to them for months and they did nothing.
Someone referred me to a very famous mechanic here in Canada. He is Bill Gardiner who stars as well on the Motoring 2004 show on the Speed channel here in Canada.
After working on the brakes he told me that he needed to replace the rear brakes only. The front brakes still have 40% left. I found it weird that the rear brakes would go first on a front wheel sedan, Bill told me that Acura tries to save money this way and makes the rear pads thinner than in other cars. It is a real shame.
I think wind noise and creaks are the least of the problems with this car. For any of you who actually bought this car and are thinking of keeping it past its warranty period, you are in for some really nasty surprises. Get your wallet ready.
BTW, have 25 K on my car without a single problem. There are posters at the TSX enthusiast site who have upwards of 50K on their cars with no serious problems.
Consumer Reports also rated the TSX as one of the most reliable cars in the segment. Only the IS300 got a higher score.
I must say.. you might have one of the worst Acuras ever... I wouldn't say it is representative of normal, though...
regards,
kyfdx
15K - front pads and new rotors OEM
30K - rear pads and reface rotors OEM
44K - front pads and reface rotors aftermarket
60K - rear pads and new rotors aftermarket
Now almost 90K - no brake work done or needed.
My 91 Accord stick
112K replace front pads OEM
That's it. Same driving style - same conditions.
But, my '99 Accord.. 39K in two years, and still had 50% when I traded it..
Not saying you could find anything wrong with your '98... but, that kind of wear is just not normal.. especially, since you've demonstrated that you are not tough on brakes...
Didn't you think it was unusual?
regards,
kyfdx
Now, if his brake pads were getting warped frequently, that would be another isssue...
Now..if it were a 911.....
What I was trying to show was that my expectation for my 98 was wildly overboard based on my 91 and that the person who was crying end of the world based on brake wear is off the mark.
Now our 00 Odyssey went 42K on the fronts and that's mostly city driving.
On the 98? I havn't a clue. Whatever the local mechanic my SIL recommended put on the fronts and whatever NTB put on the rears. Although I will say the breke dust is horrid with the aftermarkets. The OEM pads never dusted like this.
But, I think caliper problems cause a lot more premature brake wear than they are given credit for...
Each model car is different... But, when the rear brakes go early on a front driver, and you've usually had long life from your brake pads... I still say something is wrong.. (If your teenager just got his license, that may be it..lol).
I agree with your premise, though... If someone tells you his brakes wear out early, don't assume the brakes are faulty..
regards,
kyfdx
I suspect he does drive it hard. Nothing wrong with that. The TSX kind of demands it from it's owners :-). Given "normal" driving style, though, the numbers he posted seem pretty low.
Of all car components, I'd guess brake pads would rank low on the list of things with QC issues.
Johnny
The TSX is driven by my wife most of the time. While she is a spirited driver, that is no excuse for needing brake jobs after such short mileage. And I am not bench marking the TSX against a Luxury car or an expensive car. Her previous car was a Korean Daewoo Nubira which lasted for her entire lease period with ZERO problems. Being a daily work car(real estate agent) you would expect more wear and tear. But if a Korean car can outlast an Acura, then Acura is really cutting back on quality.
I have 25,000 miles on my TSX and not a peep of problems with the brakes, and I check the wear fairly regularly. This is my third Honda product, and none of them had unusal brake wear. In fact, according to Consumer Reports, the reliablity of the TSX brakes is "much better than average."
You experience not withstanding, the brakes on the TSX are very reliable as is the rest of the car. there is nothing wrong with the OEM pads and they are not especially thin or especially cheap.
I'm not making light of your frustration with the vehicle. But, if the brake pads were somehow extra thin (as you are suggesting) why aren't other TSX drivers having trouble with premature wear?
Acura Quality! just read the posts above mate. It is hilarious to even mention the word quality anymore with Acura in the same sentence. Bad transmissions and clutches on brand new cars! Give me a break.
Craig
Not that it is even relevant to the discussion, but I have my oil changed every 3,000 miles. The filter has been changed by the Acura dealer each time.
Your mechanic may be "the most famous in all of Canada" but the notion that Honda is buying especially thin brake pads to save a few dollars is still without merit. If that is the case, why aren't other drivers having trouble with premature wear? I have 25,000 miles on my TSX and I personally check the pads for wear every 5,000 or so mile. They are pretty far from needing to be replaced, and I live in heavy stop and go traffic.
What "bad transmissions and clutches" are you discussing? So, you saw one or two posts on a chat board, and that tells you there is a problem in the entire car line? Consumer Reports has survey data from thousands of drivers, and rates the transmission reliablity on the TSX "much better than average." JD Power basically reaches a similar conclusion.
Through the enthusiast TSX site, I probably know about 30 6MT TSX drivers. No one has reported a single problem with their transmission. No clutch problems. No gearing problems. No problems at all.
You're being pretty unfair to Acura here. You are making sweeping conclusions about the car based on your own brake pads needing to be replaced and a few posts you've seen here. That isn't a very solid foundation for conclusion.
I'm sorry you are having trouble with your car, and hope everything gets resolved. But, the notion that brake wear on your car indicates a poor quality vehcile that is going to cause trouble for all owners is a pretty extreme stretch.
Last year I bought Honda Accord 2.4 6MT, which is essentially european version of Acura TSX.
1 (one) day before annually service brakes failed launching me through intersection (empty, thank God).
In service they told me that air "entered" brake lines (brake fluid did not drop in reservoir) and they solved it. Brakes worked OK.
A month later brakes again started to fail. In another dealer first they did not believe me (No, it could not happened) but mechanic on test ride almost hit building. Now they changed master brake cylinder, ABS assembly and seals in lines and car is suppose to be fine. BUT, they do not to guaranty me that I have safe car.
Did any have similar problem? It is supposed to be first problem of that kind in this model.
I just bought a Tsx, and noticed that when I go over 40 mph and apply the brakes my steering wheel vibrates. The faster the car is going the move you feel it. any ideas what is causing this to happen.
The only thought I have is....could there be a possibility that you had your parking/emergency brake on while you were driving? Or just dragging a bit? The reason is that the parking brake only engages the rear brakes.
Only other thought is that your mechanic pulled one on you perhaps?
Anybody else have thoughts?
Questions: (1)has anyone noticed the above shortcomings of OEM brakes? (2)has anyone replaced the OEM pads (with what kind?)and experienced substantial improvement? (3) what will pad replacement do to the original manufacturer's warranty?
The only way any aftermarket mod can void or raise issues with your factory warranty is if the dealer can prove said mod led directly to whatever problem you are experiencing. This is unlikely with brake pads.
BTW, Hawk pads are said to be very good, too. Many TSX enthusiasts love them.
It's open for debate whether brake pads are the best mod for the TSX. The Hondata ECU reflash and A-Spec suspension are pretty good,too. Or CAI. Or better rubber. Or headers. Or RSB, etc, etc.
You're right, though, the brake pad swap would be an inexpensive, yet substantial, upgrade. :shades:
Oh, and none of the mods I mentioned are for appearances sake. They either address power or handling.
And it's brakes people, not breaks! :shades:
When I took my TSX to the track (a demanding 2.25 mile road course that's notoriously hard on brakes) back in 2004, the OE brakes lasted all day long with little sign of fade. In order for your TSX to have outstanding braking capability like this, it requires the use of aggressive compound pads - and a side effect of these compounds is some noise/squealing.
The noise your brakes make when coming to a stop or slowly rolling through a drive-through is completely normal and in no way indicates a problem with your brakes. You can temporarily quiet your pads by applying some anti-squeal compound or a special adhesive backing to the back of your brake pads, but this material doesn't last forever and the squealing will return.
