Acura TSX Basic Maintenance Questions
Has anyone experienced significant oil consumption? I have owned the car for 2 months and have gone through 1 1/2 quarts w/in 2,400 miles? Of course, Acura Customer Service claims "it's completely normal for the engine to go through 1 quart per 1,000 miles." This is a ridiculous statement to make, and one made solely to cover themselves. If people have not experienced a problem, I would really appreciate it if you could respond with a simple "No", so I can keep track for statistical purposes (no names will be used, obviously). If you respond with a "Yes", I would appreciate any insight as to how Acura is handling this for you. Thank you, everyone, I really appreciate it!
Anyway, what do you think of not having your car looked at until 10,000 miles. The salesman told me it is very important to keep this initial service date because if anything appears out of wack they can address it immediately.
Hope this helps,
kyfdx
So I check the manual, and it says to run the engine 'til warm, shut it off and check the level. If it reads low, add oil until it reaches the upper mark. But if you do that you'll have more than 4.4 qts in the engine.
I guess my point is, why the heck don't they just tell you to put 5 qts in to begin with? It takes what it takes.
What have you guys been doing? I've read other forums where drivers complain about the engine burning oil. I think what's really happening is what I described above.
Johnny
and i drive my tsx like a champ right!!! but can any one tell me how i bought the car in july 04 checked the oil a couple of times then my oil light came on the other day got to work and check the oil there was like just about nothing in there... i have no oil leaks at all.. i have zero spots on the ground nothing where did it go... one last thing theres a switch in the glove compartment... on the left top side what is that for ... anyone... thanks
My situation my be different than yours (my experience with this only happened once and wasn't a recurring problem), but I thought I would throw this story out there just the same.
My question is, how hard are you driving your car? If you driving like a "champ" and are constantly pushing it to redline and pushing it to its limits because then I would expect some oil consumption. However, if you are driving it "normally" I wouldn't expect any oil burning. I'd be upset if I bought a new car and it used oil regularly. The only car I owned that regularly burned oil was an MG--and that was an expectation. I currently have a '97 CL V6 with close to 100k miles and it doesn't use any oil.
So, unless you can find a specific problem related to yours losing 1 quart every 3000 miles, then you just have to live with it.. As long as you are checking your oil at least monthly, you should have nothing to worry about.
Interesting. Of all the cars I've owned over the years, I can't recall one that ever had a consistent oil-usage problem. This is the first new car I've owned, and the only one that does use any oil.
It just seems to run counter to common sense. You'd expect that a new engine would be less prone to this. Especially if properly broken in.
However, you're right, manufacturers do adhere to the one quart per 1000 miles tenet.
Just thinking out loud. The TSX runs great otherwise.
Johnny
Checking my oil at 1500 miles while filling up the gas tank, I was a bit alarmed to see that the level was just at the bottom "pit" of the oil stick. Checking it later after the engine cooled down for more than an hour, the oil level was just under the top "pit" where I expected it.
I'd always believed that you never check the oil when hot because so much of the oil hasn't drained to the oil pan.
But the manual specifically states that the oil is checked when the engine is warm.
So the question is, have Acura's engineers designed the oil stick markings for a warm engine? Should I not read the stick at the gas station and just check it when the engine's cold?
1. Either my dealer is lying.
2. Or the engine is in bad shape that it is clogging up the filter rather quickly with fragments.
Conclusion: Crappy car or Crappy dealer or both.
Craig
1. Is this necessary after the dealer did the certified checkup less than 3000 miles ago?
2. The dealer quoted me $165 for the checkup including the oil change, rotating tires, etc. Is this price normal?
Thanks for the help.
I did see a Honda service bulletin that stated that Honda includes breakin conditioner additives in the orginal oil from the factory and early first oil changes are not recommended. I thought I would pass that on to you.
Comments?
Also...wouldn't it be best to change the oil at say every 5k and not stick to the 10k recommendation?
** Does anyone know what the heck is being added to our oil ?
** Anybody disagree with the concept of waiting for >10,000 miles?
** With this understanding, I am going to wait for 10,000 miles to change my oil AND filter.
Below is the reply from Acura (Comes directly from an Acura Dealership Service Department...which has a vested interest in getting us in early and often) -
Acura says that you don’t need service before 10000 miles or one year if your driving conditions are “normal” and not “severe” according to the description in the owner’s manual. Southern California driving conditions tend to be a bit severe, so many of our customer’s elect to replace the oil filter with each oil change and to perform an oil and filter change between each 10000 mile service interval at 5000 miles. If your driving conditions are not severe, I might recommend that you not change the oil for the first time before 10000 miles because the factory sometimes adds a break-in additive to the first oil fill. It is important to check your oil level on a periodic basis because some oil consumption in a 10000 mile period would be normal.
Then I get a card from Acura (not the dealer?) advising me to come in at 5,000 miles for the initial oil change. This was a reminder card, not a notice that their policy was changed.
I have found no reference in the owner's manual stating when the first oil change should be.
Conventional wisdom was always that changing sooner than later is beneficial to flush out any metal particles from the breaking-in process. Creation of those particles would be highest at the git-go and taper off as engine hours increased.
Who should we believe?
I also had the same question and I reside myself to wait until it is closer to 10,000 miles. I totally agree with past wisdom of changing initially at 2,500 miles, but I have to believe that the engineers have considered all factors.
The owner's manual does specifically state NOT to change the oil until 10,000...in the break-in section. Please look at your booklet to confirm.
Now...one thing that I will be doing is to change my oil AND filter every 8,000 miles subsequently. Why not...cheap enough. See my previous post #106 in the Acura TL 'Care and Maintenace' forum.
How are you?
I'm WiLL and I am new to this so please excuse me I am indeed placing this inquiry in the wrong section of this forum.
Perhaps you can direct me to the right section if I am indeed in the wrong place?
I have an 2004 TSX. I am a NYC resident but I bought it off the dealer in Maple Shade, NJ just because it was a little less expensive. I bought it at 1,800 miles floor model. It is now nearing 9,500 miles and the maintenance light is beginning to flash (not steady). I called a few dealers up for the maintenance fees and what it entails. They all ran quotes from $130 - $150. Is there any possibility I can find a place cheaper then that? $150 for a maintenance of oli change, filter change, tire rotation is kind of expensive to me.
Thank you,
WiLL
You can probably save money if you just change oil and rotate tires. This is what I did. For a fact on 10k Miles there is nothing needs to be done except these 2 things. read user manual for maintanance and see what you have to do,.
My prior car was a Mazda Protege with 135K mi. I got the same milage towards the end as I did in the beginning changing oil every 7500 mi.
Johnny
As for the 5K/10K debate beyond the first change, read the manual! I bet Acura recommends a 5K interval for "severe" driving conditions, which seem to fit the conditions that the vast majority of cars are subjected to. And you may encounter dealers that think the "severe" interval isn't severe enough, but they should really be ignored unless you want to make the general manager's boat payment.
I can't imagine that any break-in oil hasn't done it's job by the time you've driven 5K miles... though, I'm not a Honda engineer...
regards,
kyfdx
I would allow the 'break-in' additive to perform its duties by allow it to remain close to the mileage recommendation of 10k. However...if you have driven the car more harshly during that time...change it at 7.5k. After the initial oil change...change it at 5k but no later than 7k.
