Toyota Camry Interior
As an aside, if you ever have to disconnect or replace the battery (or the "Power No. 1" fuse in the lower left dashboard), follow EXACTLY the procedure for "initializing" the sunroof in your owner's manual once the battery or fuse is reinstalled.
Ask me how I know this!
Try activating the switch manually when it stops, and see if this does the trick.
A lot of people want their cars to look like a Lexus or BMW...those cars only come with black, grey, or tan interiors. Also, much easier to mass produce only 2 or 3 interior colors.
Most select lighter interior color, like tan, with greens and reds, and darker colors with black interior. Some colors come with either back or tan/cream.
It is merely a cost measure, not preferences of buyers. It is an option their research showed wouldn't make someone not buy, so it was removed to save money. Check out Mercedes for the four or five interior color options, but then you are paying $70,000 + for it. Sorry allcarscool, but mercedes offers many interior choices.
Ken
Brent
This trim is just clipped on. But you're going to have to pull/pry harder than you like, and there is a possibility of breaking one or more clips (or the trim itself), so you may want to get someone knowledgeable in this area to help you.
I have older Camrys ('04 and '05) and these have the side curtain airbag inflators in the C-pillars (behind the rear doors); there is just a tether in the front pillars.
If this doesn't work (and it sounds like it may not), you're going to have to see a professional (doesn't have to be the dealer), just someone you trust or has a good reputation according to friends, relatives, or co-workers.
Thanks for any suggestion and recommadation
Thank You for your help
I'm going to be purchasing a Camry LE, but would like to buy wood trim parts for the LE. I basically want the exact wood trim on the XLE. Know any good accessory stores for good prices. :P
I can buy a replecement for $20 or so online. Has there been any recall on these ? It would seem dangerous to be unable to open the door from inside in an accident.
How difficult is it to remove the old plastic interior latch unit ? Do you just pry the unit out to replace, or have you got to disassemble surrounding upholstery panels ?
I haven't worked on your particular car, so in some cases you'll have to pop the door panel off to detach the handle from the activating lever. You'll have to get in there and poke around. Also when you see the new part that should tip you off.
Plastic breaks on 7 year old cars. That's normal wear and tear on a part that takes a lot of abuse.
