Toyota Avalon Audio Questions
in Toyota
I have a 2000 Avalon XL and have a tremendous amount of static on AM and FM when the rear defogger is on. Has anyone else had this condition and what did you do about it?
Avalon's radio atenna is embedded in the rear window with rear window defrost. Our 97 XL only shows static in AM with rear defrost on. No Static in FM. I think that's a flaw in Toyota's design.
bjk
At present, I convert the mp3file to a CD audio file and put it on a CD-R and close out the session. A series of one hour lectures sure uses up CD's quickly! I could put a ton of mp3 files on one CD if I could find a way to play the files directly in the car.
IMO-You have some serious HOME equipment, so if you are shooting for the stars in your car, you'll want to consider Morel/Focal/CDT etc. FYI:I am using CDT with an ARC amp. CDT braxials are a great choice for this car. -nomad56-
The service manager at Lexus had 1 of his guys pull the headrest out of an 05 RX330 and it plugged right into my 05 Avvy, the color even matched up perfectly.
I called my audio store had them order me one. Should be here in a couple days and then the kid will again have a DVD player to keep her amused. 3 yr olds get bored pretty quick
- P.
Likes: HP, HP, HP, as well as the ride and handling so far
Dislikes: No radio display and rear window view washed out by sunlight reflecting off area between rear seats and rear window. Large C-pillars no help either. I must admit, the rear view would keep me from buying this vehicle. The HVAC and radio controls also wash out in daylight. My 4Runner has the same issue. Sure wish Toyota would go back to good ole circular knobs.
canddmeyer - Try the little black button above the radio, in the center of the console. One push for top half of display. Second push for bottom half.
Groza
I also see the trip computer shows the Avalon averaging 16mpg to date. That's 6 mpg below city EPA. I'm surprised it's that low, but then again the car is new.
Thanks again.
satellite radio add-on's to a local auto stereo shop and no, they don't know either until they take everything apart - they just want to go the wireless FM route, which I do not want.
I also have the JBL system in my Limited. I downloaded music from the internet using my computer. Burnt 5 cds and loaded them into the JBL system. No problem at all....sounds great.
delan
MikeS.
MikeS
OK, sorry I'm haven't forgotten just haven't gotten this far yet.
MikeS.
http://photobucket.com/albums/y95/mtpys/
Password is; Avy05
MikeS.
This is my first post here. Looks like a great place to get suggestions and opinions. I am in the final stages of purchasing a 2005 Avalon Limited and I had a question and wanted to see what other owners were experiencing. I am going to get both satellite radio (with the antenna inside the car next to the rear window) and I also have the navigation system.
I know the Nav manual says not to tint the windows as it could affect the GPS system on the Nav, but I'm assuming that's just a standard warning. I had an Acura TL with Nav and had the windows tinted (35%) with no problems at all.
I was happy to read zekeman's input (thanks very much Zeke!) Can others confirm that they have gotten a 35% window tinting (I'm having it done at the same place that did the Acura so I know it's quality) on their Avalon w/Nav and have had no adverse affects on radio reception, satellite radio reception, or Nav reception?
Any input from anyone with tinting and Nav would be GREATLY appreciated. Thanks very much.
zekeman1
I think this is a common problem.
Is it common?
Easy fixes? [eg: Kragen woofer, about $20]
eugene
abfisch
PS. This is a factory-installed unit.
Rob
These systems typically specify they are for factory systems with a CD changer option. My system has an in-dash 6 CD system, so I am not sure it qualifies (are they referring to external only?).
Also, because by my system is made to add an XM satellite and it obviously has some sort of interface for another audio source, I was wondering if I could somehow use that option.
Has anyone come up with a solution? I've tried FM transmitters, but the reception inside the Avalon is terrible, and there is no cassette option in this model since I have the Nav system. Any help would be greatly appreciated.
I have a 2000 Toyota Avalon XLS with a 6 cd changer . The cd player will not eject suddenly , and the cd image flashes in the radio window .
How do I reset this thing , or eject the cds ?
Thank you in advance for any help .
Nice car. Radar detector should be direct linked to the battery. Chicken appears overdone. Just kidding. Enjoy that car. Very nice color.
abfisch
drb
I am planning to a buy a portable DVD player 7" for avalon 05. Wondering if the car is negatively grounded, because the DVD player requires that.
Can somebody help me out?
and also any experiences in using DVD player attached to back of car seat by caselogic or targus portable DVD cases? any suggestions? is 7" too small? I used to have pilot 04 with DVD player. It was OK. Any thick shades that would block sunlight? Sometimes it glares.
And also any suggestions on how to increase the height of booster seat? my 2 yr old kid can't see anything through the window. She is too low on the seat.
Sorry too many questions, any help is much appreciated.
drb
...Does anyone know how I could add an ipod to this system?...
Here's something that was posted 'round here awhile back:
http://www.coastaletech.com/viewtech_2005.htm
