Visitor Agreement.
Steve
Yes, a 6 year old car may have a bad starter. But do the easy things first. You might be happy you did...
Let me know how you are doing in your search for a correction.
Problem: My car makes ONE click sound everytime i try to turn ignition. I try it several times before i get lucky and the car starts. I figure that since it did that, I could do it for a while until i had time to check it out and see what's wrong with it. but the other day, i started the car again, but this time it won't start. the battery is good, all the lights are on, alternator is good. only thing i could think of is starter or bad connection. BUT what's weird about this problem is that NOW it has this other noise where it sounds like something is rotating kind of like a wheel when i try to turn the ignition. I have no idea what that is and it only happened yesterday and now today it doesn't start. Can some1 help me???? Thanks.
Roland
Had the arbitration hearing yesterday at my Toyota dealership. It was quite the experience. Actually, It was less adversarial that I expected. Anyone considering doing this and selecting an ORAL hearing should be prepared to deliver their case via a thorough oral presentation. The company rep then gives his side of the case. Personally, I was not impressed with Toyota's position or with their representative's delivery. The arbitrator only asked a few followup questions to clarify some details. For the most part, the only people who talk are the customer and the company rep. The arbitrator mostly listens and takes notes. The arbitrator was very hard to read and showed only glimpses of body language. I got a few nods that seemed positive but not having gotten any results yet, I can't say if my observations were accurate or not.
I generally hate oral presentations, but I'm pretty happy with myself on this one. I did my homework beforehand, took a lot of notes, and am confident in my recollection of details.
If I can give anyone advice on doing this: Do NOT select an oral hearing if you are not confident in your speaking abilities. Select a teleconference or documents only hearing instead. I'd be more than share more details to anyone who has an interest. I wish there had been more information out there on this for me.
I'll UPDATE you again when I get a result, supposedly within 10 days.
Keep in touch.
1.) Order repairs or another repair attempt
2.) Nothing
3.) Or order the re-purchase of the car
We were looking for a re-purchase.
A common problem on Toyota's if any air can infiltrate the air intake piping they will not start as the car will not be able to calculate the right air/fuel ratio. More on that note a dirty Mass Air Flow sensor can cause the same problem. A little isopropyl alcohol and a q-tip can clean it up fairly easily.
Net
Net
I bought a 1997 Avalon in 1999 and it has worked perfectly until now. Starting about March 15th, 2007 it has been starting the engine itself at odd times at my house. And the theft deterrent alarm activates for no reason. The horn has also beeped twice for no reason. I just checked the OBDII and there are no codes stored in the system. I need to know how to prevent the car from starting itself.
Forums>Sedans>Toyota Avalon>Toyota Avalon Solving Starting Difficulties
Problem: My car makes ONE click sound every time i try to turn ignition. I try it several times before i get lucky and the car starts. It might sound strange but I discovered that the car would start immediately when I open the door and start the car. Normally the starting problem used to happen the first thing in the morning and never during the rest of the day. but lately it happens any time of the day. I figure that since it does eventually start, I could do it for a while until i had time to check it out and see what's wrong with it.
The other day, i tried to start the car again, but this time it won't start. the battery is good (I got it checked), all the lights are on. I can't even get it to start with my trick of opening the door and cranking it.
Can anyone help me identify what the problem could be and where I should take it to for getting it fixed i.e., a normal repair shop or an auto electric repair shop? I really appreciate your input.
Turned the key, and it was't so much clicking (Some might Think that) sounded more to me like electrical arcing. Wiggling the key switch and turning the key ...it started right up. I had a similar issue about a year prior to that, which required replacing the key switch. So Assuming it was the switch again, I took it back to where it was installed (in warranty) and was informed that my connections on the starter and battery were bad, They charged me 50 bucks to clean them....and I got the the big lecture about clean terminals, Ohms law etc. I met this with a certain amount of skepticism, especially; as I had already cleaned said terminals. Yesterday my son took the car a couple of blocks, and while driving, the starter began to engage. He turned around came right home, turned the key off and the starter continued to engage over and over. By the time I got out to the car, (it was still turning the starter) a large plume of black smoke began to rise from beneath the hood. I got in the car turned key switch to on, the engine actually started, then I turned it off immedaitely (to no avail) it continued to turn over, I scrambled to find a #10 wrench to connect the battery, and by the time I had the terminal off, the starter was actually on fire...I had to put it out with a fie extinguisher. The wiring is damaged, some hoses melted.....it's a mess. I suggest anyone with this year/model carry a fire extinguisher and keep that battery wrench handy. Ghosts? Naw...bad solenoid design, or a WIRING ISSUE. Not sure just what it is at this point. I'll have to sift thru the charred remains and thenget an expert opinion, ahem and not the guy with the dirty terminal theory, obviously; I had no problem pulling enough current to melt the starter.
blown fusible link or links?
totally dead battery (dangerous to jump start by the way).
Good luck with that
According to the owner's manual (do you have one) if the key battery is dead touch the Toyota logo on the key to the start button. This is supposed to start the car. All this is on page 395 in the 2008 manual under section 5/2. Also, do you have 2 keys and are both inoperable.
Kathryn
I was told to do this by my Toyota Service Department.
I have had a little issue starting the vehicle lately and first time I am always unable to start and I see the front defrogger light flash non-stop and I try to start the vehicle again and it starts. Not sure it's related to the battery that makes the defrogger light flash? Anyone has the same experience? Please advise. Thanks.
I'm writing this on behalf of my grandparents and their 1996 Avalon that has 30k miles on it. It has recently been serviced for fluids and the battery has been tested. The problem as described to me is that sometimes, not every time, Grandpa tries to start the car there is dead silence. No clicks or turning of the starter. Then after some fiddling it starts up. He tells me that when he has this problem he has to push in on the shifter (not sure if there is a button or if he is just pushing it up further in gear or something similar), and when he gets the right spot, it will crank and usually turn over. He thinks alternator/battery are both fine. Anyone have any clue what else we can look into before bringing it in to the service shop? One local mechanic already looked at it and was puzzled by the description and was unable to duplicate the problem when he was looking at it.
Thanks very much!
