Toyota Avalon - Remotes, Remote Start, Door Locks and Security System Questions
                    The car we bought did not come with the remote button.  There were many of them for sale at ebay but I found one at a junk yard.  The one's on ebay claim it is very simple to program them to your car.  Can anyone help with the How to part?  Obviously the one we got from the junk yard didn't work on our car.
Did you only get the ONE key FOB?? Are ALL 3 (maybe 2) buttons acting this way???
OPEN the non working key fob and clean the rubber diaphram (the backside of the rubber button), as well as the "contacts" on the transmitter's circuit board. Inspect for wear. You may have to get a new one... -nomad-
In my 96XL this is an alarm indicator light. I can't tell you much more though, sorry.
MikeS.
Ed
I saw the dealer change the programming to make the door not lock on moving from P to D when I bought the car and I think he opened the drivers door during the procedure.
Does anyone have the procedure that will work for my 2000 XLS ?
I just purchased a used 2000 Avalon. My first Toyota. About a week ago, I unlocked the car and popped the trunk with the remote and when I was loading some stuff in the trunk I heard a swish noise. It had sounded like the doors locked and when I went to check, the doors actually locked on me. I had looked to see if I accidently hit the remote lock button but my keys and remote was laying on top of the car roof, no where near me. I may have had this happen once before, but shook it off as if I did something wrong. Anyone else run into their doors locking automatically?
And since being a new Toyota Avalon owner, I saw a couple of message about the 3.0 engine sludging. What exactly is this? Is the engine oil sludging? Does the Avalon need constant engine oil flush that you get at any Quick service oil change shop? Just wondering.
Thanks for any input.
The engine sludging thing I don't understand too well myself (I think it has something to do with a bad valve cover design?)...only that it can happen (and did to me) but the dealership will (should) clean it up for free within 8 years of purchase.
There is a lot of information on the net and on Edmunds about this problem. Several other makes are now also having trouble with sludge. (Chrysler, VW,).
About the door lock. If you unlock your car but do not open a door right away, they will lock back again. Could this be what is happening to you?
IIRC the sludge is caused by several factors combined.
poor maintenance/no oil changes for many months
poor design of the PCV
short trips where the engine doesnt warm up etc..
the PCV was addressed in 01 sienna and upwards (they have the same engine). The part is $10 and chnaging it was easy on the van. the engine does poorly when not maintained well.
I'm planning on doing a full tune up including PVC valve and probably the timing belt and such when I dig into it for the valve noise. I keep track of my mileage now, I'll see if anything changes when I get done...assuming I can put it all back together.
And as for the door lock, yes, it did happen when I unlocked the car with the remote and popped the trunk. I did not open any doors, but I was packing the trunk. This is the first car that I have owned that auto locks the door when just sitting there. Just caught me off guard. Gave me a concern. I don't want to walk away from the car for a moment and have it lock my kids in it.
Thanks again, and thanks to everyone else who wrote in. Appreciate it very much.
Turn everything off. Close doors. Sit in driver's seat. Selector in PARK.
UNlock all doors with the switch. Turn ignition ON, do not start.
Within 10 seconds push door lock to LOCK and HOLD for 5 seconds.
The "open door warning light" will flash.
1 flash is mode 1.
You want mode 2. That's 2 flashes. No auto lock/unlock.
There are 4 modes, in sequence. If you miss, it repeats.
If you miss the procedure, start over. No problem.
Hope this helps......
Might want to order an owner's manual if yours is missing.....
I have a 2000 Avalon XLS and have never had a problem with the car until now. After placing my key in the ignition, I attempt to turn the key to the "ON" position to crank the car, but the key will not turn past the "ACC" setting. Is there some sort of security lock that has caused this. P.S. - The transmission is in the "Park" position.
In an earlier post you mentioned, "Did you put those anti corrosion donuts on (green and red) and put lithium grease on the terminals??? I have 74K on my 02, make sure before winter that the terminals have grease or some kind of battery terminal sealer on it. The other thing I do in the spring, is take off the 6 cell covers, and with a small squirt bottle, fill up slowly and carefully with distilled H20 each cell."
If I want to clean and perform this service on my 03, do I have any concerns with the alarm when I disconnect/connect terminals (negative off first??) - anything else??
Dave
To my knowledge. No. I have an aftermarket alarm with a remote starter (Avital Brand). I believe the clock or radio I had to reset, cannot remember, but all the other electrical connections, and I have alot of them direct to the battery including, alarm, car starter, two sets of auxillary lights, etc. had no effect.
This is pretty much what they do, and it is not brain surgery. I have an XL, not an XLS, but I gotta think you can disconnect the terminals without major complications. What happens when you have to change your battery. Same.
This is easy stuff, and stuff you can feel good about doing yourself and save money at the same time. Use safety glass, gloves, have a rag to wipe up spills quickly, etc. Should be a piece of cake.
abfisch
I'd really like to have a unit that works off a timer/clock. Set it for 0730 and be done.
MikeS.
When I pressed my remote entry fob both cars chirped and the lights on both cars flickered. After I started my car and drove off the alarm on the other came on.
So my question to you boardies, what are the chances that both cars are programmed with the same key code and would my key actually start the engine of the other car? Was that coincidence or is this a serious security risk and should I report this to Toyota?
too bad you didn't copy down the VIN of the vehicle next to you. it might have been useful to communicate to Toyota.
in the end, i've got to believe the code systems are randomized, and this is a small probability event, but why not contact toyota and ask for an explaination?
