Audi TT Instrument Cluster
I have a 2001 TT 225 Quatro w/ about 57K on it. Yes, I drove the darn thing into the ground the 1st year.
Only problem I ever had was broken gates between 1st and 3rd about 2 years ago. Replaced and ok now, no probs. EXCEPT
Now have my Tach starting registering at 4K, and it has reset my date to 1998! Spoke w/ dealer, says only cure is to replace entire instrument cluster. Is that right? Any other solution?
That sounds correct. I have an 01 225 TT roadster and in the first year my fuel gauge went out. The dealer had to replace the entire instrument cluster. One of my inlaws has the same car and she had her cluster replaced for a faulty gauge. My old J30 was the same way. It seems to be all or nothing with the gauges.
drumm,
no need to let off the gas, just shift with the appropriate paddle. I believe there's two paddles so one is for upshifts (right paddle I think) and the other for downshifts. The one in the TT has two clutches so your next gear is already engaged before you even shift.
Leon
01PATT
mikeypd,
According to my service tech, the 225 engine burns oil by design. He said the heads are "porous". It's just a "feature" of the engine that people have to live with. I don't see the engines going 100k without some sort of failure due to the leaking.
http://www.bba-reman.com/content.aspx?content=audi_tt_dashboard_failing
Paul
My wife and I are not millionaires, but we have owned a 2001 Audi TT 180hp Coupe since new and now it has more than 56000 miles. The car has been perfect, and it still drives like when it was new. Actually it is better than it was new, because we didn't like the OME tires (Michelin Pilot Sports), which lasted, with no complains, 45000 miles. We put a set of Goodyear Eagle F1 GS D3 on it last summer, and now it's a dream to drive. I actually like driving it better than than our 2004 Porsche Targa, although my wife disagrees.
If you're brave enough to buy ANY Audi, dump it before the warranty expires! (Many of my friends are physicians, and one of the most common conversations in hospital physician lounges is to grouse about how unreliable their Audi's are!!)
Electrical: xenon headlight replaced (after bringing it in 5 times), battery replaced (2 failures), radio replaced (flashing backlight), instrument cluster (due to gas gauge failure).
Other: transmission issue (rabbit jump from 1st to 2nd gear, sqealing in reverse in AM), brakes grinding, fuel sensor problem - replaced, ignition coil burned out (just recently - in shop now)...
Trade in value offered to me recently 23K at Audi (20K at CarMax), my payoff balance is 29K. I am dumping this :lemon: car at the end of the 'Premier Purchase' term or at 50K (since I think they have to offer me the payoff balance as a trade-in value)... my next car will be Japanese.
I test drove a Nissan 350Z and that thing is SO much better... 287hp on the base model kicked this TTs [non-permissible content removed].
The older audi's , like audi 90, coupe, A4 relies on VDO clusters witch the quality as absolutely no comparasion to make.( This is a true audi with a VDO cluster meaning overall quality). Audi should make a recall and an upgrade cluster like the way the ignitor coil have been recall( because so many of theses coils was defective almost all!) . Personally, I have a 2001 audi coupe, I have changed the cluster 2 times...Ive got only 54000 miles on it, i don't whant to keep the car anymore because the cluster is not very reliable, even brand new, a way too much expensive to replace for this kind of quality and U never know when Its gonna break again for any reasons.
Audi TT Quatro 6 speed
I just thought I would share this info with you all. Audi UK have finally acknowledged that some of their instrument clusters/dashpods are faulty. They are now replacing those clusters for vehicle within the last 5 years. They are also offering refunds to clusters that have been repaired in the past.
Here is a copy of thier statement:
The Audi UK statement.
AUDI TT INSTRUMENT PANEL ISSUE
STATEMENT FOR BBCTV WATCHDOG TO AIR 24 JANUARY
"We recognise that a number of fuel and temperature gauges have not been working correctly on Audi TTs, mainly cars which have been built up to mid 2004. We have been replacing the majority of these free of charge under our three year warranty in the UK.
To ensure customer satisfaction Audi UK is now also moving to replace units, on a case by case basis, free of charge for cars of up to 4 and 5 years old.
Since mid of 2004 an improved instrument panel had also been introduced.
Affected customers should either contact their local Audi Centre or call our customer hotline on 0800 699888 and ask for our 'TT Helpdesk'.
Owners who have already paid for a replacement panel will be treated sympathetically on a case by case basis.
We apologise for any inconvenience caused to customers and assure them that we are working hard to resolve this issue."
I guess now that it has been acknowledged by Audi that it is a problem it strengthens owners claims to have the problem recitified for free.
If you are after more info goto the following forum site.
link title
Good luck to anyone that needs to get their cluster repaired.
Meter was flashing when I bought it. 2 months later. Meter Kaput-ed on me.
First time this happened, was when I just got home. Car shut down and could not restart. Engine wont even click.
Towed to Audi Service Center, they checked and replaced the battery. Said battery had failed.
Second time, 2 weeks later. Driving half way back from work, the car stalled and could not get it started again. It starts then after 10-15 seconds, dies out again. Got it towed back to the workshop. Guys checked first said was fuel pump. Later they changed it and said it was Meter cluster.
Went to send the local dealers the recall program but Audi regional office said they have not heard of such a recall or refit program.
Sent the Cluster over to BBA-Reman, they said they could not fix it. Wasnt the standard Power chip that failed, the Processor had failed.
Forced to buy a new unit. In Malaysia, these units are not cheap. Cost me RM$5965 + RM300 to fit and reprogram the unit. (~US$1600). Found out also that the Part number has changed. New unit superseeds the old unit. If the crap meter has no problem as what the dealers claim, why is there a super seeded unit !!??
Man, this car is nothing but trouble. Oh, and by the way, the previous owner changed the fuel pump and battery in February this year too.
Oh, I am at 57,*** miles. Bought used with 16,*** in May 2004. Lovin' it so far!!
Can anyone help me out with any advice?
If you wish to jump on the class action suit game contact this firm. http://www.classcounsel.com/news/audi.html
Also boys and girls...change that timing belt at 60,000 miles. There are a number of them breaking before the recommended change point of 105,000.
These are great cars and not at all bad to work on. The factory manual is great and any special tooling is easy to fabricate. The fuel mileage is superb for the 180hp model and they are just a fine car to drive.
And only buy Japanese if its a minivan, small SUV, or small truck. There has never been a Japanese classic sports car. Life is too short to be bored with what you drive for fun.
Typically Audi has refused to replace these units if the vehicle is out of warranty. However in the UK they recalled all TTs from 2000-2003.
If you go to the dealer and ask them to use the "good will" money allowed by Audi to fix these problems, well you will be disappointed as the dealers hold on to that money and ONLY use it for their best and frequent customers.
So if you run into dead ends and you think you might have to pay the $900-$1200 dollars to have it repaired, well dont do it quite yet.
I have 145,000 miles on my 2001 TT coupe and I got Audi USA to pay for the repair. If you want details as to what I did to get them to pay without lawyers, email me and I will share the details.
Ed. EMAIL- ed.gentile@gmail.com
My commute to work is 10 miles ...when I get to work I notice the odometer shows that I've driven 85 miles. Some days that 10 miles to work equates to 3 miles. Other days, 300+ miles.
What's going on?
And how do I get it fixed?
Any recommendations to non-Audi dealer shops in Northern California that can fix my problem.
:surprise:
Scott R. Callison
Please provide any info you can to help, thanks, car has 97K miles.
I would suggest that the California owners contact the firm in SF handling the class action filing. This may help. The Audi USA customer liason said that I should keep the receipts just in case a class action suit is filed. At this point, I do not think one has been done based on the web info as of Jan 08. Best of luck to all of you will cluster problems, Or should I say Cluster F*ck problems. In Texas
So before spending $1500, try a reboot!
Go to this website and download the settlement agreement. The extended warranty that Audi USA has offered isn't much, but it will cover the cluster when you have a problem. In Texas
We qualified undet guideline (a) for reimbursement but were sent a repair voucher instead of the cash settlement. When we reminded the administrator that the Audi had already been repaired a year ago - the Administrator said we did not qualify for reimbersement. (Hugh?)
We were told by Chuck Marshall of GREEN WELLING LLP that Audi was not honoring part of their settlement and to contact Audi directly. We did and were sorely disappointed when we were told to go back to the administrator who has closed the door (apparently).
What gives? This is the 4th Audi we've owned. The instrument cluster broke at 12k miles on the TT. We are a loyal customer who clearly qualified for reimbursement. Has anyone else recieved this treatment by Audi & the Settlement Administrator?
Did you have to call on an attorney to get them to move?
What's the downside for Audi of reneging on a settlement offer? And what leverage can I display to get their attention?
