Noticed recently that ride quality and handling have gotten worse - ride is rougher and there is more bounce and sway. Mentioned this at my dealership during last service visit and had them give me an idea of cost to address - ballpark number came back at $3k! Obviously I'd have them take a closer look to see what really needs to be done & probably have someone else check it out as well, but ... wow. Add in the additional work I need to have done between brakes & 100k intervals and that's a lot of money for a 10 year old vehicle.
Curious if anyone else has had anything like this addressed and if so what it set you back.
No chance I'm doing it myself, though. Don't have the skills or anything else necessary.
bmbernhard@fuse.net
You can email to dan27@optonline.net
Good luck with your fight.
NUMBER: 13-001-12
GROUP: Frames & Bumpers
DATE: March 16, 2012
THIS BULLETIN SUPERSEDES SERVICE BULLETIN 13-001-10, DATED OCTOBER 26, 2010, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** AND INCLUDE MODEL YEAR APPLICABILITY AND BUILD DATES.
NOTE :This only applies to vehicles in the Canadian Market and in salt belt states which include Connecticut, Delaware, Illinois, Indiana, Iowa, Maine, Maryland, Massachusetts, Michigan, Minnesota, Missouri, New Hampshire, New York, Ohio, Pennsylvania, Rhode Island, Vermont, West Virginia and Wisconsin.
SUBJECT:
Vehicle Vibration and/or Shake X26 (10 Years/150,000 Miles Warranty Extension)
OVERVIEW:
This bulletin involves inspecting the engine cradle for perforation and if necessary replace.
MODELS:
2004-2005 (CS) Pacifica
NOTE : **This applies to vehicles built from February 23, 2004 (MDHO223XX) and through March 31, 2004 (MDH 0331XX).**
SYMPTOM/CONDITION:
The customer may experience a vehicle vibration and/or shake.
DIAGNOSIS:
If the symptom condition is experienced proceed to the repair procedure.
PARTS REQUIRED:
REPAIR PROCEDURE:
1. Raise vehicle on hoist. Refer to the detailed procedures available in DealerCONNECT > TechCONNECT under: Service Info > Lubrication and Maintenance > Hoisting.
2. Inspect the engine cradle for perforation as shown in (Fig. 1). Was there any perforation found?
a. Yes >>> Proceed to Step # 3.
b. No >>> Continue further diagnosis this bulletin does not apply.
3. Remove and Replace Cradle, Front Suspension. Refer to the detailed removal/installation procedures available in DealerCONNECT > TechCONNECT under: Service Info > 13 - Frames and Bumpers > Frame > Engine Cradle Crossmember> Removal/Installation> Front Crossmember.
4. Return the vehicle to the customer.
POLICY:
Reimbursable within the provisions of the warranty.
Vehicles included in this Service Bulletin have a Warranty Extension for this repair. See Warranty Bulletins; U.S. D-10-34, Canada SAB-2010-29 for details associated with the extended warranty.
TIME ALLOWANCE:
FAILURE CODE:
Disclaimer :This bulletin is supplied as technical information only and is not an authorization for repair.<img src="
Chrysler Custoiner Assistance Center
P.O. Box 21-8007
Aubum Hills, MI 48321-8007
I received a reply and a phone call and the offer was for the 80% settlement on the amount charged by my local Chrysler dealer that replaced the frame rails and engine cradle.
Yes, they tried to tell mt that my vehicle that I ourchased in May, 2003, was outside the manufacturing period of the warranty extension, but since mine was one of the first 2004s, they agreed to pay.
The rest of the frame is perfect, just this one spot on the engine cradle
link title
I didnt want to drive it and dropped it off at the dealer this morning. I;m waiting for the phone call.
I also am waiting on a call from a Chrystler rep to discuss it.
I am so frustrated, I'm stuck with a vehicle that I can't drive becasue it was manufactured 3 months after the so-called affected production dates. You know there were parts that may have been at the bottom of the pile at the assy plant and some vehicles would be outside of the actual affected date range. - Sorry, rant over.....
I am being quoted $1400 for parts ($700 for the cradle itself) and $1300 for labor - OUCH....
DLSClark1@yahoo.com
we just found the same problem with our 2004 pacifica
thank you so much
If you call Chrysler and give them the VIN, they will tell you if yours is covered.
If not, then jump on board with the NHTSA and file a claim.
