Pontiac Bonneville Electrical Problems
245
  • skitch1skitch1 Member Posts: 1
    Did you ever get the issued straightened out on the 2002 Bonneville?
  • sriznersrizner Member Posts: 1
    I have a 2001 SSEi and from reading other posts in this forum I think I may have water drain issues and probably some ground issues. First issue was the wipers-they would turn on but not turn off. Second issue is water coming into the car-started in the rear passenger floor now it is also in the front driver side-cannot locate where the water is coming from, maybe the sunroof. Third issue is oil pressure gauge-it reads 0 pressure but there is plenty of oil and there are no additional noises coming from the engine. Interior lights work sometimes. My car has always been "sensitive" to water. Any thoughts on where I should start? Thanks!!
  • mdeciphermdecipher Member Posts: 9
    I had an older Bonv that leaked and had plugged drain holes in the sunroof, and a broken piece of trim around driver door that were responsible. A friendly GM bodyshop manager can roll off a list of possibilities since it appears they deal with these issues with this vehicle often. The wiring issues I've run into have been under the carpet secondary to rust and corrosion.
  • bonneboy44bonneboy44 Member Posts: 1
    I'm going through the exact same problem right now with my 2000 SSEi. Battery died, then no audio from the radio. Everything appears to work, but no sound output. My dealer told me the same thing...replace the radio.
    I checked the wiring diagram for the amp...Pin A8 is a "radio on signal". Does anyone know what the value of the signal should be? And how to bypass it?
  • gert3gert3 Member Posts: 2
    For the second time the fob no longer works, the interior lights do not come on when the doors are opened, and the computer plug-in does not have power. Last time I found a fuse under the rear seat blown. This time I can not find a blown fuse in either fuse box. What do I look for next and where?
    I have a 2002 bonneville se and had repeated water problems on both front doors. the mechanics said there are diverters inside the door that were coming out of place. The mechanics fixed several times and fortunately have not had a leak in a while.
  • electromechelectromech Member Posts: 1
    Not sure if anyone can help me but was wondering if anyone had any info on the wiring connections to the Chime Module that is fitted to these vehicles.
    I would like to reuse one of these Modules for a project on another vehicle but have come up short on the main 16 pin connector and exactly which terminals are connected to ground via a switched input ( eg. Door Switches ) and which are switched via 12V +
    Any info would be really appreciated especially a description of where the other connections head off to other than the main 12+ supply and the device ground connection.
    Electromech
  • bonnie95bonnie95 Member Posts: 2
    Hi
    I have a 1995 bonneville ssei. My signal lights want work, My husband has changed the fuse and every time the fuse is blown. I work nights so it's kinda hard to do hand signals in the dark and I don't think the other drivers pay attention to those any more. Can someone give me some feed back on what could be causing my fuses to blow.
    Bonnie95
  • josiah624josiah624 Member Posts: 6
    The LCD on my (Stock) stereo/cd player is very faint and the left side is EXTREMELY faint. Looks like a bulb may be out. Is this an easy fix or is it not worth the trouble/expense.
    It's annoying at worst.
  • ltkettch17ltkettch17 Member Posts: 2
    I'm having trouble with my brake lights (2002 Bonne SE). On my passenger side, the brake lights do not light up when I hit the brake pedal. However, they do light up when I lock/unlock my doors with the key-fob. I checked the fuse under the back seat, everything looks good.
    What is the problem???
  • ltigueltigue Member Posts: 1
    Just wondering if you found anything on getting this repaired. I have the same problem in my 02 Bonneville. I would appreciate any information.
  • gesepsgeseps Member Posts: 3
    It's possible that the brake light portion of the bulb is burned out. They are dual element bulbs, one for the general lights (lock/unlock doors) and the other element for braking. If your center light is working with the brakes, your wiring is probably okay. Replacing the bulb is fairly easy. You need to unscrew (3) nuts from inside the trunk which releases the whole lense casing. You can then remove the proper bulb and replace with a dual element bulb (about $5). Good luck.
    Did you ever solve the issue with your windows not working? My passenger front and driver (rear) windows are not working. I can hear the relays when I use the switches but the windows don't work. I don't believe it is the motors since they have worked intermittently. Any advice? (other than to sell!!)
    My passenger front window malfunction was repaired by mechanic who said he found a bad wire under front carpet. I imagine there must be a flowchart somewhere on how to troubleshoot it.
  • noakesnoakes Member Posts: 6
    2004 Bonneville has lately taken upon itself to lock the drivers door (only) after I have left the car.
    Have had two occurrences of this both times I partially pulled the key from the ignition and got out of the car. When I returned the drivers door was locked - other doors not.
    Any suggestions? Please do not suggest I remove the keys from the ignition, I want to solve the problem and leave the windows down just in case.
  • mmxbassmmxbass Member Posts: 2
    My '96 Bonneville has the problem where every so often the warning chime comes on indicating that the parking break is on even though is is clearly not on. Sometimes this will remain in this condition for hours at a time and the chime is extremely irritating. Is there a quick and easy way to disable the chime entirely, the chime serves no purpose other than to irritate the occupants of the car. I was considering forcibly ripping the chime module out of the car but I thought I would check to see if there is a simpler and cleaner way to stop the chime first. Oddly the chime seems to share a fuse with part of the ignition system so removal of the fuse is not an option.
  • statepigstatepig Member Posts: 1
    I have a 1995 Bonniville SSE with 80,000 miles. I have just spent 30 minutes reading all the blogs about electriac problems, but didn't find any like the problem I am having. All of my electrical components appear to be working properly, but something is draining my battery within 8 to 12 hours. My alternater does make a sqeeking noise when running, but momentarly if oil is sprayed inside the wheel. I have had the alternater checked by two mechanics, and they both say that the alternater is good. Attempting to eliminate electrical parts, I unhooked the alternater and starter from the battery, and the next morning the battery was dead. When turned off, there are no lights on, no motors running, nothing that might drain the battery. My battery is new, the terminals are clean, please help me. I will check all the grounds that others written about, hopfully that will help.
  • rfiferrfifer Member Posts: 2
    at times when i am driving my 97 bonneville, if i tap the brakes the speedometer needle will jump and at times the airbag lite comes on then the chime will sound..i have disconnected my abs front sensors to eliminate them...it still happens...i have checked the brake lite bulbs and they are all fine...i am wondering if the brake wight switch may be defective...this is an intermitent issue...it does not happen everytime i hit the brakes...got any ideas??????????
  • imidazol97imidazol97 Member Posts: 27,819
    Things to think about.
    Contacts inside the dash where different components have electrical contacts like circuit boards in a computer have corroded and are making intermittent contact with vibration from the brake pedal. Try hitting your shoe on things in the area of the brake pedal without using the pedal.
    The contacts in the ground buss at the corner of the A pillar and the floor. It's under the plastic door sill where you lift your foot in and out. Moisture in some climates can corrode the contact for the grounds which all press onto one large multicontact.
    Bad connections at battery cables where two positive cables overlay each other. The corrosion builds between the two contacts. Turn off AC with car running before removing these cables.
    Could be a weak battery.
    Could be a weak alternator or contacts at the alternator.
    my 97 bonneville's fuel guage always reads full, i have changed the sending unit in the tank...i was told this model had an anti slosh relay...if it does could this be my problem?
  • twil121489twil121489 Member Posts: 1
    i have a 95 pontiac bonneville and its giving problems starting...i have to try to start it like 10 times sometimes before it starts..and sumtimes can take a really long time to start.....i've been told many things that wud solve the problems like i got the water pump changed, crank system, and today the fuel pump...this car is still giving the same problem!! can sum1 please help me!!! im soooo fed up..email me at twil121489@yahoo.com ...thanx
    You need to test for the right combination... fuel, air, spark.
    You don't mention how many miles. Or whether the fuel filter has been changed. So fuel could be a problem. Th fuel pump might not be making enough pressure to squirt fuel through the injectors into a mist that easily fires. That requires good testing. The replacing of the fuel pump requires dropping the tank and is tricky and dangerous because of explosion/fire danger.
    The injectors might not be firing. You can hear them or feel the click when they open while cranking if you tought them. You can take a 194 bulb like the little bulbs used on side markers and taillights that have the two wire leads and put the leads into a connector for the fuel injector and see the bulb flash as the injector is fired.
    You can check for ignition spark by taking a spare spark plug and connecting a spark wire to it while it lies on a metal part of the engine and crank. It should have a good blue spark.
  • maurerush2112maurerush2112 Member Posts: 9
    outside temperature on '02 bonn. shows anywhere from 12- 25 degrees warmer than should. it adjusts after shut down, as it should with warmer underhood temps, but never gets close to accurate. It won't kill me not to have it, but up here in wisconsin der hey, it comes in handy when your out and temps fluctuate around freezing. tried obvious things, such as disconnect power for short time, check harness, etc.
    anyone with same experience?
    Have you simply removed the sensor in front of the radiator and cleaned the connector? From what you're saying it has been doing this for a while--it's not recent with snow or moisture getting into the connector out front?
    You can remove the sensor and measure its resistance at various temperatures. I assume there's a table of proper resistances for various temperatures. It may be in the factory service manual. It's a relatively inexpensive part so depending on how much trouble you're willing to go through it might be easier to replace rather than test.
    The same sensor is $15.98 from rockauto.com plus shipping. I'd get AC/delco ACDELCO Part # 1571823 myself. You could check autoparts stores for a quality brand.
    OR
    BUICK LESABRE 1999
    BUICK LESABRE CUSTOM (1992 - 2005)
    BUICK LESABRE LIMITED (1992 - 2005)
    BUICK PARK AVENUE (1991 - 2005)
    BUICK PARK AVENUE ULTRA (1991 - 2005)
    BUICK RIVIERA (1995 - 1999)
    CADILLAC DEVILLE (1994 - 2005)
    CADILLAC DEVILLE CONCOURS (1994 - 1999)
    CADILLAC DEVILLE DELEGANCE 1997
    are the models that all use the SAME sensor. Visit a recycling yard. Your odds of getting a sensor (ambient air sensor) would be good.
  • fallaciesfallacies Member Posts: 1
    well let me know if you ever find out the problem, mine is doing the same thing.
    i will report my findings as well...
    i have a 98 SE, and one day i thought i blew my starter, so i pepboys said it was my starter, so i replaced it, and my care began running again...
    later, every once and awhile, the car would not start for an hour or hours at end... it would not kick or even try to crank--just the same as when the starter was dead; it would just sit, dead. then later start up powerful like nothing had ever been wrong...
    now, it has basically stopped working... and i think that it was never my starter to begin with...
    when i turn the key, i have on "check gages" light and the "engine" light is on...
    i believe the pressure and everything else is fine... and i plan to get an engine diagnostic as soon as it finally starts back up for me to get it to the car service...
    if anyone has any suggestions, please contact me asap.
    Have you completely checked the ends of the battery cables? If you have the double positive cable, cut the plastic so you can see in between the two. There is a post that corrodes and a spacer that may not make contact. Check the copper wire on each cable to be sure battery acid hasn't corroded down into the copper wiring.
    Then you're down to diagnosing. Checking for power at the starter itself. Then checking for power on the relay terminal on the solenoid when someone turns the key.
    Then you're down to using a cable to supply direct battery positive power to the starter terminal to be sure the car's cable isn't bad. If the starter doesn't work with a direct jump, then you know it's the starter.
    Using a direct cable from battery positive to the starter positive is dangerous because you must not touch the cable to anything a part of the car or you've got a direct short which will cause fire and sparks. But it's the ultimate test.
    BTW has your car been dripping oil from the oil pan where you park it? When I replaced the starter on my 98, the AC Delco rebuild shop asked if it was dripping oil. He said the oil gets in the solenoid and keeps it from making contact.
  • msticcomsticco Member Posts: 1
    Hi, I have a 95 Bonneville and have been having some electrical problems with it. For a long time I did not have any dash board lights but the check engine lights and stuff like that work. I also didnt have any lights on my radio or heating panel. Lately the dash board lights have been working. They came on about 3 weeks ago and have been working with out fail everytime. I went to get into my car tonight and my headlights dont work. I do have dash board lights still. I had a issue with the head lights a few months back but a couple of hours later they worked. Any ideas on to why its doing this? Could it be a fuse or do you think its an electrical issue within the wiring? Can anyone help me out with this? Its really starting to annoy me! Thanks. Any feed back is greatly appreciated!!
    The first place to check is the battery connections, especially the postive battery cable which is double layer on many cars after a certain year. Cut the plastic to check for corrosion between the two positive cables. They are separated by a lead spacer/washer that may flatten and not make good contact after tightening over the years. Check to be sure the copper cable is not eroded away by acid as well near the ends of the cables.
    Check the other ends of the connectors and the ground for the negatives. I suggest retightening them.
    There are ground busses under the door sill plastic and carpet near the A-pillar. Driver's side and passenger side.
    These are wrapped up in tape but still may corrode due to moisture from shoes dragging in snow and rain or open windows for some people.
    Instrument panel connections behind the instruments also may slightly corrode and not make good contact. For certain problems reseating them helps.
    There's no one cure without looking at the factory service manual to follow the wiring to see what shares what connector among your various problems. So I suggest troubleshooting the above suggestions.
    Be sure to turn off your AC with the key ON so it parks its parts before disconnecting anything.
    The only other problem area is a worn ignition switch and the contacts inside don't make good contact on certain connections out of more than one it makes when in ON or RUN. This is the switch, not the lock cylinder at the top. The lock moves a rod that operates the switch which is down on top of the steering column to make it hard to mess with in a theft attempt. Some have reported fixing problems by replacing that but typically it's a shutoff while running which restarts easily. That doesn't sound like what you're getting.
  • emh1emh1 Member Posts: 1
    I have the same problem. Did you ever get it figured out?
  • san77san77 Member Posts: 1
    The new problem is the front windows, they will not work, they are stuck on up position. The heater/air motor is also going out, so there is not air, no way to get windows down. The back windows back in the winter one at a time, fell, and could not go back up, so they are bolted UP. The Sun roof is broken. I just got a call from our auto mechanic and they said to pick the car up they could not figure the problem out. I know the radio as well used to shut off when the door opens, well it stays on till it desides to shut off. I am going to have to take this to an electical specialist,,,, that is going to be very expensive..I think the car has been a lemon from the start, all the extra's on this car is not working...Windows, Heated seats, sun roof, heater/ air fan motor,
    But with the hot days coming, the car is black with leather seats, no air to circulate gets really hot,,,,,
    Can any one help,,, we checked the fuses,,,,,
    The blower motor most likely is a poor ground from the motor that barely makes contact. If you can take the motor apart it's at the brushes end. Some people extend it with a copper braid wire. If you kick you foot up against the bottom of the heater case in the middle, does it start working? Or when you hit a bump?
    The windows are controlled by various modules that talk to each other over the network. Do your door locks work? There's a main module in the driver's door that communicates with the other door modules. Some people find a poor connection in a braid of several wires running under the carpet under the middle of the driver's seat area. There's a connection which may corrode.
    There also are several different fuses involved including under the rear seat and under the hood. The radio going off is part of the retained power and someone elsewhere just went through a diagnosis with it. I do not know if it's a part of your problem. I have not diagnosed one of these, but have read several people having done so.
    Your rear window is the regulator which has a slide that moves up and down via a metal cable to move the glass. The metal cable terminates in a plastic part. The supplier gave them several which are defective and break that went into 2000-2002s the way it sounds. People take out their regulator and send them to places on Ebay or other sources which repair and return or do an exchange. I do not recommend Ebay, but sometimes they have what is needed.
    If you set up your carspace email on your carspace page in the upper corner of this page which say's "my carspace" then send me an email at my carspace account which is my username in the title for this post with an at sign and carspace dot com. I'll try to help you find info.
  • 02gtpbonn02gtpbonn Member Posts: 1
    Hi everyone.
    I am a longtime lurker to this great forum and I need your help.
    I just put a 2001 3.8 SC from A Grand Prix GTP in my 02 Bonneville.
    The motor is in and all that is left is the electrical and the front shaft connections.
    I have a few questions and need some help if possible!
    1. We are thinking we need to use the computer for the GTP motor.
    2. The wiring harness( where it plugs into the fuse box, and the connection in the firewall-under the master cylinder is different.) The 02 takes a rectangular plug, and the one on the new motor is round.
    Anyone have any ideas on how to proceed?
    Joe
    I found your email, finally. Check your mailbox. Pay special attention to the link about the connection under the front seat that can stay wet and is a junction between the modules in the doors. People have found that doesn't make contact causing things to not work because they can't talk to themodule in the driver's door.
  • tjp4tjp4 Member Posts: 1
    I'm experiencing the same issue with locks going on and off while driving. Have you heard any reason why?
  • tjacks1tjacks1 Member Posts: 2
    i cant get car to turn over when i try to jump starer with screwdriver it turns over but wont do it with th key is there a way to disable the security system or reset it the keys have a chip on it and i was told it might not be reconizeing them any one out there who can help with this problem
    This is an early solution.
    http://vats.likeabigdog.com/t
    If you put your key in and turn it to on and the security light flashes for 3 minutes and then resets to read a new key insertion, you either have broken wires in the column where the tilt flexes, the contacts that rub the chip are dirty (alcohol on key when inserted may help), or the contacts on the key are dirty (rub with pencil eraser).
    When the system doesn't read the chip right, the lights on dash all come on, but when turned to start nothing happens. You'll hear fuel pump when key is turned to on. But injectors and starter are disabled for 3 minutes after you turn the key 3 times to start with a wrong resistance reading.
    You can read your resistor with a meter, and match with the 15 choices in the link I posted. Buy resistors at radio shack for a series you solder together. Or see an aftermarket alarm place; they routined bypass these with resistor sets for alarms they install.
  • rednufrednuf Member Posts: 1
    Had same problem with my 02. Was told by dealer whole unit would need to be replaced. Then one day another light was out on my dash, so I slapped the top of the dash and that light came back on. So I decided to try it on my stereo. I flicked the display with my finger twice and the light came back on. You might try that. It's a shame that vehicles have become so complicated and so poorly made.
  • megaroosmegaroos Member Posts: 1
    My mom purchased her 94 from my brother last year. The car had issues with water leaking into the driver's side very close to the pedals. He assumed it was from the sunroof and taped it so it wouldn't leak and well you cannot use the sunroof anymore. That helped with the leaking, but it sat unused in a garage for a few years. The car however has been having issues with the dash. The odometer and the window that shows the little car icon (IDK what it's called) come on sporadically. The window flickers on and off but more so off lately. She cannot get the car inspected b/c of this issue. Before that, when the car would show up in the window, it would chime that the 3rd brake light was out(which is wasn't).
    I am wondering where to even begin to look for the problem, is it a fuse or wire or both?? I'm thinking that the water had something to do with it.
    :confuse:
  • theelectriciantheelectrician Member Posts: 1
    I just changed out the a/c blower motor on my 2005 pontiac booneville. The motor will not come on. I found a field mouse lodged inside the old motor. Is there a fuse, relay or resistor that i need to check? The a/c compressor starts and stops with the switches on the dash. I have a newborn and gotta fix this fast.
    Fuse #2 30 amp. rear block under rear seat. That may mean the original motor was okay and just swedged by a mouse carcass?
    Check your connector under the dash for a burned contact or a contact that has unclipped and is recessed too far to make contact.
    I am assuming your car is wired like an 03 leSabre. I checked the CJ2 diagram for auto temp control.
    fuse #37 goes to the control, but you said the control is working other parts of the system.
    On the blower motor connectors B and C are power and ground. A is a feedback to the control unit. You might use a fused jumper to see if you can apply power to the old motor and make it turn and then the new one.
    Good lluck.
  • shawn101gshawn101g Member Posts: 2
    HI yall i have a 92bonneville and my service engine light has been on when i had bought the car. a week later the car would not do anything when i turn the key. the lights and radio come on but thats it. so i had bought a new battery& a new starter, took it to the shop and they said no power was going to the column so they said i needed a new key or a new column so i bought a new key nothing. then a new column still nothing. i had noticed that my security light dose not come on at all when i turn the key i dont know what to do or what is wrong can any one help
    My guess from a distance is that yo've been sold a new key and new column you didn't need.
    You may have a connection problem in the various battery cables and grounds. Especially grounds.
    Do you hear a click when you turn the key to ON as the starter tries to work?
    There also are ground busses under the door sill plastic liner and carpet on the driver's side and passenger side. Pull out the sill at the front and check for corrosion on those grounds. I do not know if one affects the starting circuit, but cars in wet climates or having leaks have developed corrosion there.
    The chip in the ignition key is read by contacts in the lock cylinder. Two tiny thin wires go down the column, inside a plastic cover that looks like it's a solid wire itself, to the connector at the bottom of the column where the two inner wires split out to different connections. From there the leads go to the computer on those early years of PassKey and the resistance is read by the powertrain computer whether to allow injector pulses and to allow the relay for the starter circuit (high up on the firewall above the passenger's side where it's very hard to reach.
    The two wire can be cut where they go up to the steering column and connector by a resistor series of the same resistance as the chips in the keys.
    Then the computer gets the right reading for the car's key all the time. No theft resistance.
    http://www.thirdgen.org/vats_passkey_system
    yeah i kinda figured that i did get sold things that i did not need. but when i turn the key the starter will not even attempt to move. it was jump started by the guy at the shop. but it only ran for maybe 3 seconds and it shut right off he said that something was enabling the fuel. and he replied that he did not no why the security light dose not come on at all when the key is turned to the on position to allow the lights and radio to come on.
  • fcbclanfcbclan Member Posts: 1
    starter ok relay ok no power to small purple on relay
  • hbj1955hbj1955 Member Posts: 1
    I has my '95 towed to Affton Auto Electric. They found a bad ground boat. These guys know what they are doing.
  • jmosejmose Member Posts: 4
    I'm working on a 94 bonne I need a way to check a 5 digit trouble code the code
    that came up is not in the Haynes repair manual P0629 any ideas where to get help , pass key frequency invalid also comes up.
