Acura CL Tires and Wheels
                    I hit a curb and put a painful scrape on one of those handsome alloy wheels. Not particularily deep (say about 1mm), but about 2 inches long by 1/2 wide.   Any suggestions about how to remove/remediate the ugly blemish?
sincerely,
1999 solara V6 5 speed owner
(4 alloy wheels, + 1 full size alloy spare)
BTW, exchanging the damaged wheel for the spare won't repair the problem. Is that a Toy solution: Just hide it in the trunk?
my point was, in the accord coupe vs solara conference, we sometimes discuss pros and cons of each car, and one advantage put forth by the solara folks back in the 1999 model year was the full size alloy spare-- the accord coupe folks poohed-poohed this, saying, heck, they never use their spare (and when they do, it's just for the brief time they need until they get the puncture hole patched in their tire)....but here's a case where having a full size alloy wheel spare comes in handy-- when you scratch the wheel itself against the curb.
i'm not starting a ruckus here tho, not me. in fact, i think starting with the 2000 solara, they cheapened out and went to a steel rim spare (so I hear)---- tis the holiday spirit and i'm just filled with good cheer. you folks own a real nice car, that acura cl-p/cl-s-- i kinda wonder how you keep it under 55 in a 55 zone-- i think radar detectors should be standard.
Back to the original problem: does anyone have a suggestion for refinishing a gouged wheel? (Other than downgrading to a Toy?)
or..take the spare to a brake shop-- they probably have experience turning brake rotors on a machine lathe-- explain your problem and see if they could provide a remedy...wear goggles if you assist.
http://www.bumper.com/wheelrpr.htm
if you use a search engine and type in "alloy wheel repair" it will take you to various sites related to this..i use google.com as my search engine.
hope this helps.
Larry Homer
lwhomer@cwnet.com
I should replace them with the same type which is Michelin 205/55/16.I would like to know if anybody
has put 60 series on.COSTCO said 60 series are too
big.My only gripe about the original tires is road noise.I have 54K miles and lot's of tread is left but cracks are in the sidewalls.Also the price is $144 each mounted,balanced,with road
hazard coverage.Is this a good price?
thanks......i have a picture of them if you want to see....email me and ill send it to you//
you pay $7 for a package that includes road
hazard warranty.That's per tire and it sounded
like a good idea.Now it sounds like a GREAT idea.
My CL has not run over anything yet that ruins a tire but... My wife's new TL hit something on the freeway and caused a blowout and had no road
hazard coverage.Acura roadside assistance covered
the tire change but it costs over $150 to replace
the tire.Since I have learned my lesson I now
have coverage on all my tires.More advice don't
try changing a tire on a busy freeway you might get killed by crazy drivers instead join AAA
or buy a car that has roadside assistance.Driving
just a short distance on a flat can ruin an alloy
wheel and that's another $300 or so.
In other words, it appears that dirt and water whipped up by the tires can get in between the gap where the 2 pieces overlap.
I'm wondering if it is just my car where there is separation of these liner panels, or are they all like that. Secondly, assuming these gaps are by design, would that create a problem (in regard to dirt and water getting in)?
OR.......you could just be careful when parking and make use of the tilt-down mirror. This was one of the first things I was warned about in the http://www.acura-cl.com board.
I agree that it is a weird design, but if you're careful, they don't have to get scratched.
fastdriver
Plus, you wouldn't be able to find a decent slice of pizza, which is even worse.
Wants to know if he can fit a 225/50 without a problem? He seems to think by going to a bit wider of tire it will stop the rims from getting scraped so easiliy. I checked out his wheel and it does look like the stock rims are wider than the tires.
thoughts anyone?
spyder98
I don't have a problem with wheel scratching... lucky me
I'm sure a 225 will fit on the rim without a problem, but will it cause rubbing problems with suspension parts etc..?
I would hope the acura wouldn't have such tight tolerances.
No?
if you look at it this way... put 18-wheeler's tires on the existing wheels then you can decrease the protruding wheels... then you won't be able to fit the tires properly, right? Maybe someone can test it, but I don't think that 225 would help in this case. ( I might be wrong about my theory, but I still don't think that it would be worth it to upgrade the tires for that reason)
The circumference is also increased by 1.5%, which would mean that your speedometer/odometer would be off by 1.5%. You would actually be going faster/farther than it said by a factor of, you guessed it, 1.5%
An extra 10mm or so in tread width should not exceed the rim's capacity or the wheel well spec. It will help traction by giving you more rubber on the road, and handling because of the lower profile ratio.
Actually, the ride shouldn't be any rougher as the sidewall width will not get any narrower. Also, if he switches brands or models, he may find a smoother, quieter tire. The Yokos I put on my Impala are quieter than the Michelins that came on my CL.
There was an error in my previous post, though. The profile of the new tire will remain the same, so his cornering probably won't see any improvement from decreased flexing of the sidewall. The additional tread grip, however, should improve cornering as it relates to skidding.
Seriously now, don't certain models of BMW come with some sort of a audible warning system for curbs?
now I want to have side curtain airbags... I think the CR-V has them... what's up??? Not that I want to use them anytime... NEVER would be better... but...
Maybe this has come up before but let me ask anyway. Has anybody replaced wheels/tires and have a recommendation? Maybe some of you have gone back to 16's or upped to 18's. What will make this car look/feel better?
The stock tread still looks good for another 10k mile or so, so i've got some time.
kt
